Author Topic: The Sequel - Oh Blimey I bought a CNC Lathe (Beaver TC 20)  (Read 1252914 times)
« Reply #1300 on: January 10, 2026, 04:00:06 PM »
Haas use electric cooker elements (the spiral ones) stacked to give the required resistance
« Reply #1301 on: January 12, 2026, 12:36:20 PM »
Yes, glad to see you working on it, too, Andrew. Though it also looks like a pain! Reminds me of a giant scale version of my little plastic welder's problem -- which I never did fix, BTW.  :beer:
« Reply #1302 on: January 19, 2026, 08:40:51 AM »
So time ticks by !
Several false starts winding the resistor: Firstly hand winding it is a pain (literally) the wire is very springy and hard to tension - anyway I persisted, got an ugly looking resistor but it's resistance was far too low.
Turns out my calculations were wrong on two counts - wire diameter was actually 1mm not 0.9 as measured - the bit I measured was wasted down by being repeatedly  heated - and the turns count was wrong due to the mounting arrangement obscuring things as there were actually extra inactive turns used for the terminations. Re-working the calculations proved that it actually is wound from the more common Ni-Chrome wire. So I ordered up a reel of 1mm Ni-Chrome and wound another resistor. To aid winding I made up a bolt on adapter for the frame allowing me to mount it between centres on the lathe (still hand turned), this allow me to have better control on the tension - if only the reel of wire had been long enough  :bang:
« Reply #1303 on: January 19, 2026, 09:07:19 AM »
Still in the end I did end up with a fairly neat winding and when all was re-assembled and the two halves of the resistor paralleled up it measured exactly and precisely 3.3 ohms - phew what a load of bother for a simple wire wound resistor.
Re-assembling it all on the machine went reasonably well - I thought I'd leave testing to the following day. But in the night I woke up in a sweat thinking 'did I remove that melted dribble of resistance wire on the upper cage frame ?' Of course I had to pull it all apart again to check and sure enough I hadn't - the power of dreams - lucky really.
Anyway testing at least didn't result in the previous glowing fire that I'd had previously - controller came ready but when I pressed 'Reset' to initialise things it went into eStop and dropped the servo crate power displaying:
Decoding the error message it was implying that the Z position encoder was out of phase, shorted or disconnected. Now the encoder and it's wiring are not the easiest things to access and are far removed from where all the trouble had been. My first suspicion was the servo cards immediately below where that resistance wire had melted and dripped however changing them made not an iota of difference.
OK bite the bullet - open things up - get to the back of the Sinumerik controller by sliding it out of the cabinet onto its shelf so now at least I can see the Z axis encoder cable where it plugs into the Siemens 'measuring card' that takes all four encoders. Nothing looked amiss - suppose it's the measuring card itself? Fortunately I had a spare. A bit of gymnastics - old card out - new card in and lets see:
Whoohay - I can now jog X and Z axis for the first time in months  :ddb: :ddb:
At that point I decided to quit while I was ahead and reserve more testing for tomorrow - there's only so much excitement I can take these days  :lol:
Offline modeng200023
« Reply #1304 on: January 19, 2026, 09:14:12 AM »
Well done!
« Reply #1305 on: January 19, 2026, 10:35:03 AM »
Thanks.
The good luck continues - OK I've used my one and only 'Measuring Card' spare.
Best see if any are available on eBay - oh yes several in the price range just below and quite a bit above 1000 UKP - yikes. Then I found a UK dealer clearing his stock -  20 UKP inc postage - never hit a 'buy it now' key quite os fast !
« Reply #1306 on: January 21, 2026, 06:16:42 AM »
Not been able to continue this push until this morning (yesterday - standby generator failed it's regular 'test start' I fire it up every few weeks and it's a good starter - should be it's brand new. I start it, then turn the fuel off and run until the carb is empty to stop it gumming up. Well it's gummed up and needs a carb strip  :bang: too much grovelling at floor level so woke unable to move - 600 mg of Ibruprophen and I can now move so off to the workshop.
Lathe fires up correctly, I can traverse over the reference points, initialise the tool turret, select tools at will, drive the main spindle clockwise and anti-clockwise - in fact EVERYTHING IS WORKING  :ddb:
Now the big caveat is that currently the tool disk is currently empty - no tool holders fitted so minimal weight for the servo system to fight. (There is approximately 45 kG of tools when all twelve positions are fully populated)
It was while diagnosing erratic positioning of the tool disk that I managed to blow up the Siemens Simodrive AC servo system so I'm tredding ever so carefully at the moment and only taking small steps.
« Reply #1307 on: January 22, 2026, 05:36:50 AM »
Todays job. Recommission the coolant system - now this sprays coolant everywhere in the enclosure when things are spinning, so the first job was to replace the cast aluminium cover for the tool disk and Z axis motor connections. Hylomar sealant scraped off the mating faces - but where are the screws ? Cover removed a couple of years ago but normally I'm pretty good at keeping things together. It's only half a dozen M6 x 20 mm socket caps - no where to be found. I guarantee they are safely in a marked up poly bag somewhere - no sign of them and surprisingly nothing in stock - Amazon order placed for tomorrow  :bang:
So having been foiled in that task I thought that I'd play with a bit of simple programming - set up a diddy ( test loop  ) to exercise the tool disk - could I remember the commands - no! OK lets see if Chat-GPT knows this controller. Please generate code to select Tool#1, pause 5 seconds then select Tool #6 on a lathe controlled by a Siemens 820T controller:
O1000
LBL 1
T1 M6          ; Select tool 1
G04 F5         ; Dwell 5 seconds
T6 M6          ; Select tool 6
GOTO LBL 1     ; Repeat loop
M30
And there you go ! Now it would have taken seconds to look up the codes but that was just a bit of fun.
« Reply #1308 on: January 22, 2026, 09:13:02 AM »
Just to remind me how I've uploaded a short video to YouTube of the tool turret rotating to select different tools and spinning the powered tooling (that isn't fitted yet)
Somehow Youtube have rotated it 90 degrees - any ideas how it sit it the right way up?
https://youtube.com/shorts/JY9bBcAkoLk
OK I've rotated it 90 degrees with CLIDEO.COM on line
« Reply #1309 on: January 22, 2026, 10:41:50 AM »
Video unavailable....not set to public view... :Doh:
« Reply #1310 on: January 22, 2026, 02:17:28 PM »
Hopefully corrected - thanks John
Offline kayzed1
« Reply #1311 on: January 22, 2026, 03:51:57 PM »
Worked for me.. :thumbup:
« Reply #1312 on: January 22, 2026, 04:11:10 PM »
Progress is looking good?.
« Reply #1313 on: January 22, 2026, 04:36:48 PM »
Thanks John. There are still loads of hurdles ahead. The servo action of the tool disc when fully loaded with its 45 kg of tooling will no doubt not be so crisp and that's where things went downhill previously failing to re-lock.
« Reply #1314 on: January 22, 2026, 08:01:13 PM »
Worked for me too
« Reply #1315 on: January 23, 2026, 06:01:13 AM »
Tool Turret loaded with three tools total weight about 10 kG. Two driven tools and a normal lathe tool holder evenly spaced around the disk.
https://youtube.com/shorts/kL3Tf-aXCA8
Left it running for a while to see what happens - fingers crossed still going !
« Reply #1316 on: January 23, 2026, 06:33:50 AM »
Well that ran happily for ten minutes :ddb:
M6 x 20 mm stainless cap heads arrived in the post this morning so I've re-sealed the turret interface box
« Reply #1317 on: January 23, 2026, 07:18:51 PM »
Looking good!
« Reply #1318 on: January 25, 2026, 11:42:57 AM »
Yes but . . . madness beckons  :bang:
I re-ran that same program again yesterday and it locked up - tool disk not sinking back into  the locked position after a move. In each case I was able to get it into lock by manually manipulating the drive for the lock and unlock hydraulic cylinders and giving the turrent a slight bit of rotation while unlocked. Theres a distinct feeling of de-ja-vu here from a couple of years back - it's as though the servo drive doesn't quite get the disk to the exact position for the curvic coupling to mesh.
Previously I was trying to set the servo system to eliminate a very slight back rotation by setting the drive gain and zero points and ended up catestrophically blowing up the drive system and melting that big wire wound resistor.
What I really need is an expert in Siemens Simodrive 610 AC servos to come and lean over my shoulder and give me a hand but they are a rare commodity.
This morning I revisited the issue and the fault was still extant. For a change of scenery I set up the good old Panasonic Toughbook running Window XP and the Siemens Step 5 PLC software to check I still had a viable set up (which I do it seems)
So this afternoon I thought that I might as well try running the turret program again - blow me down it runs faultlessly. I left it running for 36 minutes with no errors. Is it a temperature thing maybe. I remember years ago being told it's virtually impossible to set the turret tool change servo system if the seals round the disk have gone hard - they are a very large diameter so I can see they could add a fair ammount of friction. I measured the turret temperature as 14 deg C at the start of the 36 minute test and it rose to 15 deg C at the end but unfortunatly I don't have a value fir when it wouldn't run. The workshop heating allows the shop to go no lower than 5 deg C overnight to prevent freezing and condensation and in the day time the set point is 15 deg C.
I did measure one leg of the three phase servo drive card while it was running the program - it was peaking at about 25 amps iirc it's a 40 amp servo card.
Offline cnc-it
« Reply #1319 on: January 30, 2026, 11:48:40 AM »
I'm not sure if this chap is still carrying out repairs Andrew but when I spoke to him some years ago he said that he specialised in the older Siemens controls and servo drives.  At the time he was doing some work for a friend of mine who is the Heidenhain distributer in my area.
DW NC Solutions
Dick Westland
28, Spinney Hill Drive
Loughborough
LE11 3LD
Mobile: 07967757435
Tel: 01509 230479
« Reply #1320 on: January 30, 2026, 05:28:29 PM »
Thanks for that
« Reply #1321 on: February 06, 2026, 06:26:51 AM »
I am STILL chasing turret rotation issues.
As an aid to seeing miss-alignment I have made a metal 'fiducial line' and bolted it to the structure of the turret to allow me more easily to see any misalignment as the curvic coupling settles together. Like the teeth on reverse bevel gears the two halves of this coupling not only ensure that the tool disk is in the correct radial position, but help to retain it there as the hydraulic piston locks it in place. Any miss-rotation shows up as a slight rotation as they settle together and is not easy to quantify with nothing close for the eye to compare it to - hence the fiducial line.
Then I cobbled the hydraulic drive that presses the tool disk forward and reverse and by trying to rotate the disc by hand could feel the sweet spot where the servo was 'happy' - engaged position is the black line - blue line is where the servo wants to settle.
Now on the analogue drive card in the Simodrive servo crate is a 15 turn 10K  pot that the book labels 'offset' but there is no procedure anywhere that I can find for setting It. Random twiddling is dangerous but I didn't have much choice. A couple of turns clockwise seemed to make it worse so 4 turns anticlockwise - not much different. OK a few more turns - argh servo not happy at all - roughly put it back to where it was and we are back working and oddly rotational positioning seems better.
Here is a video where I have placed a Sharpie line for every correct turret position (made when curvic coupling engaged) to show that there is still a bit of joggling into place as the coupling comes together but not massive.
(Video was prematurely ended by me catching my iPhone on a passing tool and it being dashed into the swarf tray !)
https://youtube.com/shorts/ScP4BF2CDUM
« Last Edit: February 06, 2026, 07:13:23 AM by awemawson »
« Reply #1322 on: February 06, 2026, 06:53:06 PM »
Hmmm  :scratch:  ISTM that the misalignment is quite inconsistent - sometimes the tool goes "down" as it pulls in, sometimes "up", sometimes down THEN up or vice versa... Also interesting that it doesn't always disengage in a straight line; e.g. the first time it disengages from post 3 (at around 6-7s) it looks like it drops slightly.
I'd be wondering about now if it's not some kind of physical/mechanical wear, rather than iffy electronics. Although honestly, that's just pure guesswork.
What (if any) sensor(s) does it have for indexing? And is it a closed-loop servo or a closed/open loop stepper that's driving it?
« Reply #1323 on: February 07, 2026, 03:23:53 AM »
There is a Baldor. SMCC card that controls the tool turret, and this card is a self contained servo system that does the thinking.
At start up it takes input from an index sensor which is fixed to the structure of the turret and looks at a notch on the internal rotating bits. From then on it counts encoder pulses from the encoder that is mounted on the turret servo motor - 2000 counts per tool position . The SMCC card generates a -10 to +10 voltage analogue signal that drives the Siemens Simodrive ultimately providing three phase drive to the servo motor
Once assembled virtually none of the signals are easily available for monitoring which make fault finding interesting!
« Reply #1324 on: February 07, 2026, 06:23:34 AM »
This is getting silly, I set off this morning with the intention of fully loading all the tool positions - so more inertia to shift. Before I did that I re-ran the program in the previous video where the fidicule line was showing reasonable positioning but no this time there is a significantly greater error .
Same program, same tool load - argh  :bang:
Now it's running in the back ground as I type this, and hasn't failed to seat the curvic couplings over a fairly extended run, but something has changed. The only thing I can think is maybe the temperature has changed. Today the turret is at 14 deg C and the Simodrive is at 16-17 deg C - what was it yesterday - I don't know  :bang:
The rotational positioning is within the mechanical 'capture range' of the curvic coupling but it certainly is less accurate than yesterday. Oh boy is there any way out of this maze ?
https://youtube.com/shorts/Zh7LAquC93o
