Author Topic: Oh Blimey I bought a CNC Lathe !!!!  (Read 482153 times)
« Reply #300 on: July 10, 2013, 12:58:28 PM »
Thanks Tom. It arrived this afternoon and is on charge - not had time to play yet as I've to dig 30 metres of land drain this evening in the field
« Reply #301 on: July 11, 2013, 06:17:30 AM »
Today's Task: get the tin work back on the 'X' axis turret slide.
So this:
« Reply #302 on: July 11, 2013, 06:19:09 AM »
Needs covering up with this lot - anyone remember what goes where and in what order  :bugeye:
« Reply #303 on: July 11, 2013, 06:20:13 AM »
Trial offering up sorted out the conundrum, so we start with the left cheek piece:
« Reply #304 on: July 11, 2013, 06:21:04 AM »
Followed up by the smaller boxy shaped thingy:
« Reply #305 on: July 11, 2013, 06:21:55 AM »
Followed by the bigger boxy shaped thing:
« Reply #306 on: July 11, 2013, 06:23:00 AM »
And finally the outer left hand cheek which was the panel I had to make - will it fit ....
« Reply #307 on: July 11, 2013, 06:27:14 AM »
Yes it did - so it should !
Rightly or wrongly I decided to lather the entire inside of the metalwork with undiluted soluble cutting oil. My argument being that the bare metal had already shown signs of corrosion, the soluble cutting oil has corrosion inhibitors in, and it seems to cling to my other machines pretty well as the water evaporates. Also I didn't want to introduce other oils as the whole machine will be awash with soluble oil when widget production starts.
lordedmond
« Reply #308 on: July 11, 2013, 06:43:53 AM »
 its getting closer to widget production  :beer: :bow:
Stuart
« Reply #309 on: July 11, 2013, 03:09:39 PM »
Stuart
Won't we wejoice with 'whoopees' when window wonderfully weveals whizzy widgets wending wictoriously without westriction while weltering white water washes wotating whiskers within?
   :beer:   :D   :beer:   :D   :beer:   :D   :beer:   :D
« Last Edit: July 11, 2013, 03:46:03 PM by Pete W. »
« Reply #310 on: July 11, 2013, 06:20:32 PM »
westwiction, pwease!
Cawamba, what is the wanguage coming to watewy?
lordedmond
« Reply #311 on: July 12, 2013, 02:38:36 AM »
you have that rare and highly contagious condition  called Wublewoo Syndrome
Stuart
« Reply #312 on: July 12, 2013, 03:26:38 AM »
  :whip: OK you lot at the back of the class room, stop mucking arround and concentrate  :whip:
We have SWARF
  :ddb: :ddb: This may not be the most impressive demonstration in the world, but it IS the first time this lathe has produced swarf in probably over 3 years  :ddb: :ddb:
I had to cheat as the tool setting issue is currently defeating me. I wrote a diddy program to start the main spindle at 1000 rpm then used MDI to do the turning - up until now I hadn't found a way to set the spindle running other than when running a program, but I found that you can actually pop out of the program leaving the spindle running and operate the machine either under MDI or jog mode.
Anyway a highly unimpressive picture of a 1" stainless steel bar reduced to 21.14 mm and the resulting swarf:
« Reply #313 on: July 12, 2013, 03:32:42 AM »
I have made contact with a company in the midlands that run several Traub CNC lathes and have been offered the opportunity to spend the day with them picking their brains and copying any documentation that I don't already have. Even more surprising the SWMBO has agreed (even actually suggested !) making a mini holiday in her motor caravan and dropping me off for the day - I feel quite faint  :clap: Just need to arrange a farm sitter for a couple of days - any volunteers ?
« Reply #314 on: July 12, 2013, 04:06:59 AM »
Stuart
Stuart,
Well, I AM Pete Wublewoo, so who'd be more likely to suffer it?   :bugeye:   :bugeye:   :bugeye:   :bugeye:
(If it's that contagious, how can it be so rare?)   :)   :)   :)   :)   :)   :)
  :whip: OK you lot at the back of the class room, stop mucking around and concentrate  :whip:
We have SWARF
   SNIP
Awemawson,
Hooway, Hooway, wictory, wictory, we wesoundingly wejoice!
 :clap:   :beer:   :clap:   :beer:   :clap:   :beer:
Offline Anzaniste
« Reply #315 on: July 12, 2013, 04:27:50 AM »
CONGRATULATIONS!!!! :thumbup:
Following this thread in complete awe, not understanding a word but recognising the grit and determination to see it through, I am full of admiration for your efforts.
I'm looking forward to seeing the beast do more than one thing at once under the voodoo magic instructions that I am sure you will be able to incant. :beer:
« Reply #316 on: July 12, 2013, 09:07:28 AM »
awemawson
Congratulations on having made the first swarf with the machine. Hopefully it will be all downhill from here. Getting the opportunity to spend the day with the machines, operator and documentation should help you imensley.  :ddb:
I would offer to farm sit but they haven't finished building the bridge over the pond as yet.  :lol: :lol:
« Reply #317 on: July 12, 2013, 09:21:57 AM »
No Bridge Don - dig a tunnel  :lol:  (watch out for the mid Atlantic Ridge )
Farm sitter sorted, date set for two weeks time, so hopefully onwards and upwards.
« Reply #318 on: July 12, 2013, 09:37:50 AM »
Excellent! Congratulations!!!! :thumbup:  :clap: :clap:
« Reply #319 on: July 13, 2013, 08:48:00 AM »
:bugeye:  Inside The Belly of The Beast  :bugeye:
Been experimenting putting a 'GoPro' video Camera inside the machine enclosure - really just mucking  about trying to make sure it's in a relatively safe place and still get a reasonable shot:
(How do I embed a Youtube link? - cutting and pasting from the youtube embed link doesn't seem to work)
« Last Edit: July 13, 2013, 10:38:12 AM by dsquire »
« Reply #320 on: July 13, 2013, 09:54:32 AM »
www.youtube.com/embed/cW5xb9LVlE8
Andrew,
Simples: Press the YouTube Button and paste the video url between the inner pair of square brackets. (Right click on video and click on "Copy Video URL".)
[ Invalid YouTube link ]
I'm amazed that you couldn't suss that one out considering all the far more complex problems you've shown you can solve.  :thumbup: :thumbup:
« Reply #321 on: July 13, 2013, 10:34:26 AM »
Well it's still not working for me :(
"Press the YouTube button" - which button where ?
"Inner pair of square brackets" - which square brackets where?
From the source video on my youtube page I can by right clicking :
'Copy Video URL' which gives me:
or
'Copy embed code' which gives me:
<iframe width="640" height="360" src="
" frameborder="0" allowfullscreen></iframe>
No Youtube buttons or square brackets in sight !!!!
« Reply #322 on: July 13, 2013, 10:47:53 AM »
awemawson
This is how you initially had it
Code: [Select]
This is what you need to make it work
Code: [Select]
[youtube]cW5xb9LVlE8[/youtube]
There are other methods but this one allways seems to work for me. it is those 11 characters between the square brackets that you have to find. Hope this helps. :D
« Reply #323 on: July 13, 2013, 11:49:55 AM »
OK I've found the 'Youtube' button hiding amongst the test attributes - thanks Don and Philf.
« Reply #324 on: July 13, 2013, 04:38:35 PM »
Andrew,
Sorry - I should have told you where the YouTube button was. I went out just after I posted so have only just seen your reply. I didn't know you could just paste the video code between the square brackets so I've learned something myself.
I'm just about to venture into the world of a CNC lathe. Mine shouldn't present much of a problem as there's no auto tool change, only a 1/2hp spindle motor and a 3-jaw manually operated chuck to worry about. (And it will fit in the boot of my car!)
Cheers.
