Author Topic: small lathe big tools  (Read 13136 times)
« on: August 10, 2014, 05:43:22 PM »
Lads
I have been that busy with vids I keep forgetting to post pictures:ouch::ouch:
I have recently been given some lathe tools
http://i261.photobucket.com/albums/ii63/john970s0/cap%20frame/GrabbedFrame12_zps2ef450e0.jpgsmall lathe big tools
They need machining to fit my tool holders
http://i261.photobucket.com/albums/ii63/john970s0/cap%20frame/GrabbedFrame14_zpsbf97d4b8.jpgsmall lathe big tools
The pictures are "grabbed" frames from a hd video
http://i261.photobucket.com/albums/ii63/john970s0/cap%20frame/GrabbedFrame15_zps8bf4270b.jpgsmall lathe big tools
I was also given a 6 inch mag chuck
http://i261.photobucket.com/albums/ii63/john970s0/cap%20frame/GrabbedFrame21_zpsf9775bab.jpgsmall lathe big tools
I had a back plate to modify
http://i261.photobucket.com/albums/ii63/john970s0/cap%20frame/GrabbedFrame23_zps8e37ef37.jpgsmall lathe big tools
http://i261.photobucket.com/albums/ii63/john970s0/cap%20frame/GrabbedFrame24_zpsb52504ff.jpgsmall lathe big tools
All this can be seen on this sundays video
Offline Jonny
Re: small lathe big tools
« Reply #1 on: August 11, 2014, 08:59:46 AM »
Used to turn em down when had an ML7 without QR.
Ok if decent tools like Kennametal, Ceratizit, Iscar and Horne but wouldn't risk it with the cheap imports.
I now use the 250-200 series and only have one holder untouched milled out of 23. Biggest tool in is a 1" RH still ample unless taking 1" off, majority are 20mm high including threading, easy on.
Don't think theres much height difference between the 250-100 and 250-200 series.
Offline Arbalist
« Reply #2 on: August 11, 2014, 11:56:01 AM »
They had half a dozen Harrison M300's where I used to work which they bought a batch of new tools for. The new tools fitted all of the lathes fine except one which must have had a slightly different tool post. They couldn't touch the tools with a standard milling cutter so I took it home and trimmed an eighth of an inch off for them on my mill with a carbide bit. Very tough stuff. If I remember correctly they were Sandvik Coromant tool holders.
« Reply #3 on: August 11, 2014, 05:09:03 PM »
Lads
Did a bit more with the chuck back plate
Made some "pointy studs" to transfer the hole pattern
http://i261.photobucket.com/albums/ii63/john970s0/cap%20frame/GrabbedFrame14s_zpsa4c11b84.jpgsmall lathe big tools
A gentle tap with a soft hammer
 :jaw: :jaw: :jaw: :jaw: :jaw: :jaw:
http://i261.photobucket.com/albums/ii63/john970s0/cap%20frame/GrabbedFrame16s_zps4117b14a.jpgsmall lathe big tools
:yikes::yikes::yikes::yikes::yikes::yikes::yikes:
The marks have been transferred with no maths at all :smile::smile:
http://i261.photobucket.com/albums/ii63/john970s0/cap%20frame/GrabbedFrame17_zps0973fd72.jpgsmall lathe big tools
Lined up with the super accurate eye ball and pointy wiggler
http://i261.photobucket.com/albums/ii63/john970s0/cap%20frame/GrabbedFrame18s_zpsc667a2d6.jpgsmall lathe big tools
http://i261.photobucket.com/albums/ii63/john970s0/cap%20frame/GrabbedFrame19s_zps5981d603.jpgsmall lathe big tools
« Reply #4 on: August 11, 2014, 06:34:09 PM »
good post  :thumbup:
« Reply #5 on: August 11, 2014, 10:08:02 PM »
Sure is! I use transfer punches just about every time I do something in the shop. There's a million uses for them -- particularly when doing stuff with old machinery and equipment. I have a big set of them and I also use them as gauges to test hole sizes -- better than drill bits for that.
Offline Jonny
« Reply #6 on: August 13, 2014, 05:35:00 PM »
Theres an easier way to fit up.
Just pick up from any hole in chuck or whatever, without moving it place backing plate register over and drill through.
Mark datum
Will have to keep removing backing plate to pick off for each subsequent hole then replace to drill.
You don't even need to clamp the chuck down just hold and move in to position, that easy.
Sandvik not the best got rid of all mine bar one tool, there are many of same calibre Iscar, Kennametal, seco etc far better that don't make it almost impossible to find the tips and spare parts required. Mind the others not too far behind.
Used to turn the lathe tools down with Kennametal NSR2020K3 with NR48R tips or just NB4R K68 tips clamped in tool holder. Just found a Sandvik hack sawed down the length to reduce height, theyre softish.
« Reply #7 on: August 13, 2014, 06:47:26 PM »
Good post John , the photos are spot on for being taken from a video  :thumbup: , it will be interesting to see how firm the mag chuck can hold things, should be a handy addition to your tooling.
  Cheers Mick.
Offline mosey
« Reply #8 on: August 14, 2014, 09:23:38 AM »
[/quote]
Love your anvil, John!
Mosey
Offline Jonny
« Reply #9 on: August 14, 2014, 03:53:40 PM »
Keep em coming Johnny, just pointing out another way of doing it for others to follow, nothing more.
« Reply #10 on: August 14, 2014, 06:17:49 PM »
Lads
Managed to finish the back plate with my "left hand":smiley-dancenana::smile::smile:
http://i261.photobucket.com/albums/ii63/john970s0/cap%20frame/GrabbedFrame21_zpsb0851e48.jpgsmall lathe big tools
All the bolts screw in:smiley-eatdrink004::smiley-eatdrink004:
http://i261.photobucket.com/albums/ii63/john970s0/cap%20frame/GrabbedFrame22_zps3ffee54c.jpgsmall lathe big tools
Parted off to length
http://i261.photobucket.com/albums/ii63/john970s0/cap%20frame/GrabbedFrame23_zpsca6e667c.jpgsmall lathe big tools
http://i261.photobucket.com/albums/ii63/john970s0/cap%20frame/GrabbedFrame24_zpsf3306877.jpgsmall lathe big tools
It looks the part
http://i261.photobucket.com/albums/ii63/john970s0/cap%20frame/GrabbedFrame25_zps3009fc62.jpgsmall lathe big tools
No run out at all :drool::drool::drool::drool:
(watch the video)
