Author Topic: Dividing head  (Read 159096 times)
Re: Dividing head
« Reply #100 on: November 03, 2013, 05:53:28 PM »
 Krv,
plodding along! By multiplying my gear potential by three, I'm also multiplying the gear mounting bits by three! So I'm plodding along! Quit a lot of little bits to go.
All the best, Matthew
Re: Dividing head
« Reply #101 on: November 12, 2013, 10:29:30 AM »
Hi,
I realise from the number of photos that I just uploaded to Botophucket (dyslexia rules!) that I haven't updated in a while. In addition, I've decided to make it  so that I can use three different sets of gears. Two disadvantages,:-
I. I can't drill for a draw bar to enable me to use a Morse taper which could have been useful.
II. I have a lot more little parts to make!
So here it is, starting with the gear carriers.
http://i917.photobucket.com/albums/ad16/mattinker/gear%20carrier/gearcarier1_zpsf08111da.jpgDividing head
The top slide on the lathe still being  set up with the taper (about 20°) it's a good place to start.
http://i917.photobucket.com/albums/ad16/mattinker/gear%20carrier/gearcarier3_zps9a07b89a.jpgDividing head
By turning the end of the 17mmØ down to 14mm and flipping it round, I could then cut the taper in the same direction as it was cut on the inside of the spindle.
http://i917.photobucket.com/albums/ad16/mattinker/gear%20carrier/gearcarier5_zps6f0c15df.jpgDividing head
Cutting the M14 thread. I made four as who knows what gears might turn up in the future!
http://i917.photobucket.com/albums/ad16/mattinker/gear%20carrier/gearcarier6_zps1e00e700.jpgDividing head
Three blanks plus the one that I already  reduced to 14mm.
http://i917.photobucket.com/albums/ad16/mattinker/gear%20carrier/gearcarier7_zps12ed7aa6.jpgDividing head
I set the spindle up in the fixed steady to use it as a mandrel to reduce the ends of the carriers and to drill and tap to M8 for the gear retaining bolt.
http://i917.photobucket.com/albums/ad16/mattinker/gear%20carrier/gearcarier8_zps6dc34467.jpgDividing head
The 12mm carrier test with a plastic gear!
http://i917.photobucket.com/albums/ad16/mattinker/gear%20carrier/gearcarier9_zps4f024aa4.jpgDividing head
With the spindle once again set up in the dividing head, I centred with a centre finder and centre drilled for an M6 thread.
http://i917.photobucket.com/albums/ad16/mattinker/gear%20carrier/gearcarier10_zpsc88706f3.jpgDividing head
Without moving the setup, I drilled all of the carriers 5mm .
http://i917.photobucket.com/albums/ad16/mattinker/gear%20carrier/gearcarier11_zpsbb4a8e63.jpgDividing head
Tapping the spindle M6.
http://i917.photobucket.com/albums/ad16/mattinker/gear%20carrier/gearcarier12_zps2b93ec1b.jpgDividing head
The drive belts arrived today, now I can use that nice precise little three jaw and the power feed again!
http://i917.photobucket.com/albums/ad16/mattinker/gear%20carrier/gearcarier13_zps7d22b3eb.jpgDividing head
In addition, I can use my ER32 collets, handy when shortening and reducing grub screws.
http://i917.photobucket.com/albums/ad16/mattinker/gear%20carrier/gearcarier14_zps595c093e.jpgDividing head
Grubscrew, now there will be two Allen key sizes  on the dividing head.
http://i917.photobucket.com/albums/ad16/mattinker/gear%20carrier/gearcarier15_zps9b906b8b.jpgDividing head
The finished product, just needs deburring. I forgot to take pictures of cutting the keyways. I was nervous, having never cut 3 and 4mm keyways with a 2mm slot drill before, my mill seems enormous with that tiny little end mill in it! No problems encountered!
http://i917.photobucket.com/albums/ad16/mattinker/gear%20carrier/gearcarier16_zps0f1fd411.jpgDividing head
All three of the key-ways are different! This is the Emco one which is four mm wide.
http://i917.photobucket.com/albums/ad16/mattinker/gear%20carrier/gearcarier17_zps9720e9e2.jpgDividing head
Milling the keys to size.
http://i917.photobucket.com/albums/ad16/mattinker/gear%20carrier/gearcarier18_zpsa2adbc7f.jpgDividing head
The three carriers finished with their respective gears and keys.
I may soft solder the keys in place so that they don't get lost.
http://i917.photobucket.com/albums/ad16/mattinker/banjo%20slots/banjoslots1_zpsbf035c2f.jpgDividing head
With the gear carriers done, I can get on with the Banjo. Spot the mistake!
http://i917.photobucket.com/albums/ad16/mattinker/banjo%20slots/banjoslots2_zpsc3cfd458.jpgDividing head
Carving out the slots.
http://i917.photobucket.com/albums/ad16/mattinker/banjo%20slots/banjoslots4_zps7645f35e.jpgDividing head
The set up is flawed, having not tried to cut slots this way before, I hadn't thought about the fact that I was squeezing up on an area that I was removing metal from!
http://i917.photobucket.com/albums/ad16/mattinker/banjo%20slots/banjoslots5_zps1a35baea.jpgDividing head
The Banjo gently started to rise in the vice, no damage, but another reminder about how to set up!
http://i917.photobucket.com/albums/ad16/mattinker/banjo%20slots/banjoslots6_zps18f006cf.jpgDividing head
The slots are finished, Al that the Banjo needs is a clean up and chamfer.
I'll be back later, I'm not even half way through the photos that I've taken!
Re: Dividing head
« Reply #102 on: November 12, 2013, 03:02:41 PM »
Hi,
the next chapter is the plunger assembly.
http://i917.photobucket.com/albums/ad16/mattinker/plunger%20assembly/plungerassembly1_zps1276b602.jpgDividing head
A piece of 25mm cold rolled is reduced to 12mm over a length of 20mm.
http://i917.photobucket.com/albums/ad16/mattinker/plunger%20assembly/plungerassembly2_zpsd02c8694.jpgDividing head
Drilled 6.75mm, tapping size for M8 and tapped  to a depth of 25mm.
http://i917.photobucket.com/albums/ad16/mattinker/plunger%20assembly/plungerassembly3_zps5ffa8334.jpgDividing head
This allows fixing in either slot of the banjo.
http://i917.photobucket.com/albums/ad16/mattinker/plunger%20assembly/plungerassembly4_zpscb83c975.jpgDividing head
The centre is found and a centre hole drilled.
http://i917.photobucket.com/albums/ad16/mattinker/plunger%20assembly/plungerassembly5_zps8682ea6f.jpgDividing head
Pilot drilled.
http://i917.photobucket.com/albums/ad16/mattinker/plunger%20assembly/plungerassembly6_zps9b4c6f39.jpgDividing head
http://i917.photobucket.com/albums/ad16/mattinker/plunger%20assembly/plungerassembly7_zps64cef559.jpgDividing head
Drilled 14mm, tapping size for M16, a flat is milled to allow the plunger to seat ot 90°s to it's support.
http://i917.photobucket.com/albums/ad16/mattinker/plunger%20assembly/plungerassembly8_zps39107c18.jpgDividing head
Tapped M16.
http://i917.photobucket.com/albums/ad16/mattinker/plunger%20assembly/plungerassembly9_zpsf1ff305b.jpgDividing head
A second flat is machined on the other side an the circular portion that had been supporting the end turned off in the lathe.
http://i917.photobucket.com/albums/ad16/mattinker/plunger%20assembly/plungerassembly10_zpsb37e3615.jpgDividing head
In position on the Banjo.
http://i917.photobucket.com/albums/ad16/mattinker/plunger%20assembly/plungerassembly11_zps30fb7db5.jpgDividing head
Plunger body, reduced and threaded M16.
http://i917.photobucket.com/albums/ad16/mattinker/plunger%20assembly/plungerassembly12_zps7dfb0228.jpgDividing head
Shoulder turned at the end of the thread to allow to seat on it's support.
http://i917.photobucket.com/albums/ad16/mattinker/plunger%20assembly/plungerassembly13_zps36ed69ab.jpgDividing head
Drilled through 7mm.
http://i917.photobucket.com/albums/ad16/mattinker/plunger%20assembly/plungerassembly14_zpsd2daf7df.jpgDividing head
Setting up square to correct an error! The flats were not parallel, I was asking too much of my collets.
http://i917.photobucket.com/albums/ad16/mattinker/plunger%20assembly/plungerassembly15_zps61a3e492.jpgDividing head
Re-milling the lower flat.
http://i917.photobucket.com/albums/ad16/mattinker/plunger%20assembly/plungerassembly16_zps314b8cb2.jpgDividing head
I haven't got a 10mm reamer yet, so I used a 10mm Slot Drill to drill the larger diameter in the plunger housing.
http://i917.photobucket.com/albums/ad16/mattinker/plunger%20assembly/plungerassembly17_zps4214c50c.jpgDividing head
http://i917.photobucket.com/albums/ad16/mattinker/plunger%20assembly/plungerassembly18_zpsd087f21b.jpgDividing head
Centre drilling and drilling an annealed ball bearing to make the handle for the plunger.
http://i917.photobucket.com/albums/ad16/mattinker/plunger%20assembly/plungerassembly19_zps5af84c5a.jpgDividing head
Centre drilling a piece of 12mm cold rolled to make the plunger.
http://i917.photobucket.com/albums/ad16/mattinker/plunger%20assembly/plungerassembly20_zps5089d6c6.jpgDividing head
First opperation, reduced to 6mm in diameter and threaded M6 to accept the ball bearing.
http://i917.photobucket.com/albums/ad16/mattinker/plunger%20assembly/plungerassembly21_zps4b3072a6.jpgDividing head
Preparing to reduce the plunger to 7mm and 10mm diameters.
http://i917.photobucket.com/albums/ad16/mattinker/plunger%20assembly/plungerassembly22_zpsadfb0472.jpgDividing head
7mm
http://i917.photobucket.com/albums/ad16/mattinker/plunger%20assembly/plungerassembly23_zps294c0ba2.jpgDividing head
Spring winding, thanks Tom Griffin for your recent video contribution! I ended up making 3 mandrels, the first, 7mm, produced a spring that was nearly twice the mandrel diameter, A 4mm one was well undersized, a 6mm would have been best, but I made a 5mm mandrel as I had some 5mm in stock. I had to open up the coils slightly by hand. I got good results from 6thenths of a mm piano wire.
http://i917.photobucket.com/albums/ad16/mattinker/plunger%20assembly/plungerassembly24_zps071f7897.jpgDividing head
Plunger with it's spring.
http://i917.photobucket.com/albums/ad16/mattinker/plunger%20assembly/plungerassembly26_zps8aca563d.jpgDividing head
Milling the plunger point. I used a 17mmØ mill, which was as rear as I could get to the radius of the gear teeth.
http://i917.photobucket.com/albums/ad16/mattinker/plunger%20assembly/plungerassembly27_zps9a440867.jpgDividing head
The fit is reasonable, especially bearing in mind that the radii change with the diameter of the gears.
http://i917.photobucket.com/albums/ad16/mattinker/plunger%20assembly/plungerassembly28_zps7e527459.jpgDividing head
Plunger assembly nearly finished.
http://i917.photobucket.com/albums/ad16/mattinker/plunger%20assembly/plungerassembly29_zpsb00da5ea.jpgDividing head
Lining up the plunger body to slot the guide.
http://i917.photobucket.com/albums/ad16/mattinker/plunger%20assembly/plungerassembly31_zpsce3ee1aa.jpgDividing head
Slotting the plunger.
http://i917.photobucket.com/albums/ad16/mattinker/plunger%20assembly/plungerassembly32_zpsc16531b9.jpgDividing head
Dialling in the plunder to drill for the pin at right angles to the point.
http://i917.photobucket.com/albums/ad16/mattinker/plunger%20assembly/plungerassembly33_zps9a5fecd3.jpgDividing head
Centre drilling the plunger.
http://i917.photobucket.com/albums/ad16/mattinker/plunger%20assembly/plungerassembly34_zpsde0f81ea.jpgDividing head
Drilling plunger, 2.5mm.
http://i917.photobucket.com/albums/ad16/mattinker/plunger%20assembly/plungerassembly35_zps00f556f9.jpgDividing head
In place on the lathe.
http://i917.photobucket.com/albums/ad16/mattinker/plunger%20assembly/plungerassembly36_zps32154a29.jpgDividing head
http://i917.photobucket.com/albums/ad16/mattinker/plunger%20assembly/plungerassembly37_zps4a8bd199.jpgDividing head
http://i917.photobucket.com/albums/ad16/mattinker/plunger%20assembly/plungerassembly38_zps5d9a0779.jpgDividing head
Drilling the spindle.
http://i917.photobucket.com/albums/ad16/mattinker/plunger%20assembly/plungerassembly39_zps21cfbe8f.jpgDividing head
Final drilling.
http://i917.photobucket.com/albums/ad16/mattinker/plunger%20assembly/plungerassembly40_zpsee684db8.jpgDividing head
The chuck in place, one of those nice moments!
Nearly finished! To be continued.
Re: Dividing head
« Reply #103 on: November 12, 2013, 03:23:40 PM »
Very nice
Well documented and photographed
Re: Dividing head
« Reply #104 on: November 12, 2013, 04:17:39 PM »
Very nice
Thanks John,
I wasn't sure whether or not I'm putting too much detail in!
Re: Dividing head
« Reply #105 on: November 12, 2013, 04:31:43 PM »
I did 10 hours of video lol
 :doh: :doh: :doh: :doh: :doh: :doh: :doh: :doh:
Re: Dividing head
« Reply #106 on: November 12, 2013, 04:43:58 PM »
Point taken!
Offline stvy
Re: Dividing head
« Reply #107 on: November 13, 2013, 06:30:34 AM »
Hi,
I'm enjoying the build log. For me as a beginner the extra detail and pictures are helpful. Many thanks.
Re: Dividing head
« Reply #108 on: November 13, 2013, 01:54:17 PM »
Hi,
Thanks Steve,
feedback is useful and nice! I'm glad it's helpfull.
Offline kayz1
Re: Dividing head
« Reply #109 on: November 13, 2013, 03:20:13 PM »
  Steve said  (  I'm enjoying the build log. For me as a beginner the extra detail and pictures are helpful. Many thanks)
  Same goes here.. many thanks..   Lyn.
Re: Dividing head
« Reply #110 on: November 13, 2013, 03:52:24 PM »
I enjoyed watching your build thanks for taking us along!  :beer:
Re: Dividing head
« Reply #111 on: November 13, 2013, 04:31:01 PM »
hi and well dun all you need to do gnaw is send me that one as its you prototype and mack one for your self  :) :)
Re: Dividing head
« Reply #112 on: November 13, 2013, 05:06:38 PM »
Bob nice try,  or is he done a gear from the feed shaft would give a 4th axis   :D
Offline Fredbare
  • Fakenham, Norfolk
Re: Dividing head
« Reply #113 on: November 13, 2013, 05:48:23 PM »
The amount of detail was fine by me, as a beginner, thanks for taking the time and trouble to share, enjoyed it immensely.
Re: Dividing head
« Reply #114 on: November 13, 2013, 06:35:19 PM »
Hi Tom,
it's not quit finished yet, for the moment, I can only do direct indexing from single gears! A few more bits to make!
Re: Dividing head
« Reply #115 on: November 13, 2013, 06:36:53 PM »
glad you enjoyed, thanks for your comment!
Re: Dividing head
« Reply #116 on: November 13, 2013, 06:38:29 PM »
Lyn,
thanks for your comment, back soon!
Re: Dividing head
« Reply #117 on: November 13, 2013, 06:41:01 PM »
Bob,
maybe I'm going to have to make you a casting, that way, you could show me how you'd do it differently!
Glad to see you back!
Regards, mùatthew
Offline svk
Re: Dividing head
« Reply #118 on: November 13, 2013, 07:05:09 PM »
Well done, I have learnd alot from this thread, the DH is on the endless long todo list :D
Nice with all the detail photos, me like :headbang:
Re: Dividing head
« Reply #119 on: November 13, 2013, 07:34:43 PM »
svk,
thanks svk, I'm glad it was usefull!
Offline nel2lar
Re: Dividing head
« Reply #120 on: November 13, 2013, 10:54:42 PM »
Matthew
I enjoyed your build, and I like how you kept to the drawings, Very nice, you will be able to use it for years.
Nelson Collar
Re: Dividing head
« Reply #121 on: November 14, 2013, 02:59:47 AM »
Thanks Nelson,
I've learnt a lot on this build and I'm going to end up with a useful tool into the bargain!
Re: Dividing head
« Reply #122 on: November 14, 2013, 05:00:53 AM »
Hi Matthew
                Your presentation has the correct ratio of pictures to text, the content was clear and interesting and I have picked up some tips on the way.  Producing these posts involves many hours, and this has resulted in a great read. Look forward to the final result.
                                   Well Done
                                                           David
Re: Dividing head
« Reply #123 on: November 14, 2013, 11:24:14 AM »
Thanks David,
I'm glad that I'm apparently not over doing the photos, it's hard to tell when one is working on something.
I find doing the build posts stimulating, it makes me think about the project differently!
Offline northumbrian
Re: Dividing head
« Reply #124 on: November 16, 2013, 04:50:27 PM »
Just finished reading this, excellent job, really enjoyed it :)
