Author Topic: Warco VMC mill  (Read 50704 times)
Offline svk
Warco VMC mill
« on: November 13, 2013, 07:19:36 PM »
I have ordered a new milling machine from Warco, it will be shipped tomorrow. My old rf45 is out of the house and it will be nice with a new toy :D
The plan is to fit a DRO on it, but does any of you have this or another version of the mill with DRO and what scale lengts do you have?
I see doubleboost in his fantastic videos have the Chester version, and I guess it is the same mill.
Offline Arbalist
Re: Warco VMC mill
« Reply #1 on: November 14, 2013, 04:48:05 AM »
Yes, the Chester 626 is the same as the Warco VMC. Have a google, there are several threads on the net about these machines. There is also a dedicated 6X26 Yahoo group.
Re: Warco VMC mill
« Reply #2 on: November 14, 2013, 12:02:09 PM »
Just seen a mates 626 with two of the three scales fitted in a 3 axis setup, perhaps the easiest machine to do.
Readout is far better than the budget Allendale and can be halved on the Y axis when set to lathe. Ordered 4pm any length scales and 3 axis for £389 delivered next day tracked within a 1 hour time slot.
http://www.ebay.co.uk/itm/3-axis-digital-readout-for-mill-milling-machine-complete-DRO-kit-/320919811363?pt=UK_Measuring_Tools_Levels&hash=item4ab84fb523#ht_4281wt_904
Look elsewhere you may pay £200 extra for inferior.
Offline kayz1
Re: Warco VMC mill
« Reply #3 on: November 14, 2013, 04:48:05 PM »
I have just got a Chester 626 with table PF and DRO, i with put the ruler on them tomorrow.
 Lyn.
Offline svk
Re: Warco VMC mill
« Reply #4 on: November 14, 2013, 05:10:13 PM »
Thanks :nrocks:
I have the Sinpo DRO system on my 12x36 lathe and I am very happy with it. I will mount the same on me mill.
Need to find a big lump of steel for the riser now..
Offline Arbalist
Re: Warco VMC mill
« Reply #5 on: November 15, 2013, 05:01:14 AM »
 Lyn.
A picture of the installed scales would be helpful if you get a moment. :-)
« Last Edit: November 15, 2013, 04:22:10 PM by Arbalist »
Offline kayz1
Re: Warco VMC mill
« Reply #6 on: November 15, 2013, 03:34:21 PM »
http://i10.photobucket.com/albums/a104/bustupbiker/PA140003.jpgWarco VMC mill
http://i10.photobucket.com/albums/a104/bustupbiker/PA140002.jpgWarco VMC mill
http://i10.photobucket.com/albums/a104/bustupbiker/PA140001.jpgWarco VMC mill
http://i10.photobucket.com/albums/a104/bustupbiker/PA140004.jpgWarco VMC mill
Last one is my mode for the fine feed, Arc euro trade bit of kit and good enough for the bits i do.
Scale across the table is 62cm and it's cover is 66cm.
Below the table ( iny and outy ) Scale 32cm and cover 36cm.
 Hope the pics yurn out.
  Lyn.
Offline Arbalist
Re: Warco VMC mill
« Reply #7 on: November 15, 2013, 04:21:26 PM »
Thanks for the pictures, very helpful!  :thumbup:
Offline svk
Re: Warco VMC mill
« Reply #8 on: November 15, 2013, 05:19:19 PM »
Thanks, you dont have dro on the z-axis?
Offline kayz1
Re: Warco VMC mill
« Reply #9 on: November 15, 2013, 08:00:48 PM »
They do not fit one to the knee ( upy downy ) because they say that they get damaged, so i fitted that little unit to the fine feed.
Offline Arbalist
Re: Warco VMC mill
« Reply #10 on: November 16, 2013, 04:34:25 AM »
I don't have DRO's on my VMC and as a point of interest I never use the fine feed on the quill. I have replaced the handle and fitted a readout for accurate drilling though.
http://i230.photobucket.com/albums/ee286/Arbalist/IMGP1808_zps3bb42979.jpgWarco VMC mill
Offline kayz1
Re: Warco VMC mill
« Reply #11 on: November 16, 2013, 03:41:26 PM »
I must say it looks far better in green than my grotty grey machine..
Re: Warco VMC mill
« Reply #12 on: November 16, 2013, 04:36:32 PM »
This video shows some of the mods on mine
Offline NeoTech
    • Roughedge Hobbyworks
Re: Warco VMC mill
« Reply #13 on: November 16, 2013, 04:38:39 PM »
Been thinking about getting me a secondary milling machine, with a quill - basicly im looking for a drill with light milling capabilites..
Whats the price on the Warco VMC machine - and from where? =)
Offline Arbalist
Offline svk
Re: Warco VMC mill
« Reply #15 on: November 16, 2013, 10:29:13 PM »
Thanks guys.
I ordered the mill directly from Warco, no problem to export. Just contact them directly.
I had a rf45 clone for years and sold it to a friend who will cnc it for his shop.
I surfed around for several weeks and desided to go for the 6x26 after seeing Doubleboost videos
of the mill and what he has done with it.
I think it will suit me well.
Ohh....the horrible wait...the mill is on a truck somewhere..
Offline NeoTech
Re: Warco VMC mill
« Reply #16 on: November 17, 2013, 04:46:43 AM »
Hmm then we wait for a quality review of it then.    :poke:   :thumbup:
Offline Xldevil
Re: Warco VMC mill
« Reply #17 on: November 22, 2013, 09:17:15 AM »
Hello.
My mill is similar to the Warco and I've got the Sino DRO installed.
Here are some pictures:
Cheers,Ralph
Re: Warco VMC mill
« Reply #18 on: November 24, 2013, 05:31:52 PM »
Just a point about the three posters piccies above all take the feed off the threaded depth stop, not a good idea but easy route to take. As we all know threads have tolerances and in turn play then more importantly  the threaded bar is able to move vertically with its own tolerance on top.
Ideally need off the quill its direct which just means making a bored in cylindrical clamp, with required offset.
Old piccy circa 2006 just done a quick job here and bolted to the quill casting with C type scale on left of head set back. Plus can see where I still have the cheap vertical scale mounting block, there was another above on the head to clear the depth stop much needed.
http://pic20.picturetrail.com/VOL15/728921/1252422/392394060.jpg
I haven't got a picky uploaded of the other mill now sold but that like above had the coolant and tap off the quill as well.
Offline Arbalist
Re: Warco VMC mill
« Reply #19 on: November 25, 2013, 02:59:57 AM »
I only ever use the quill movement for drilling holes, plus or minus half a mm is no issue for me.
 I only move the knee for milling, that's what it's designed for.
Offline kayz1
Re: Warco VMC mill
« Reply #20 on: November 25, 2013, 06:53:05 PM »
The threads run through the block and have a nut top and bottom to stop movement, that block is screwed into the quill barrel so the thread has no bearing on the movement of the scale. well that's how the Chester machine is unless i have it wrong.
 Lyn.   PS: i could be wrong but if you look at the pic of my machine it can be seen.
Re: Warco VMC mill
« Reply #21 on: November 26, 2013, 09:22:34 AM »
Same as mine Kayz the nuts have to be free or you cant rotate the screw.
Fine feed is the quill for accuracy, coarse the knee with locking gib strips.
Re: Warco VMC mill
« Reply #22 on: November 28, 2013, 01:15:36 PM »
Hi  svk
                     I had to wait 6 weeks for my Chester 626, it felt like 6 years.
        Good Luck you will enjoy    Cheers David
Offline svk
Re: Warco VMC mill
« Reply #23 on: November 29, 2013, 01:56:21 AM »
The mill should arrive on Wednesday- Thursday says the carrier. The winter conditions on the roads
are horrible at the moment so I hope the truck dont end up in the ditch.
I´ll keep you updated.
Offline Xldevil
Re: Warco VMC mill
« Reply #24 on: December 01, 2013, 05:46:17 AM »
Hello.
So far,my solution is good enough for my needs.
Never had any issues.
