Author Topic: Chester 626 mill CNC Conversion  (Read 451595 times)
Re: Chester 626 mill CNC Conversion
« Reply #350 on: July 14, 2012, 07:02:13 PM »
LOL too  :lol:
« Reply #351 on: July 15, 2012, 02:19:51 AM »
Mounting the work like this means i could machine all round the part in one go ,making all the edges parallel and square .
And do the chrome plate all at one go...............................................................
Where's that freeking Ju-ju doll ?     Pass me that big bodkin needle...........................
John S.
Looking at that lump of" scaly ****e being "transformed in to chrome plate has me feeling quite sickly
I'm out of words.........
Not unusual, I know......
Most early mornings, I sit here reading yesterday's edition of the Wilson Chronicle......
And....... All I can do, is shake me head, and smile..........
Love it!  :D
« Reply #352 on: July 15, 2012, 11:14:10 AM »
John S.
Love it!  :D
I love reading the Wilson Chronicle as well. I like how they sometimes manage to put all the pages into 1.  :lol: :lol:
« Reply #353 on: July 17, 2012, 04:26:39 PM »
Thanks Lads  :beer: :wave:
Well did a spell in the shop tonight  a bit more work on the motor mounts , I am using my 20 year old RF25 mill/drill to bore the mounts.
I used a hole saw to remove most of the material , witch left about 1/8" for boring , using the hole saw also means i dont have to move the head on the machine and loose alignment .
Bored to size , finish is Ok for an old not very ridged machine .
Thats the screw end done .
The motor end was done much the same way , just is an oval , bored both ends which leaves a little bit between the two too mill away .
I use mild steel bar ground up for parallels so it dose not matter if i machine into them .
« Reply #354 on: July 17, 2012, 04:29:31 PM »
Rob...
Can I come and stay for some machining lessons?  :beer:
« Reply #355 on: July 17, 2012, 04:53:57 PM »
I supose the finish is ok  :drool: :drool: :drool: :drool:
It would appear to be spot on size as well :D :D :D
Glad to see you are using propper material  :thumbup: :thumbup:
Not aluminium  :clap: :clap: :clap:
« Reply #356 on: July 17, 2012, 06:35:37 PM »
Man after me own heart, can't see what all the fuss is about hardened and ground parallels accurate to a given size to the nth micron.
Much prefer stock size ground down to a matching set. Plus points are if you use a 1" wide parallel it won't allow it to grip a 1" bar, toss up which one is held the tightest but if you grind 5 or 10 thou off to clean up they will always grip an 1" bar if you do have an accident it's doesn't cost you an expensive tool and possible harm a job.
This tip is only for the unwashed, that twat in the yellow mac obviously knows all this so I don't know why I waste my time posting instaed of making more Ju-ju dolls.
John S.
« Reply #357 on: July 18, 2012, 05:17:46 AM »
Aha, your secret is revealed Rob!
I see you are craftily using the hidden cutting edge on the back of the insert!  :)
« Reply #358 on: July 18, 2012, 05:50:03 AM »
Well spotted, Ade!  :clap: :clap:
I just thought..... Summat don't look quite right, there?  :scratch:
lordedmond
« Reply #359 on: July 18, 2012, 06:39:08 AM »
naw
he got it going backwards the mill that is
saves buying a left hand tool for the boring head
Offline 9fingers
    • Info on Induction motors (Heavily UK based!)
« Reply #360 on: July 18, 2012, 06:45:27 AM »
Nah! its how Rob gets his mirror finish  - rubbing on the back of the tool! :lol:
Offline rotorhead
« Reply #361 on: July 20, 2012, 04:00:08 AM »
No, Rob probably developed the negative in reverse.........
Sunny Scunny,
North Lincolnshire.
« Reply #362 on: July 28, 2012, 02:58:16 PM »
 :lol: :lol: :lol: :lol: Cheers lads  :beer:
Been a bit slow of late  :palm: , anyway did do a bit to the motor mounts .
Set up to round the corners , using the angle plate i made earlier and a stop , actually a cam roller from a fuel pump CAV i think .
once set its just a simple job to turn and flip part to do all four corners on both mounts .
Next the motor pocket , more cam rollers used to position the work on the mill .
Next the slots for the motor fixing screws . no DROs in my shop i use gauge blocks and the likes ,no battery's required   , after using edge finder to locate position of first slot , lock X stops
for the slot length and Y stop for first slot position , move Y to next slot position and lock stop .
work fist position .
Second position .
Remove gauge blocks , that are set for  the pitch of the slots , and slide job down .
Had a nice run up to Scotland today , picked up a new toy ,,,,, thanks Darren  :beer:
must resist urge to fiddle with it  :palm:
« Reply #363 on: July 28, 2012, 03:08:28 PM »
Motor mounts are to the usuall standard :drool: :drool: :drool:
That lathe it has not got any hand wheels  :lol: :lol: :lol: :lol: :lol:
Offline steamer
« Reply #364 on: July 28, 2012, 03:15:16 PM »
Nice work Rob!
I'll follow along....
"Mister M'Andrew, don't you think steam spoils romance at sea?"
Damned ijjit!
Offline Dean W
  • My kingdom for a lathe!
    • Projects web pages
« Reply #365 on: July 28, 2012, 10:22:28 PM »
OY!  What's this?
Whatter them humpy bumpy thingies?  You gonna tell us it's supposed to be like that,
or did you farm this piece out to the local chop shop?
 :hammer:   :scratch:
 :)  Nudge, nudge.  Wink, wink, & all that jazz...
Dean W.
Shop Projects:
« Reply #366 on: July 29, 2012, 05:45:39 AM »
Thats where he photoshopped the last operation.
Well spotted Dean I didn't think this latest Ju-ju doll was working, obviously is, just needs tweaking a bit or a bigger bodkin.   :zap:
« Reply #367 on: July 29, 2012, 05:34:27 PM »
hi rob work is brill as per that lathe is too smale for youe work shop it will go wel imn mine i think you need to chuck sum stuff out when do you wont me to fech the traler up  :) :) :)
lordedmond
« Reply #368 on: July 30, 2012, 10:49:30 AM »
OY!  What's this?
 :hammer:   :scratch:
Thats his big slot to match the small slot  , no point in having a round hole and slots the motor has to be able to move
Stuart
Offline 9fingers
« Reply #369 on: July 30, 2012, 10:53:37 AM »
What Rob needs is a CNC mill to make that hole !  :lol: :lol: :lol:
Bob
Offline Dean W
« Reply #370 on: July 31, 2012, 12:49:23 AM »
Stuart
Not talking about the "slot".  Have a peek at the text...  : )
Dean W.
Shop Projects:
Offline Dean W
« Reply #371 on: July 31, 2012, 12:54:34 AM »
Oh, so it's wicked ju-ju?  I always knew it was a bad thing if grown men played with dollies.  This proves it!
Dean W.
Shop Projects:
lordedmond
« Reply #372 on: July 31, 2012, 02:42:54 AM »
Stuart
nither am I the bumpy bits in the main hole are the result of lengthening the large hole to make a BIG slot to allow movement two big holes with centre offset by say 10mm
Stuart
« Reply #373 on: July 31, 2012, 06:34:34 AM »
Yes, but he SHOULD have milled them away so the edge of the slot was the usual baby-soft chrome-plated wonderfinish...
But, for some reason, Rob chose to not only take the half-baked route, but after his previous work dared to show it in public! Either that, or the Stevenson Curse is finally taking effect...
« Reply #374 on: July 31, 2012, 07:30:28 AM »
I suspect it's an homage to the effect of the cold weather on the Women's Beach Volley Ball
