Author Topic: Witchcraft! ak.a know as quadralell.  (Read 10268 times)
Offline NeoTech
    • Roughedge Hobbyworks
« on: November 11, 2013, 07:26:59 AM »
I found this kinda nifty and seem to be simple enough to recreate.. =)
Re: Witchcraft! ak.a know as quadralell.
« Reply #1 on: November 11, 2013, 08:03:03 AM »
That looks identical to a printers 'Quoin' used to clamp type letters in a printing frame.
« Reply #2 on: November 11, 2013, 09:20:53 AM »
If you'd asked me what a 'quoin' is, I'd have said it's a tapered house brick.  Or am I getting mixed-up with a 'squint quoin', a house brick with a skew end?
Offline flutedchamber
« Reply #3 on: November 11, 2013, 09:47:35 AM »
I do the same thing with two sections of large diameter spur gear about an inch thick.
« Reply #4 on: November 11, 2013, 12:45:32 PM »
A "Quoin" is a wedge, so the keystone in an arch is a quoin. In printing it is an expandable wedge used to hold the type in place
Offline NeoTech
« Reply #5 on: November 11, 2013, 05:54:45 PM »
Dont really seem to work same way. This got a ballbearing making two plates swivel against each other taking out odd angles when clamping. Not expandable at all actually.
« Reply #6 on: November 12, 2013, 04:07:59 AM »
When I had my Adana 10x5 printing press the quoins were just as you describe pivoting on a ball but with the screw acting on the ball to tighten up. There were two dowel pins fixed in one half, and very loose in the other to allow a lot of out of parallel motion
Andrew
Offline NeoTech
« Reply #7 on: November 12, 2013, 07:32:15 AM »
Ah ok..  Then i misunderstood your little picture there.. Well it seems like a valid way of clamping odd parts like.. car parts  and such that in some cases isnt always straight. =)
Offline AussieJimG
« Reply #8 on: November 13, 2013, 04:30:20 AM »
I think that's just what I need for a task I am trying to do.
Thanks
Jim
« Reply #9 on: November 13, 2013, 08:06:56 AM »
What is the maximum acute angle you can achieve?  Looks like a useful clamp.
Offline rotorhead
« Reply #10 on: November 13, 2013, 04:55:18 PM »
Hi Folks,
The quoin was originally used I believe, as a cannon gunners elevation piece, it was situated under the breech to aid rise and fall for a better aim.
I may be wrong again, but hey whatever.
Sunny Scunny,
North Lincolnshire.
Offline markball2
« Reply #11 on: November 16, 2013, 02:36:54 PM »
Ok, I give.  How does a feller make the recess for that ball bearing?  The rest is fairly easy machining.
I have a project in mind & have been struggling with the work holding.  I think something like this will work pretty slick.
I haven't always been a nurse..................
Craftsman 12 x 36 lathe
New to me Enco GL-30B Mill/Drill
« Reply #12 on: November 16, 2013, 02:47:30 PM »
Ball ended end mill, or form cutter
Andrew
« Reply #13 on: November 17, 2013, 05:41:06 AM »
I wouldn't have thought it needs to be curved - a countersink type dimple ought to work just as well.
Offline Fergus OMore
« Reply #14 on: November 18, 2013, 03:07:56 AM »
Actually it is a corruption of 'Coin' a French word for nothing odder than a  Corner. It gets hacked about  because none of us could spell or read or write but saying that- the French or most of them -- couldn't speak French anyway.
C'est vrai.
« Reply #15 on: November 18, 2013, 04:47:39 AM »
Norm,
"Coin" not only means corner, but it means wedge. Funny, I can speak and read French and the French I'm surrounded by seem to be able to speak it quite well, they can even write it, which I can't!
Ça, c'est vrai!
« Reply #16 on: November 18, 2013, 05:24:31 AM »
Actually wedging is coincage( apologies for the lack of the c cedille) from the verb 'coincer' to wedge.
« Reply #17 on: November 18, 2013, 06:00:57 AM »
Norm,
I didn't give your the etymology, the French for wedge is a coin, " n. m. instrument de forme prismatique (en bois, en métal) pour fondre des matériaux, serrer et assujettir certain choses."
In this case, the coin refers to the object and not it's action!
Eh beh, "je te bouche un coin la mon pote"!
A plus, Matthew
