Author Topic: Mill drill help  (Read 44339 times)
Offline Trebor
Mill drill help
« on: August 11, 2013, 12:30:51 PM »
I was looking into getting parts for my lathe to enable me to convert for milling. Looking around I've seen a few second hand mill drills Warko was one in good condition, belt drive. Is there any drawbacks getting a drill milling machine as opposed to a milling machine ?
Re: Mill drill help
« Reply #1 on: August 11, 2013, 01:11:27 PM »
Beware of the round column ones. If you need to crank the head up when changing tools to give you more daylight you lose alignment  which can be a real pain
Re: Mill drill help
« Reply #2 on: August 11, 2013, 01:51:41 PM »
Trebor,
I have the Eagle 30 mill drill from Chester...V similar to the Warco offering...
Converted mine to three phase with a vfd..
As awemason pointed out being a round column does have the disadvantage..but....depends on what you are doing...If you are cutting parallel to the X axis then yes...other wise it doesnt matter if you're just fly cutting or summat similar...Not been a problem for me so far and I've had mine for a number of years...Nothing a DTI can sort anyway...
I certainly wouldnt swap it for some of the smaller gear head mills....
Besides....It all depends on your budget....Thats the bottom line....
Do you want an MT2 or MT3 or R8 on the quill.....ooooh nooooo..dont go there... :lol:
Offline ParCan
Re: Mill drill help
« Reply #3 on: August 11, 2013, 02:16:31 PM »
It all really depends what you want to do....
If you mainly want to drill holes but want the facility of a mill for occasional use then any of the lower cost milling machines out there will do more than you need.
Heed the Round Column advice.
I have all but ditched my Pillar Drill, mainly use my AMA16 mill now.
Offline Trebor
Re: Mill drill help
« Reply #4 on: August 11, 2013, 02:27:02 PM »
I see what you mean about the round support for the head  :thumbup: I nearly bid on a Axminster x2 tonight, went to just short of £400 but it had an intermittent stopping fault on it. So still looking !!
Re: Mill drill help
« Reply #5 on: August 11, 2013, 03:01:54 PM »
I'm pretty happy with my Enco Mill Drill, and I have mostly used it for milling, not drilling.
There have been many mods of these machines published over the years to deal with the fact that the head swivels (which is intentional). That doesn't happen a lot of the time, only when you have to raise or lower it MORE than the 6" that the fine feed provides. Usually you don't while milling since end mills are generally about the same length. It's when switching between milling and drilling where you're adding a drill chuck plus drill that you might have to raise the head.
One interesting solution involves attaching a cheap laser level to the head and marking a vertical line opposite on the wall of the shop. Then you line up the laser dot with the line to bring the head into alignment after raising it. There are other solutions, like pinning the rack (normally it swivels with the head) and using a shim or gib, etc.
As said above it all depends on what you have to spend, and how much work you want to do to modify things to suit your own needs. I don't have any plans to get rid of mine, although if someone wanted to trade a Bridgeport for it, in equivalent condition, I wouldn't say no.
Re: Mill drill help
« Reply #6 on: August 11, 2013, 03:21:43 PM »
the head swivels when you have to raise or lower it MORE than the 6" that the fine feed provides. Usually you don't while milling since end mills are generally about the same length. It's when switching between milling and drilling where you're adding a drill chuck plus drill that you might have to raise the head.
I dont use a chuck on mine.....
Better security using a collet chuck and collets be it metric or imperial....and minimises the number of times I have to adjust the height.....
Re: Mill drill help
« Reply #7 on: August 11, 2013, 05:32:29 PM »
There ya go -- another solution. They're really not that bad as mills go. I mean, on a budget.
Offline Trebor
Re: Mill drill help
« Reply #8 on: August 12, 2013, 07:15:44 AM »
Re: Mill drill help
« Reply #9 on: August 12, 2013, 09:16:05 AM »
Wrong approach: What you mean it that you need a bigger shed  :lol: :lol: :lol:
Offline Trebor
Re: Mill drill help
« Reply #10 on: August 12, 2013, 09:41:46 AM »
I would love one like this if it was ok! But I'd be getting divorced soon after I recon  :bugeye:
Offline Pete49
Re: Mill drill help
« Reply #11 on: August 26, 2013, 02:15:48 AM »
And the problem is :scratch: funny how a woman can't fathom the need for a big shed....mine insists on putting her car in mine. Little does she know the cars days are numbered MUHAHAHAHAHAHA
Offline Trebor
Re: Mill drill help
« Reply #12 on: August 26, 2013, 02:27:00 AM »
Mine managed to get a tumble dryer and a freezer in mine when we moved here but another move coming soon and I am ready for it. She's getting a bigger kitchen  :thumbup:
Offline Jonny
Re: Mill drill help
« Reply #13 on: August 28, 2013, 06:33:09 PM »
Love to see my mrs try and get something like that in, sacred ground especially when got other machines under cover outside.
Nowt wrong with round columns just have to make sure you can get all the tool changes in rarely a problem even when using chucks with up to 1/2" dia drills to mt3 collets with small short cutters.
Good accurate machines and very quiet when used to use mine, I keep it as a backup mill. Know what I would rather have of similar price with dovetailed column.
Re: Mill drill help
« Reply #14 on: August 28, 2013, 08:04:16 PM »
I would probably not buy a round column mill now but the location problems are not hard to fix:
http://wktodd.webspace.virginmedia.com/drillmill/page4.html
http://wktodd.webspace.virginmedia.com/drillmill/index.html
Offline markball2
Re: Mill drill help
« Reply #15 on: August 31, 2013, 09:19:36 PM »
Don't ignore the round column mills because of the alignment issues.  I aligned mine a year ago, crank it up/down about every other week & alignment stays the same.  It has more play in the table than "twisting" of the head.
I will admit I did make a minor modification, which keeps it aligned.
« Last Edit: August 31, 2013, 10:12:22 PM by vtsteam »
I haven't always been a nurse..................
Craftsman 12 x 36 lathe
New to me Enco GL-30B Mill/Drill
Re: Mill drill help
« Reply #16 on: August 31, 2013, 09:44:14 PM »
Clever idea Mark but could you size those pictures down a bit please? They are more than double my screen res.
Re: Mill drill help
« Reply #17 on: August 31, 2013, 10:03:13 PM »
(I've resized photos above)
Markball2, thanks for the mill drill mod photos -- that's helpful if I do something similar on mine. Coincidentally we both have Enco mill drills and Craftsman 12" lathes. I do see one difference in my mill -- the pulley cover opens on the opposite side -- it looks like you cut your cover away to clear the upper arm of your guide support post. Did you alter the cover support hinges to get it to open on that side or was it like that when you bought it?
Offline markball2
Re: Mill drill help
« Reply #18 on: November 16, 2013, 03:07:05 PM »
No.  The cover doesn't hinge, it removes by unlatching some clasps & lifting off.
Yes I did have to notch the belt cover.  I was running it without the cover, but the top/front of the cover is a nice place to put my hand when I'm using the mill.  I kinda like my fingers right where they are  :bugeye:
Offline Arbalist
Re: Mill drill help
« Reply #19 on: November 16, 2013, 06:32:18 PM »
I agonised for over six months over which mill to get. My budget was £1000 and included the SX3 and several mill drills. In the end I got the Warco VMC knee mill at £500 over budget but so glad I did. It's very difficult trying to imagine how you're going to use a particular machine but in hindsight I'd used several different knee mills and now know that the other machines would have been frustrating to use.
Re: Mill drill help
« Reply #20 on: November 17, 2013, 05:06:10 AM »
I have a BEHEMONT knee mill (for HMS use). While it is pretty good when I need to shift some real metal, I'm thinking of buying a light mill/drill to complement the big one.
My reasoning:
* Winding up heavy knee to drill is not my favorite thing to do, specially when I'm using small drills or mills.
* I would love to get higher speeds. Knee mill has something like 16 - 600 rpm. Great for big mean cutter, but small scale is bit of a struggle.
* For drilling quill feed would be really nice. I want it long. Even 130 mm feels short.
* I would be fine with round column if it were heavy and stable. Like the machine least 300 kg.
Offline Arbalist
Re: Mill drill help
« Reply #21 on: November 17, 2013, 05:23:24 AM »
 The Warco VMC is only a "small" (440Kg) knee mill Pekka. It has a drill quill for quick and easy drilling and has speeds up to 2540 rpm.
This is the slightly modded head on mine.
http://i230.photobucket.com/albums/ee286/Arbalist/4a7d5782-309b-4353-a2a2-7e203fd7477a_zps9bf21911.jpgMill drill help
Offline NeoTech
    • Roughedge Hobbyworks
Re: Mill drill help
« Reply #22 on: November 17, 2013, 05:45:39 AM »
Pekka, i have exactly the same train of thought. Drilling in the knee mill is a hassle at best. So looking into either a dedicated pillar drill or a cheap quill feed milling machine for light milling. =)
Re: Mill drill help
« Reply #23 on: November 17, 2013, 07:12:45 AM »
Well years ago my drill press had to be sacrificed to generate enough room for my Bridgeport, and since then all my normal drilling is done on that with really no downside. I do have a pillar drill in the wood work shop, really just as otherwise it's a fag going from one to the other to drill a hole. And for really big stuff I have a rarely used radial arm drill in the welding shop. As I say I don't feel the loss of a conventional pillar drill, and could easily fit one in if I did.
Andrew
Re: Mill drill help
« Reply #24 on: November 17, 2013, 12:25:51 PM »
Bridgeport has quill....mine does not. Makes a little difference doesn't it?
