Today's Tasks: Clear the bench, Invert Tool Disk on Trolley to inspect the Curvic Coupling and dust seal, Lift body of Tool Turret onto newly cleared bench.
How hard can it be! Well I was about to start and we were hit by another power cut. Two hours later I could start. Strategically placed dust bin at the end of the bench and a hand brush cruelly applied solved the bench clearing (with a few item saved!)
Re-arranging the lifting strap turning the tool disk over onto wooden cribbing was relatively simple:
Lifting the body of the Tool Turret was a bit messy due to it's shape but up it went - getting it high enough to sit on the bench was slightly complicated by to boom of the crane fouling the bench lighting but manually swinging the load away from vertical got it there, but I must say the rigging was decidedly dodgy
Once on the bench it was a case of using levers to get it on a firm base and I could move the crane out of the way and start inspecting it.
It rotated reasonably freely which is more than the one currently in the lathe will do, AND it will move outwards to lock the curvic coupling AND back again. Features missing from the other one.
So why am I not going to use this body! Well it's casting is cracked and it lacks the powered tooling features, so this is simply an education lesson for me before attacking the other turret.
But that's enough for today, I'll hope to continue tomorrow.
