Author Topic: Gonna Do's.........  (Read 104098 times)
Re: Gonna Do's.........
« Reply #50 on: November 13, 2012, 05:53:39 PM »
Hi Peter.
That's a fine protector pad. Much more decorative than mine!   :clap:
The studs are the 28mm long ones, originally supplied with the machine. Tightened against the plain portion, using a couple of nuts locked together.
They have never come loose, unless I needed to swap them to another chuck........  :thumbup:
Offline stirling lad
  • Stirling Scotland
« Reply #51 on: November 13, 2012, 08:32:45 PM »
David ,,  Cack handed  yes, I think that ones used up and down the country, but then it would'nt be the first time i was wrong :doh:
I think my studs are all like Peters ,, threaded  all the way...
  ...Mike...
« Reply #52 on: November 14, 2012, 05:42:02 AM »
I've used the same square of 18mm chipboard for the last 15 years as a chuck board - soaked in oil and battered at the corners it sits patiently propped up against the headstock end of the lathe waiting for the next (quite infrequent) chuck change !
« Reply #53 on: November 14, 2012, 08:21:44 AM »
Hi Andrew.
Yes! Keep remembering Sod's law, and always store it where you can immediately find it.  :thumbup:
For anyone who might be contemplating longer chuck nuts.
My machine's gap is 14mm wide. (Taper rollers)...... Shakedown trials have shown, 12mm long nuts are easier to maneuver.......
« Reply #54 on: November 24, 2012, 09:32:52 AM »
Some while ago, I bought this tapping chuck from RDG, for around £17........
http://i110.photobucket.com/albums/n95/Dayjo/After%202012/P1030040.jpgGonna Do's.........
What a waste! The thing is rather large for a mini lathe. And the useless chuck won't grip the hard/ smooth tap shank.  :bang:
Last Thursday's fleamarket yielded one these, for £4.......
http://i110.photobucket.com/albums/n95/Dayjo/After%202012/P1030043.jpgGonna Do's.........
Removed  the plug, indent ball and spring. Then loctited in, a length of M8 studding.
Turned down to 6mm, or so........
http://i110.photobucket.com/albums/n95/Dayjo/After%202012/P1030044.jpgGonna Do's.........
A piece of  45mm dia x 1" plastic. 8mm cross hole. Piece of 8mm o/d alloy tube, (from a wind chime)........
http://i110.photobucket.com/albums/n95/Dayjo/After%202012/P1030046.jpgGonna Do's.........
Hold gently, in tailstock chuck. Grip the handle for drive.
Not tried it out yet.........
http://i110.photobucket.com/albums/n95/Dayjo/After%202012/P1030049.jpgGonna Do's.........
Any extra torque needed, a 6mm tommy bar will fit through the alloy tube.
That's summat else sorted! :thumbup:
  • Stirling Scotland
« Reply #55 on: November 25, 2012, 10:00:48 AM »
 :clap: :clap:
very clever David,
I'd love to visit your local flea market :drool:
My local one is only good for fleas :(
  ...Mike...
« Reply #56 on: November 26, 2012, 03:17:14 PM »
Hi David
                A cool idea and can be made in various sizes, can't beat hand feel when power tapping.
                                       David
« Reply #57 on: December 08, 2012, 06:11:05 AM »
Mike, David. Thanks!
I've now used it for the first time. Very easily managed M6 in mild steel, tapping this next little job.
I have a 6" bench grinder. The wheels are too hard, don't cut. And when they do, there's grit over the very limited bench space, and car........
So, when I really need a grinding session, I set up in the middle of the back lawn. So there's no rusty patch left behind on me driveway.
I have been using a 50mm dia diamond disc in the lathe chuck, for the past few years for tool/ drill sharpening. It does the job admirably!
Occasionally though, a little more roughing power is needed..........
I bought a couple of sets of angle grinder disc nuts, and mounted them on stub arbours.........
http://i110.photobucket.com/albums/n95/Dayjo/After%202012/P1030062.jpgGonna Do's.........
Didn't bother with the M14 thread, just a slide on fit, and an M6 screw and heavy washer.......
http://i110.photobucket.com/albums/n95/Dayjo/After%202012/P1030063.jpgGonna Do's.........
Slips into the chuck........
http://i110.photobucket.com/albums/n95/Dayjo/After%202012/P1030055.jpgGonna Do's.........
Diamond rougher disc.......
http://i110.photobucket.com/albums/n95/Dayjo/After%202012/P1030054.jpgGonna Do's.........
Not quite so rough, diamond disc........
http://i110.photobucket.com/albums/n95/Dayjo/After%202012/P1030056.jpgGonna Do's.........
Old faithful, finisher..........
http://i110.photobucket.com/albums/n95/Dayjo/After%202012/P1030057.jpgGonna Do's.........
Works for me!  :thumbup:
« Reply #58 on: December 11, 2012, 10:35:36 AM »
And, finally.
A 110mm disc of mdf, backing an al oxide polishing disc.......
http://i110.photobucket.com/albums/n95/Dayjo/After%202012/P1030070.jpgGonna Do's.........
Good for woodworking.  :thumbup:
Had around 180 hits, since I posted this last gonna do, and no comments....... Guess it's run it's course.
I'll see if I can't get the Maiwald project finished, and out of the way.
Offline AussieJimG
« Reply #59 on: December 11, 2012, 02:52:36 PM »
Sorry David, I should have posted my thanks for a good idea. I am an avid follower of all your stuff; just don't say much. But I will try to do better in future.
Jim
« Reply #60 on: December 11, 2012, 03:22:02 PM »
Hey Jim!
Don't take it personal..... There's only so many times we can say, well done. (Or otherwise). On one subject......
Thanks for your enthusiastic support.  :thumbup:
Incidentally. I have recently spent some time on Google Images. Looking at pics of hit n miss engines.
Several times, turned up a pic of a familiar character, enjoying a pint!  :beer:
That's a lovely engine you've made, Mate!
« Reply #61 on: December 11, 2012, 03:25:41 PM »
It's not that we aren't interested, David - merely mesmerised by your ingenuity and productivity in making useful devices.
Well done!
« Reply #62 on: December 11, 2012, 04:20:13 PM »
Well done  :clap: :clap:
Offline caskwith
« Reply #63 on: December 12, 2012, 12:05:04 PM »
I'm gonna have to get myself some more diamond wheels and have a go at this. Tried it once using a diamond disc for an angle grinder but it seems to have too much runout. 2nd attempt needed I think. I do have some nice Eze-lap diamond hones that do a lovely job of finishing up the edges though.
« Reply #64 on: December 28, 2012, 04:04:46 AM »
Thanks for your kind comments, Chaps!  :beer:
Here's another one........
Fed up with dropping the gear cover allen screws, into the scrap/ recycle pile.  :bang:
I made a pair of thumbscrews.........
http://i110.photobucket.com/albums/n95/Dayjo/After%202012/P1030078.jpgGonna Do's.........
M5 studding, with washers, and a couple of turned down nuts.......
http://i110.photobucket.com/albums/n95/Dayjo/After%202012/P1030088.jpgGonna Do's.........
The nuts fit inside the spacer tubes......
http://i110.photobucket.com/albums/n95/Dayjo/After%202012/P1030089.jpgGonna Do's.........
Even upside down. They don't fall out........
http://i110.photobucket.com/albums/n95/Dayjo/After%202012/P1030090.jpgGonna Do's.........
Tidy.......
http://i110.photobucket.com/albums/n95/Dayjo/After%202012/P1030087.jpgGonna Do's.........
David D.
« Reply #65 on: December 28, 2012, 04:17:11 AM »
Tidy.......
David D.
Very tidy David  :thumbup:   all those small mods will make life much easier  :med:
  • Stirling Scotland
« Reply #66 on: January 01, 2013, 12:12:11 AM »
over the last few days ive been trying to get some of the little 'gonna do's' done before the year was out.
Santa brought me a exrta handwheel so i got on with following your instructions for the leadscrew handwheel...
I made a bigger spacer but the temporary thinner one worked so well and turned so smoothly that i left it on..
I will get round to 'running in' the thicker one some day..but for now.... Thanks very much for all your help.. :thumbup:
and guidance, :wack: :hammer: :poke:... i know it must be difficult :bang: as we speak in different tongues :drool:  :scratch:
....Mike... :wave:
  http://i1101.photobucket.com/albums/g440/burky123/steadyeddie018.jpgGonna Do's.........
« Reply #67 on: January 01, 2013, 02:29:15 AM »
Thanks Rob!  :beer:
You're right! I'm just wondering where all the dropped M5 caphead screws have gone to, over the years.......  :scratch:
Mike.
Pleased Santa brought what was needed. That set up is looking good!  :thumbup:
Help, and guidance? Different tongues?
Well..... You know me. I like a challenge....... I'll say no more!   :lol:
« Reply #68 on: January 02, 2013, 08:25:03 AM »
Hope I can remember how to do this.
Some time back I figured out that the safest way to cut threads on small jobs,  particularly thos that entail working up to a shoulder,  is to use a handle attached to the mandrel and wind it by hand.
So here (at last) is my hand powered thread cutting attachment.
All I have to do now is get the pics from Photobucket.
Here is the device attached.
http://i437.photobucket.com/albums/qq93/klixon/DSCF0271_zps46e3bb7a.jpgGonna Do's.........
And a couple of close ups. AS you can see,  all it is is a rawl bolt and a bit od steel strip. The only part that needed any machining was the keyed part at the end of the bolt. I filed a groove in the end to the mandrel and filed the bolt end to (more or less) fit.
http://i437.photobucket.com/albums/qq93/klixon/DSCF0275_zpsebbde73c.jpgGonna Do's.........
http://i437.photobucket.com/albums/qq93/klixon/DSCF0276_zps56c10969.jpgGonna Do's.........
Someone remind me how to get pics from PB to this page.
Dave, :(
Andy,  Thanks.  Worked as advertised.
Now I just have to reduce the size a bit.
« Last Edit: January 02, 2013, 11:18:11 AM by DavidA »
« Reply #69 on: January 02, 2013, 09:34:54 AM »
It seems to have changed recently, but the way I do it is to click on the thumbnail pic to see it full size. Then look at the image links on the right; you may have to click "Image Links" to see them. There are four, and it's the one in the bottom box that starts [IMG] that you want. Click inside the box, which should go yellow very briefly and say "Copied". Then come back to the message you are composing here, and Ctrl V paste the link into your text.
Previously, I could hover over any of the thumbnails and a drop-down would appear showing the links. That was a bit easier, but doesn't seem to work any more.
Offline Henning
  • All the kit and no clue!
« Reply #70 on: January 02, 2013, 10:40:43 AM »
I am going to borrow shamelessly steal the thumbscrew idea!
I also have an idea about a hinge, but that may hinder placement later on, so jury still out.
Henning
« Reply #71 on: January 02, 2013, 11:54:58 AM »
A couple more pictures of the same late.
My hi-tech answer to cross slide DRO.  It works surprisingly well.
http://i437.photobucket.com/albums/qq93/klixon/DSCF0272_zpse92434e4.jpgGonna Do's.........
Can you see what the problem is here? And I don't mean all the clutter.
http://i437.photobucket.com/albums/qq93/klixon/DSCF0273_zps1c70c4fa.jpgGonna Do's.........
« Reply #72 on: January 02, 2013, 11:55:31 AM »
You're welcome Henning!  :thumbup:
I post up my ideas. To give others, their ideas........  :)
Wish I'd thought of a Rawlbolt, for my depth stop.........  :Doh:
« Reply #73 on: January 02, 2013, 12:09:40 PM »
Henning, I used hinges on my gear cover as shown here:
The letters refer to some accompanying text on my website, but I sawed up a cheap door hinge and attached the results at E and E, with the other parts attached to the lathe. The hinges are lift-off, and the pin in the lower one is longer than in the upper one, to help me to replace the cover if I have removed it completely. A toggle clip (like the ones on some toolboxes) at F fastens on to a lug on top of the headstock, to hold the cover closed.
 :D It seems I can embed pictures direct from my website without the bother of PhotoBucket.  :D
I didn't know that until I tried it.
Offline mastermaker
« Reply #74 on: January 04, 2013, 05:02:24 PM »
And another Norwegian will swipe the rawl bolt spindle crank idea from DavidA, I've been looking for a simple way of doing this. :clap:
