Author Topic: Big Marine Steam Engine  (Read 163945 times)
Re: Big Marine Steam Engine
« Reply #25 on: July 21, 2011, 01:58:19 AM »
That's going to be some engine John!  :bugeye:
You're putting a lot of good work into it......  :clap: :clap: :thumbup:
« Reply #26 on: July 21, 2011, 01:35:45 PM »
Nice work!
« Reply #27 on: July 22, 2011, 06:33:11 PM »
Had a day off work (so i spent it working in the shop ) :loco: :loco:
Made a start on the con rod , i was going to machine it from soild but decided on a fabricated job
http://i261.photobucket.com/albums/ii63/john970s0/P7210016.jpgBig Marine Steam Engine
http://i261.photobucket.com/albums/ii63/john970s0/P7210017.jpgBig Marine Steam Engine
http://i261.photobucket.com/albums/ii63/john970s0/P7210019.jpgBig Marine Steam Engine
http://i261.photobucket.com/albums/ii63/john970s0/P7210021.jpgBig Marine Steam Engine
Finally a bit of stress relief
http://i261.photobucket.com/albums/ii63/john970s0/P7210031.jpgBig Marine Steam Engine
Shoild get it machined tomorrow
lordedmond
« Reply #28 on: July 23, 2011, 04:07:08 AM »
How will the CI ring wear in the bronze cylinder ?
I have only used CI rings in CI cylinders , I do use 'O' rings in bronze or soft packing
Nice work BTW I am not criticising just asking as I am knocking up a triple expansion engine that uses a bronze block and bronze rings , I an thinking of using CI as i know it will work
Stuart
Offline Mike Cole
  • Wallasey Wirral
« Reply #29 on: July 23, 2011, 03:41:00 PM »
Very nice work, I am very inpressed with the crank. is this engine going in a boat when finished?
Mike
« Reply #30 on: July 23, 2011, 05:07:07 PM »
Stuart
I think the iron rings and piston should work ok
(if anyone has views i would like to hear them)
Mike
It would certainly power a boat but sadly i have no room for one
« Reply #31 on: July 26, 2011, 05:37:07 PM »
Got a bit more done this weekend
Started on the cross head guide
http://i261.photobucket.com/albums/ii63/john970s0/P7260173.jpgBig Marine Steam Engine
http://i261.photobucket.com/albums/ii63/john970s0/P7260175.jpgBig Marine Steam Engine
I had a hell of a job trying to clamp things in to place and then drill and tap them
The weld tacks will be milled off  :D :D :D
http://i261.photobucket.com/albums/ii63/john970s0/P7260180.jpgBig Marine Steam Engine
http://i261.photobucket.com/albums/ii63/john970s0/P7260186.jpgBig Marine Steam Engine
Bolted and dowell pinned
Propper job
« Reply #32 on: July 30, 2011, 05:20:14 PM »
Got a bit more done
All the welds machined off everything debured and cleaned up
The dowel pins make for a nice job
Machined a big lump of bronze in to a cross gead guide
http://i261.photobucket.com/albums/ii63/john970s0/P7300210.jpgBig Marine Steam Engine
http://i261.photobucket.com/albums/ii63/john970s0/P7300214.jpgBig Marine Steam Engine
http://i261.photobucket.com/albums/ii63/john970s0/P7300212.jpgBig Marine Steam Engine
http://i261.photobucket.com/albums/ii63/john970s0/P7300213.jpgBig Marine Steam Engine
« Reply #33 on: August 03, 2011, 05:26:01 PM »
Made a start on the cross head
Starting to get to grips with the rotary table
http://i261.photobucket.com/albums/ii63/john970s0/P8020343.jpgBig Marine Steam Engine
http://i261.photobucket.com/albums/ii63/john970s0/P8030351.jpgBig Marine Steam Engine
That is a 3/4 cutter  :bugeye: :bugeye:
http://i261.photobucket.com/albums/ii63/john970s0/P8030352.jpgBig Marine Steam Engine
« Reply #34 on: August 03, 2011, 05:34:59 PM »
Coming along very nicely. :thumbup: :thumbup: :thumbup:
Nice bit of milling with the rotary table :clap: :clap: :clap:
« Reply #35 on: August 04, 2011, 04:16:20 AM »
Developing very nicely John!  :clap: :clap:
Keep on, keeping on.......  :thumbup:
« Reply #36 on: August 04, 2011, 05:25:19 AM »
nice RT work  :thumbup:
That's going to be one hell of a powerfull engine John, It'll need a big boiler, have you any plans to power something with it ?.
« Reply #37 on: August 04, 2011, 05:44:38 PM »
Rotary tables are a steep learning curve
Pleased with the result though
http://i261.photobucket.com/albums/ii63/john970s0/P8040367.jpgBig Marine Steam Engine
I had a feeling this was inside the other half of this block
The hard bit is getting it out  :doh: :doh:
http://i261.photobucket.com/albums/ii63/john970s0/P8040357.jpgBig Marine Steam Engine
http://i261.photobucket.com/albums/ii63/john970s0/P8040362.jpgBig Marine Steam Engine
http://i261.photobucket.com/albums/ii63/john970s0/P8040359.jpgBig Marine Steam Engine
The rod needs cutting to length some threads and silver solder
A bit of taper turning and some file work
« Reply #38 on: August 07, 2011, 02:52:16 PM »
Finally got the cross head to go up and down
I made up a dummy con rod to get the length right
http://i261.photobucket.com/albums/ii63/john970s0/P8060371.jpgBig Marine Steam Engine
http://i261.photobucket.com/albums/ii63/john970s0/P8060375.jpgBig Marine Steam Engine
http://i261.photobucket.com/albums/ii63/john970s0/P8070383.jpgBig Marine Steam Engine
I could not help running it up in the lathe
CLICK THE PICTURE
http://i261.photobucket.com/albums/ii63/john970s0/P8070379.jpgBig Marine Steam Engine
Offline CallMeAl
« Reply #39 on: August 07, 2011, 05:52:40 PM »
Wow this is going to me massive! Looks great, I like that base casting and bearing caps.  The scale is just right, easy to see all the pieces working. :thumbup:
Al
I skin cats my own way!
« Reply #40 on: August 07, 2011, 06:16:44 PM »
Looks really great, runs even better :clap: :clap: :clap:
What a very nice engine it is going to be. :thumbup: :thumbup: :thumbup:
« Reply #41 on: August 08, 2011, 02:22:23 AM »
        SWEET!!  :thumbup:
Blummin well done John!  :clap: :clap:
« Reply #42 on: August 08, 2011, 05:14:35 AM »
Very nice John, you intending to power the house with this or something?! It's a fair size!  :bow:
« Reply #43 on: August 08, 2011, 05:53:18 PM »
Made a start on the front colums (22 mill stainless round bar)
Drill and tap one end screw cut the other and set to length.
They looked ok but very plane
Rob wilson recond on a taper .
Out with my freshly made drive dog
http://i261.photobucket.com/albums/ii63/john970s0/P8080395.jpgBig Marine Steam Engine
http://i261.photobucket.com/albums/ii63/john970s0/P8080391.jpgBig Marine Steam Engine
http://i261.photobucket.com/albums/ii63/john970s0/P8080389.jpgBig Marine Steam Engine
http://i261.photobucket.com/albums/ii63/john970s0/P8080388.jpgBig Marine Steam Engine
http://i261.photobucket.com/albums/ii63/john970s0/P8080398.jpgBig Marine Steam Engine
The surface finish is astounding (for me )
« Reply #44 on: August 09, 2011, 03:43:21 AM »
They look good John.  :clap: :clap:
(I reckon that Rob Wilson knows a thing or two).  :thumbup:
« Reply #45 on: August 09, 2011, 11:22:20 AM »
Very nice job going on here, I like to see an engine come together with each part dictating what comes next, and the ability to decide on the fly, how to do each little bit.  It makes for a very personal engine, and I have to say, you are going to need a real boiler for that job, when it is finished.   :beer:  Cheers, Mad Jack
« Reply #46 on: August 13, 2011, 05:02:02 PM »
Made a start on the pattern for the bottom cylinder cover
MDF glued together
Needs a bit of filleting and some paint
http://i261.photobucket.com/albums/ii63/john970s0/P8130002.jpgBig Marine Steam Engine
http://i261.photobucket.com/albums/ii63/john970s0/P8130009.jpgBig Marine Steam Engine
http://i261.photobucket.com/albums/ii63/john970s0/P8130008.jpgBig Marine Steam Engine
http://i261.photobucket.com/albums/ii63/john970s0/P8130007.jpgBig Marine Steam Engine
Machining it will be interesting
« Reply #47 on: August 17, 2011, 05:02:09 PM »
Got the pattern finished
Hopefully it will be turned in to bronze this week end :D :D
The wife  reccons it looks like a space invader  (the old arcade game) :doh: :doh: :doh:
http://i261.photobucket.com/albums/ii63/john970s0/P8170017.jpgBig Marine Steam Engine
http://i261.photobucket.com/albums/ii63/john970s0/P8170018.jpgBig Marine Steam Engine
http://i261.photobucket.com/albums/ii63/john970s0/P8170020.jpgBig Marine Steam Engine
http://i261.photobucket.com/albums/ii63/john970s0/P8170021.jpgBig Marine Steam Engine
PatJ
« Reply #48 on: August 17, 2011, 09:24:05 PM »
Looks great John.
You look pretty close to getting it running.
Pat J
Offline CallMeAl
« Reply #49 on: August 17, 2011, 10:03:45 PM »
Nice pattern work.  Look forward to see it in metal.
Al
