Author Topic: Another ER25 lathe chuck  (Read 12121 times)
Offline modeldozer
  • Valencia, Spain
    • AJ´s Truckmodeling
« on: April 28, 2013, 06:46:34 AM »
Hi all modders,
My next project was more an exercise to test my skills and the capability of my lathe.  The First step was turning an exact replica of the register on the lathe spindle.
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/ER25Chuck/DSCN1884.jpgAnother ER25 lathe chuck
Facing and turning the female register in a 80mm dia. lump of steel.
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/ER25Chuck/DSCN1885.jpgAnother ER25 lathe chuck
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/ER25Chuck/DSCN1886a.jpgAnother ER25 lathe chuck
 Testing the fit with the replica.
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/ER25Chuck/DSCN1886b.jpgAnother ER25 lathe chuck
The lathe chuck was then removed without disturbing the work and put on the mill for drilling and tapping of the mounting holes.
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/ER25Chuck/DSCN1888.jpgAnother ER25 lathe chuck
The new chuck was then bolted to the spindle, still mounted in the other chuck for in case adjustments were needed.
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/ER25Chuck/DSCN1890.jpgAnother ER25 lathe chuck
The slow process of turning down the front was done.
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/ER25Chuck/DSCN1891.jpgAnother ER25 lathe chuck
The thread section turned down with a relief groove at the end.
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/ER25Chuck/DSCN1894.jpgAnother ER25 lathe chuck
The finished thread.
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/ER25Chuck/DSCN1897.jpgAnother ER25 lathe chuck
The compound was then set to 8 deg. And the inside turned.  When it was close to size it was tested with mechanics blue on a collet with an end mill in it to keep it open.
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/ER25Chuck/DSCN1901.jpgAnother ER25 lathe chuck
Turned out the angle was spot on and was finished to the correct depth.
A piece of bar was mounted and the run out tested, it was less than 0.01mm.
(Dial gauge was not zeroed)
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/ER25Chuck/DSCN1902.jpgAnother ER25 lathe chuck
The chuck was marked for orientation when refitting.
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/ER25Chuck/DSCN1904.jpgAnother ER25 lathe chuck
It was setup in the mill to drill a hole for a tommy bar.
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/ER25Chuck/DSCN1905.jpgAnother ER25 lathe chuck
And all finished.  I was quite happy with the result, and will be using it for my next project.
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/ER25Chuck/DSCN1914.jpgAnother ER25 lathe chuck
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/ER25Chuck/DSCN1910a.jpgAnother ER25 lathe chuck
http://i519.photobucket.com/albums/u356/dozerd10/Workshop/Projects/ER25Chuck/DSCN1912.jpgAnother ER25 lathe chuck
Cheers :beer:
Abraham
Re: Another ER25 lathe chuck
« Reply #1 on: April 28, 2013, 07:29:52 AM »
 :clap: :clap: :clap: :clap: Very nicely done Abraham  :thumbup:
Well documented post showing good setups and methods  :dremel: ,Its much more satisfying making ones own tooling  :med:
« Reply #2 on: April 28, 2013, 07:50:31 AM »
Nice
Well shown you will get years of use from that  :thumbup: :thumbup: :thumbup:
I do like your edge finder  :) :) :) :) :)
Offline modeldozer
  • Valencia, Spain
« Reply #3 on: April 28, 2013, 09:18:53 AM »
Rob and John,
Thanks for the kind comments.  Hopefully I will soon have the tools on my list made and go back to some serious model building.  Edge finder curtesy of one of your videos John.
Abraham
« Reply #4 on: April 28, 2013, 10:36:05 AM »
Nicely done. Love homemade tools.
I plan to make one this summer.
