Author Topic: Handy, Meths Burner.......  (Read 20379 times)
« on: August 23, 2013, 05:49:32 PM »
I needed to make a burner, for the Metisse engine.
The adopted Maiwald one wasn't right. Too small in diameter. Flame too close to the hot cap......  :scratch:
I love making odds n ends, out of bits n pieces. Found a stainless steel salt and pepper set. The cap diameter was just right.  :thumbup:
Friction turned a brass disc, base......
http://i110.photobucket.com/albums/n95/Dayjo/Return%20Album/P1030770_zpsa6108dc6.jpgHandy, Meths Burner.......
Silver solder wire, sprung inside the cap. Just enough flux........
http://i110.photobucket.com/albums/n95/Dayjo/Return%20Album/P1030773_zpsc1f63776.jpgHandy, Meths Burner.......
Still glowing. Had an el of a job, unsticking the supporting nails. Bit too much solder.........
http://i110.photobucket.com/albums/n95/Dayjo/Return%20Album/P1030774_zps5219fff7.jpgHandy, Meths Burner.......
Opened the existing hole out to 12mm........
http://i110.photobucket.com/albums/n95/Dayjo/Return%20Album/P1030775_zps7d22379c.jpgHandy, Meths Burner.......
16mm o/d, 10mm bore, bush. More silver solder.........
http://i110.photobucket.com/albums/n95/Dayjo/Return%20Album/P1030777_zpsfe3d9897.jpgHandy, Meths Burner.......
I've got the hang of silver soldering, now. I'm proud of that joint.......
http://i110.photobucket.com/albums/n95/Dayjo/Return%20Album/P1030778_zpsbb80c08f.jpgHandy, Meths Burner.......
Clean up. Drill breather holes, in the r/t........
http://i110.photobucket.com/albums/n95/Dayjo/Return%20Album/P1030781_zps5f08ea83.jpgHandy, Meths Burner.......
6mm bore, adaptor bush. Temporary cotton wick. (I'm out of stove rope)........
http://i110.photobucket.com/albums/n95/Dayjo/Return%20Album/P1030783_zpseaa08869.jpgHandy, Meths Burner.......
The engine ran for 70 mins, on one filling........
http://i110.photobucket.com/albums/n95/Dayjo/Return%20Album/P1030784_zpsd68c1f6c.jpgHandy, Meths Burner.......
And, I've still got one left........
http://i110.photobucket.com/albums/n95/Dayjo/Return%20Album/P1030786_zps70449f54.jpgHandy, Meths Burner.......
Really satisfying, little project.
Thanks for watching!
Re: Handy, Meths Burner.......
« Reply #1 on: August 23, 2013, 09:50:54 PM »
David
That looks like a fine little burner that you have made there. Glad to hear it works a charm as well.  :clap: :clap:
« Last Edit: August 24, 2013, 04:00:36 AM by Stilldrillin »
Offline NeoTech
    • Roughedge Hobbyworks
« Reply #2 on: August 24, 2013, 02:28:41 AM »
Nice...  Looking at your friction turning and then remembering how i do it.. yours looks much much safer..   :doh:
« Reply #3 on: August 24, 2013, 02:57:08 AM »
Nice job... Looks great! What is the yellow parts you are holding the brass disc between - just wood or custom fixture?
« Reply #4 on: August 24, 2013, 03:54:22 AM »
Don.
Thank you!   :beer:
Andreas, Chris.
The two plastic parts were made some time ago, to support some 1.5" dia copper tube, as I machined it...........
Blank plug. To support chuck jaws area. Bush to support tailstock end..........
http://i110.photobucket.com/albums/n95/Dayjo/P7210004.jpgHandy, Meths Burner.......
Plug in place. Tube filled with paper to position bush........
http://i110.photobucket.com/albums/n95/Dayjo/P7210005.jpgHandy, Meths Burner.......
Bush supported by piece of 3/8" ground stock.........
http://i110.photobucket.com/albums/n95/Dayjo/P7210009.jpgHandy, Meths Burner.......
Don't know the name of the plastic. It's a little softer than delrin. But, better than wood. Came from work.........
For yesterday's application, I centre drilled the plug. Then mounted the bush in the chuck.
I must admit. It was more secure than the usual, chuck jaws/ insulation tape, set up. The disc never moved, despite some adventurous .020" passes........   :thumbup:
« Reply #5 on: August 24, 2013, 04:31:12 AM »
Dave SD et al ..
Cute little burner, ....  :bow:  where do you get all these bits of stainless from? Saw some SS containers in Wilkos some time ago, but they had transparent windows in the side ... useless buggers .... Grrrrrrr ...
I have some plastic bar that looks about the same, sort of 'waxy' to feel. [ Not that I make a habit of it  :scratch: .... err,.. very  much ]
It's HDPE, I think it is the same stuff they make underground gas pipes from ...
It did have 'HDPE and other bits' printed along the length, but my oily paws fetched it off ..
Dave BC
« Reply #6 on: August 24, 2013, 06:20:59 AM »
Hi Dave.
Cute!? Thanks!
I get my bits from Wilkinsons, Tesco, Morrisons, etc......
You just have to be looking, when they've got the things which might come in handy...... One day. Mebbe!  :smart:
That's why I've got several stainless containers, of varying sizes. Awaiting a purpose in their lives. Same goes for the 9" dia stockpot, stored in my loft.......  :palm:
You can have the pepper pot, if it's any use to you.  :thumbup:
HDPE. That, rings a bell. And your description matches.
Though I never machined any, at work. Think it was used to make buffer type rings, for inside the rock drilling hammers.
« Reply #7 on: August 24, 2013, 03:28:22 PM »
Not a precision perforated pepper pot perchance ???
Nice offer, but it's better off in your hands I think. I lack your talent for seeing desirable things in somewhat mundane items ... all I would ever see is a pepper pot .... I have about as much imagination as the average house brick ...  :(
Dave BC
P.S.     I think I may have insulted house bricks .... Ah well ...
