Author Topic: Gonna Do's.........  (Read 104096 times)
Gonna Do's.........
« on: September 14, 2012, 03:44:30 PM »
I have a Pal. Lives in Scotland..... One of several "Apprentices", I have gathered, over the years.......   :)
I reckon he'd make a decent Turner. If only we could understand what we were saying to each other, during our weekly phone-ins!  :lol: :lol:
He can't quite get a gentle enough feel, from the "big handle, on the front".......  :(
He wants a leadscrew handwheel. How to do it?  :scratch:
Tell yer what..... Our lathes are the same. I'll do one for me!  :thumbup:
We have the same backlash nut, on the r/h end.........
http://i110.photobucket.com/albums/n95/Dayjo/After%202012/P1020826.jpgGonna Do's.........
Take off the drive gear, key, and spacer from the other end. Then undo the r/hand plummer block.
And, it will slide out........
http://i110.photobucket.com/albums/n95/Dayjo/After%202012/P1020828.jpgGonna Do's.........
Take off the nut and plummer block, and saw off the 8mm tail. Mount in the fixed steady, and clean up face.......
http://i110.photobucket.com/albums/n95/Dayjo/After%202012/P1020829.jpgGonna Do's.........
Double (or treble) drill to 8mm dia x 1 1/2" deep........
http://i110.photobucket.com/albums/n95/Dayjo/After%202012/P1020830.jpgGonna Do's.........
8mm silver steel shaft, set in to full depth.
Position 3.5" dia handwheel, to clear fingers. Measure spacer length, and overall shaft length + locknut & washer......
http://i110.photobucket.com/albums/n95/Dayjo/After%202012/P1020831.jpgGonna Do's.........
Mock up. To see if all lengths are correct.....
http://i110.photobucket.com/albums/n95/Dayjo/After%202012/P1020845.jpgGonna Do's.........
Loctite shaft into leadscrew, and assemble........
http://i110.photobucket.com/albums/n95/Dayjo/After%202012/P1020848.jpgGonna Do's.........
I don't like the idea of a fixed handwheel handle, in this situation. So, this one will reside in the machine tray, until needed.
Haven't used it, yet. Not sure I ever will need it.
But if this helps someone........  :thumbup:
I've finally got around, to several gonna do's this year, and not shown 'em. Mostly mini mill tweaks.
To follow, as and when......
Re: Gonna Do's.........
« Reply #1 on: September 14, 2012, 04:42:55 PM »
Nice fix Dave
 :thumbup: :thumbup: :thumbup:
Offline AussieJimG
« Reply #2 on: September 15, 2012, 06:23:01 AM »
Good one David, and nice photos as well.
Jim
« Reply #3 on: September 15, 2012, 07:41:13 AM »
Good bit of modding David  :clap: :clap: :clap:
Rob  :thumbup:
« Reply #4 on: September 15, 2012, 07:48:14 AM »
Nice done  :beer:
« Reply #5 on: September 15, 2012, 12:59:45 PM »
Stew, Jim, Rob, Benni...... Thanks for your kind words!   :beer:
Talking about words...... Looks like I will have to eat mine!
Managed 10 mins this afternoon, for a quick play.  :thumbup:
The mini lathe power feed is much too coarse. But, this gives a fabulous fine controlled feed!  :bugeye:
Thanks for the initial idea Mike!  :beer:
« Reply #6 on: September 15, 2012, 04:17:12 PM »
Nice job, David. I found after fitting my handwheel that the power "fine" feed was only used occasionally.
Mine has a dial on it, which helps on things like wanting to turn down stock for a given distance before (for example) threading it. Wouldn't be hard to fit a zero-able dial to yours, if the outer end of the spacer was reduced in diameter to allow a dial and an O ring for friction to fit between the resulting shoulder and the handwheel boss.
« Reply #7 on: September 15, 2012, 05:47:51 PM »
Thanks for your thoughts Andy.  :beer:
Will have to see how things develop. I certainly like the dial/ O ring idea.  :thumbup:
One turn is .059", for roughing purposes.
I regularly use my "tyre gauge" digital read out, for more accurate measurements.
« Reply #8 on: September 15, 2012, 08:27:58 PM »
Thanks for the reminder about tyre gauges, David. I bu33ered mine up while trying to mod it. Time to get another, and treat it more kindly!
Offline stirling lad
  • Stirling Scotland
« Reply #9 on: September 15, 2012, 10:08:50 PM »
Thanks for the 'how to' guide David, its much easier to follow without the hovis accent :poke: :thumbup:
I jest of course,, its the very next on my list... :drool:
I had a feeling you'd approve once you'd fitted it,, what with all the strange wee jobs you have to do to fix them orphans.
BUT, if it starts gathering dust then you could always banish it into exile up here in jocksville....hoots mon!!!
  ..Mike...
« Reply #10 on: September 16, 2012, 08:59:50 AM »
Hi Andy.
I just couldn't be without my mini dro. It's one of those widgets which you make as a novelty...... Then realise it's true worth!  :thumbup:
Just had another 10 mins making random swarf. It's a much better feed arrangement than the two modes which I've used over the last 8 years!  :bang:
I've now removed the 80t drive gear........  :)
Hi Mike.
Hovis accent? Hmmm.......  :bugeye:
I'm a little further south, than De Dar Land........  :lol:
Happy memories of Tony Capstick. Now, no longer with us......  :(
Right then. On with the next one.....
Back in springtime, someone mentioned, using a plastic spacer to position taper roller bearings, was not right.........
Makes sense!  :thumbup:
So, a swift text, to the long suffering Dave, who still works where I used to...... And 24 hrs later, a nice sized piece of EN something, roughed out bar, arrived.
Thanks Mate! Yer a gem.....  :wave:
Topped it to same dia as the inner race.
Then reduced the rest of the dia to clear the 32 tooth, oversize belt pulley.......
http://i110.photobucket.com/albums/n95/Dayjo/After%202012/P1020468.jpgGonna Do's.........
Bored, to give a nice sliding fit on spindle........
http://i110.photobucket.com/albums/n95/Dayjo/After%202012/P1020465.jpgGonna Do's.........
Then sawed off.........
http://i110.photobucket.com/albums/n95/Dayjo/After%202012/P1020469.jpgGonna Do's.........
Set up as true as..... And faced to finish oal.
Keyway clearance.......
http://i110.photobucket.com/albums/n95/Dayjo/After%202012/P1020470.jpgGonna Do's.........
Looks a little better, I think.......
http://i110.photobucket.com/albums/n95/Dayjo/After%202012/P1020471.jpgGonna Do's.........
Just, enough room for the belt.......
http://i110.photobucket.com/albums/n95/Dayjo/After%202012/P1020473.jpgGonna Do's.........
A definite improvement.
http://i110.photobucket.com/albums/n95/Dayjo/After%202012/P1020474-1.jpgGonna Do's.........
When setting up the bearing preload. I wind in the locknuts, until any bearing movement has gone. (Checking with 5/8" bar held in chuck jaws),
I then lock the two nuts against each other. Which usually gives a little clearance.
If there's no movement. I assume the adjustment to be too tight, (whether it is, or not)......
Slacken back, using only the inner nut. Until movement is felt.
Then tighten, as little as possible at a time, using only the outer (l/h) nut.
I find, on a cold m/c, when set correctly. There is some spindle bearing drag, when hand rotated, in the neutral position.
But, after a few seconds of motor rotation, the spindle will rotate freely, by hand. With no bearing movement, even when warm. (It never gets hot)......
The offcut?  :scratch:
That was made into another spacer, and sent up to Scotland......  :)
« Last Edit: September 16, 2012, 09:24:25 AM by Stilldrillin »
  • Stirling Scotland
« Reply #11 on: September 16, 2012, 10:37:45 AM »
and its working a treat up here,,thanks David your a star...and chatter is almost eliminated now.
 I honestly did'nt think it would make much difference but it really has, any chatter i get is coming from other,
not so well fitting parts..but with the help and advice i get from your good self, they parts will be fixed too  :thumbup:
thanks mate..
 ...mike...
« Reply #12 on: September 16, 2012, 10:44:54 AM »
 ...mike...
TWO components. Separated by miles an miles. Both working well!!  :bugeye:
I must be improving, at last.......   :)
  • Stirling Scotland
« Reply #13 on: September 16, 2012, 05:35:19 PM »
 Can i back track a little and ask what the brass bit is on the lefthand side of the plummer block on your lead screw mod?(second photo) as mine just has a fully threaded 8mm rod going through the block to the nut on the r/h side ..:scratch:
..Mike..
« Reply #14 on: September 17, 2012, 03:44:13 AM »
Hi Mike.
That was my first mod!  :smart:
I seem to remember, the leadscrew was machined short, between it's thrust face, and the location of the 80t drive gear.  :bang:
So, I faced up the very rough machined, end of the leadscrew, and added a brass thrust/ spacer washer. Moving the leadscrew some 3mm to the left........ :thumbup:
"fully threaded 8mm rod going through the block"...... As in, studding?   :scratch:
  • Stirling Scotland
« Reply #15 on: September 17, 2012, 12:33:26 PM »
 :doh: David, its not often i'm right but i'm wrong again...I double checked under the plummer block and its just the same as yours after all :loco:8mm  threaded on the r/h last 1/4inch......sorry....
thanks for explaining about the brass thingy..now i can get on with following your instructions without worrying about differences...cheers..
  ...mike....
« Reply #16 on: September 17, 2012, 05:38:08 PM »
Now for some mini mill mods.......
First off, I really don't like the silly spring saucer, which holds the column.
The column is hollow, and most of the applied pressure is trying to collapse the void........
http://i110.photobucket.com/albums/n95/Dayjo/After%202012/P1020367.jpgGonna Do's.........
It needs something more rigid, to span the width of the column.
So, once again, I texted Dave.   :poke:
And this 4" x 4" x 5/8" piece of plate was delivered, within 24hrs........
http://i110.photobucket.com/albums/n95/Dayjo/After%202012/P1020369.jpgGonna Do's.........
As requested, he'd surface ground one side.........
http://i110.photobucket.com/albums/n95/Dayjo/After%202012/P1020368.jpgGonna Do's.........
The 2mm offset hole, was drilled and bored to a sliding fit over the 24mm(?) dia thread.......
http://i110.photobucket.com/albums/n95/Dayjo/After%202012/P1020373.jpgGonna Do's.........
Much more contact area, than the original.......
http://i110.photobucket.com/albums/n95/Dayjo/After%202012/P1020374.jpgGonna Do's.........
Slid on with a satisfying plop, when the two ground surfaces came together.......
http://i110.photobucket.com/albums/n95/Dayjo/After%202012/P1020376.jpgGonna Do's.........
A lot of people seem to have used many, more complicated methods.
But, the little machine is rigid enough for it's purpose. Also, nothing has moved in the 9 months since I installed it.....  :thumbup:
« Reply #17 on: September 20, 2012, 04:31:38 AM »
I have one of these 4", lo-cost, tilting rotary tables.
After the usual strip and re assembly, it does it's job quite nicely.  :thumbup:
http://i110.photobucket.com/albums/n95/Dayjo/After%202012/P1020833.jpgGonna Do's.........
But, I miss the ability, just to bolt it on. Having to clock up...... Even for the "inaccurate" jobs....
The 2 bolt holes are some distance away from the centre line...... Time to sort it out!
Mock up........
Angle plate clocked true to Y axis.
R/t set accurately, at 90*.
Baseplate horizontal, in X & Y axes.
Still plenty of head room.......
http://i110.photobucket.com/albums/n95/Dayjo/After%202012/P1020290.jpgGonna Do's.........
"Willy Wobbler", each side of faceplate. Find centre........
http://i110.photobucket.com/albums/n95/Dayjo/After%202012/P1020296.jpgGonna Do's.........
Mill a, (genuine), centre line. Hmmm......
http://i110.photobucket.com/albums/n95/Dayjo/After%202012/P1020298.jpgGonna Do's.........
12mm keyway location's, rather short......
http://i110.photobucket.com/albums/n95/Dayjo/After%202012/P1020307.jpgGonna Do's.........
Extended key length, into central recess.......
http://i110.photobucket.com/albums/n95/Dayjo/After%202012/P1020308.jpgGonna Do's.........
With the key in the way. Can't now use the "central" bolt hole......
Drilled/ counterbored one each side. 35mm spacing........
http://i110.photobucket.com/albums/n95/Dayjo/After%202012/P1020322.jpgGonna Do's.........
That's secure.......
http://i110.photobucket.com/albums/n95/Dayjo/After%202012/P1020323.jpgGonna Do's.........
New rear hole. Further in, to allow more rearward overhang, if necessary.......
http://i110.photobucket.com/albums/n95/Dayjo/After%202012/P1020325.jpgGonna Do's.........
Starting to look like a Swiss cheese.......
http://i110.photobucket.com/albums/n95/Dayjo/After%202012/P1020327.jpgGonna Do's.........
Very pleased with this mod.
Just bolt on, and operate.......  :)
Offline mechman48
« Reply #18 on: September 20, 2012, 05:25:15 PM »
Dave,
Your RT mod has just reminded me that I have one of these tucked away for later use, bought from Chronos/Arc Euro, (usual disc'r) can't recall exactly, anyway it's something I need to do, & the same for the vice ( thats been fitted & trammed in for now so that will have to wait 'till as & when I move it). I'll have to write up my t'duit list   :dremel: as I'm sure to have forgotton something.
Nice mod anyhow & thanks for reminding me so to speak.
cheers
George
George.
« Reply #19 on: September 20, 2012, 05:36:08 PM »
Thanks for your comments George!
The vice is also done...... And will be shown, in a coupla days, or so........   :thumbup:
« Reply #20 on: September 20, 2012, 09:45:21 PM »
Hi David,
Some nice mods there!
« Reply #21 on: September 21, 2012, 01:55:42 AM »
Nice mod Dave  :thumbup: :thumbup: :thumbup: :thumbup:
Whats next  :whip: :whip: :whip:
 :D
Offline AndreasL
« Reply #22 on: September 21, 2012, 04:57:56 AM »
One more here with the same thing on the list for...to long to remember.
Good reminder this!  :thumbup:
Q: No need to have a second key at the other side of the center hole for even more stability? Or would that only make it hard to mount?
« Reply #23 on: September 21, 2012, 06:48:33 AM »
Thanks Eric!  :beer:
Andreas.
I've found it is plenty good enough, with the present key under the chuck area. Giving a little wriggle room, for more accurate set ups, if necessary.
Most of the time, the rear, (l/h) end is hanging over the end of the table. With the single T nut, just in the end of the slot.
Stew.
Here we go........
A pal from me other forum, asked me if I could drill the dummy rivet holes, along and around a traction engine boiler cover.
Should be a nice exercise..... Need a tailstock! ...... And, we were at Harrogate at the time........  :thumbup:
A new tailstock came home with me...... And Good Ol' Dave, received yet another text.......
This arrived some time later.
Nice innit?      Dave's a grinder, by trade.........
 http://i110.photobucket.com/albums/n95/Dayjo/After%202012/P1020329.jpgGonna Do's.........
Keyway...... Key.........
http://i110.photobucket.com/albums/n95/Dayjo/After%202012/P1020328.jpgGonna Do's.........
Mock up. Had to machine the screw seat areas, to accommodate washers.........
http://i110.photobucket.com/albums/n95/Dayjo/After%202012/P1020331.jpgGonna Do's.........
The screws had to be M8. So, I loctited in, some 10mm studding. Then drill/ tapped M8, as "helicoils".........
http://i110.photobucket.com/albums/n95/Dayjo/After%202012/P1020333.jpgGonna Do's.........
All assembled, and dowelled together.........
http://i110.photobucket.com/albums/n95/Dayjo/After%202012/P1020339.jpgGonna Do's.........
That's close enough for me.......
http://i110.photobucket.com/albums/n95/Dayjo/After%202012/P1020335.jpgGonna Do's.........
All ready for the boiler rivet project!  :)
But..... He's changed his mind! Not building it, now........   :bugeye:
Sigh........... :bang:  :bang:
« Reply #24 on: September 22, 2012, 04:27:42 AM »
And...... The next one.
Staying with the "just, bolt on", theme........ Vice key........
It's been done before. This is my version, for my quirky vice.
Gripped my two table stops, at the extremes of the vice jaws........
http://i110.photobucket.com/albums/n95/Dayjo/After%202012/P1020818_zps8fa64ab4.jpgGonna Do's.........
Can't machine a keyway between the screw slots, cos of the screw heads. The T slot spacing is 35mm.
Table stops located in the T slot. Clamp down.
12mm. keyway. M4 tapped holes.........
http://i110.photobucket.com/albums/n95/Dayjo/After%202012/P1020815_zps80b48010.jpgGonna Do's.........
Full length, 4" key. Just add two c/ sunk screws......
http://i110.photobucket.com/albums/n95/Dayjo/After%202012/P1020819_zps6c533e60.jpgGonna Do's.........
Snug fit in the T slot........
http://i110.photobucket.com/albums/n95/Dayjo/After%202012/P1020822_zps598ea628.jpgGonna Do's.........
Within half a thou'. Repeatable...........
http://i110.photobucket.com/albums/n95/Dayjo/After%202012/P1020825_zps3cb32e58.jpgGonna Do's.........
I'm a bit pleased with that.......  :thumbup:
