Author Topic: Rotary Broaching  (Read 37578 times)
Rotary Broaching
« on: October 24, 2011, 12:15:17 PM »
Got this off a news group I belong to. Intersting approach to broaching.
 http://www.slatertools.com/sales-support-service/videos/rotary-broach-and-tool-holder-demostration
Perhaps one of our talented members can build one and do a build log?  :poke:  :clap:
Re: Rotary Broaching
« Reply #1 on: October 24, 2011, 12:31:37 PM »
Hi Bernd
had ago at making  one last year , after seeing that very video  :dremel:
still needs a bit of refinement  :proj:
« Last Edit: October 29, 2011, 12:58:08 PM by Rob.Wilson »
« Reply #2 on: October 24, 2011, 12:51:54 PM »
I watched the video then came back to the post and was going to reply. Then I saw Robs reply. Man that guy is not only good but he is extremely fast. Bet you never figured on anyone doing it quite that quick.
 :D :D
That was quick or was it good timing.  :lol: It will be interesting to see when you are finished with the refinements.
« Reply #3 on: October 24, 2011, 01:10:06 PM »
Hi Don  :lol: :lol: :lol:
Just good timing  :med: ,,,,,, made it last Christmas (i think ) ,,looked and interesting project  ,so  thought i would have an attempt at making one  :dremel:
works ok ,,,,,,, but i screwed up the bearing fit  :doh: so i need to re machine one part .
it still  work in progress
« Last Edit: October 24, 2011, 02:20:28 PM by Rob.Wilson »
« Reply #4 on: October 25, 2011, 06:58:16 AM »
Jeeeeees Rob, I can't post anything new.  :(    :lol:  :lol:  :lol:  :lol:
Nice job. And like Don said, "your fast".
« Reply #5 on: October 25, 2011, 10:47:20 AM »
Don't you just hate that when you see something that you think is new and great. So you rush out to tell the rest of the world only to find out that everyone else already knew about it. It has happened to me a few times too.  :lol: :lol:
« Reply #6 on: October 25, 2011, 11:52:53 AM »
SORRY Bernd  :lol: :lol: :lol:
Its still needs some refinements ,,,,,, was planning on doing a build when it was all sorted ,,,,,, just  :proj: keeps getting in the way  :doh:
Rob  :dremel:
« Reply #7 on: October 25, 2011, 05:21:41 PM »
Ok Rob your forgiven.  :thumbup:
 I know all about that  :proj:. I've got a couple of those going right now.
  • Country: za
« Reply #8 on: October 26, 2011, 03:23:00 PM »
Rob,
That's a nice bit of machining you did. :clap: :clap: :clap:
« Reply #9 on: October 27, 2011, 11:42:44 AM »
Thanks Dave  :beer:
Rob  :D
Offline plunger
« Reply #10 on: October 29, 2011, 03:58:01 AM »
Rob I would really like to make one of these. I hope I can ask a couple of questions without showing how ignorant I am? How do you get the tapered shape on the two main parts. Are you sawing off the shape as close as possible and then filing or grinding to get it to look good or is this done on a rotary table.Are you using two cheap bearings Would a thrust bearing also not maybe work better here as well.How much strain does it put in  a lathe to do a broach. Could this also be used on a milling machine to broach as well.
Have you made any broaches for yourself or are you buying broaches. This would be useful for making the odd tap handle that is obsolete in plumbing so it will only be used for brass.
 would like to try and make my own broaches but I think it may be beyond a home shop ability. Square I can probably handle but I tried to make a 8 mm spline broach with 20 splines and was not successful. Would you have a suggestion as to how a spline broach could be made. Regards Eugene
« Reply #11 on: October 29, 2011, 04:48:58 AM »
Hi there Eugene
No problem , ask away  :med:
I used a R/T for the job ,,,, it can be done by hand just the same  :dremel:
Yes i just used a couple of cheap bearing that i had at hand ,,,,, thrusts would be a much better job , now i no it works i will make a better job of it  :dremel:
Not allot in brass and ally ,,,,,,,,,,,,,,,, the larger the broach the more grunt required  ,, i dig out info on that .
Possibly never thought about it  :med:
Yes i made the broach myself ,,, i used Silver steel / drill rod  , water hardening   ,, worked fine on brass  ,, broke on stainless  :lol:
Just the job  :headbang:
Still thinking on that one  :scratch:
« Reply #12 on: October 29, 2011, 05:08:34 AM »
The doodle i used to make mine
« Reply #13 on: October 29, 2011, 07:44:02 AM »
Very Nice.  Can you elaborate on its function and use, how come you adjust the clamp bolts in 2 axis not one ?
                  Joules
  • Country: za
« Reply #14 on: October 29, 2011, 09:37:42 AM »
Rob,
Show off  :lol: :lol: :lol: :lol: :lol:
Nah - nicely done.
Any chance you can fix your avatar before it induces an epilepsy fit. :D :D :D
« Reply #15 on: October 29, 2011, 12:53:31 PM »
Hi Joules
                  Joules
Did you not watch Bends video  :poke:  ,,,,,,,,,, its for poking odd shaped holes in things  :lol: :lol: :lol:
Ease of manufacture ,,,, other wise you would have to devise some other way of keeping perfect alignment on one axis
Cheers Dave  :beer:
New coil pack on order  :lol: :lol: :lol:
Edit  ,,,,,,, fixed now Dave  :med:
« Reply #16 on: October 29, 2011, 01:39:15 PM »
Hi Rob
Do us all a favour...  :thumbup:
You wouldn't like to consign that lurid hyperactive custard thing to the crap bin would you ??
Find something with a bit of culture eh ???
I presume it is custard???
Aaarghhh .... not pureed canary ??? Oh Nooooooo   ............. blaaaargh
BC
Good job we can turn off avatars   :med:  :med:
« Reply #17 on: October 29, 2011, 01:59:10 PM »
An old saying comes to mind. Be careful what you ask for as you might not get what you expected.  :lol: :lol: :lol:
  • Country: za
« Reply #18 on: October 29, 2011, 02:15:03 PM »
Thanks Rob, :)
Just trying to think who your new avatar reminds me of? :lol:
PS I don't suffer with epilepsy - I just said that to make you feel sorry for me. :D :D :D
« Last Edit: October 29, 2011, 03:29:05 PM by DaveH »
« Reply #19 on: October 30, 2011, 06:18:16 AM »
 :lol: :lol: :lol: :lol: so you not impressed with my new avatar Dave BC   :(
I thought it was just the job  :lol: :lol:
« Reply #20 on: October 30, 2011, 06:42:50 AM »
Personally I think it's a good likeness of Rob.
John S.
« Reply #21 on: October 30, 2011, 09:56:09 AM »
John S.
Since you have pointed that out, I have to agree.
Yet another objectional feature  ... :lol:  :lol:  :lol:   :lol:
BC
Offline AussieJimG
« Reply #22 on: January 12, 2012, 11:56:21 PM »
It is amazing how synchronicity creeps in. The latest Model Engineering Workshop - No 185 has an article on construction of a rotary broach and the tools to use in it. Michael Cox has included all the drawings. If you are interested in rotary broaching, it might be worth a look. :wave:
Jim
« Reply #23 on: January 13, 2012, 03:11:41 AM »
Jim, it's all on his website, too: http://mikesworkshop.weebly.com/rotary-broaching.html
Offline AussieJimG
« Reply #24 on: January 13, 2012, 05:43:49 AM »
Thanks Andy, that site has some really great stuff on it. Mike's mods to his 6x4 bandsaw in particular fixed a whole bunch of things that I should have fixed instead of moaning about them. :doh:
And now Mike has paved the way.
Thanks for pointing me to the site.
Jim
