Author Topic: BIG Thanks To Bogs aka John Moore!  (Read 27532 times)
Offline bry1975
    • http://www.satintime.co.uk
« on: February 07, 2011, 05:09:58 PM »
Thanks for machining the replacement Tag Heuer Bezel John the watch now looks decent. :thumbup:
http://img141.imageshack.us/img141/2358/tgl.jpgBIG Thanks To Bogs aka John Moore!
http://img714.imageshack.us/img714/1312/tgl2.jpgBIG Thanks To Bogs aka John Moore!
http://img826.imageshack.us/img826/294/tgl3.jpgBIG Thanks To Bogs aka John Moore!
Old knackered bezel:-
http://img560.imageshack.us/img560/4788/tgl4.jpgBIG Thanks To Bogs aka John Moore!
Offline Bogstandard
  • Bogs Group
Re: BIG Thanks To Bogs aka John Moore!
« Reply #1 on: February 07, 2011, 05:42:54 PM »
No problems Bry. I'm glad you are happy with it.
That case looks a lot better than the last time I saw it. Had it been run over by a car? It certainly looked like it.
Location - Crewe, Cheshire
Skype - bandit175
« Reply #2 on: February 07, 2011, 05:59:13 PM »
John, how did you go about maching that part, did you take an pictures? I`m thinking more about how you held it.
Offline j45on
« Reply #3 on: February 07, 2011, 06:17:51 PM »
Nice job  :thumbup: the old one certainly was a mess.
Jason
Offline Bogstandard
  • Bogs Group
« Reply #4 on: February 07, 2011, 06:26:30 PM »
Chris,
As this was a private request, I don't normally take pics of the processes, just the finished article.
But a quickie explanation.
The internal dimensions and boring to fit the crystal OD was all done on the original stainless bar held in the chuck. It was then parted off and turned around. It was then held with an expanding 5C mandrel turned to size to fit the inside dimensions of the bezel. I was then able to put the two outside tapers on.
I hope that helps
« Last Edit: February 07, 2011, 06:35:08 PM by bogstandard »
Skype - bandit175
« Reply #5 on: February 08, 2011, 02:05:03 AM »
Yes, makes sense, thank you for the explanation.
Offline bry1975
« Reply #6 on: February 08, 2011, 06:20:47 AM »
The case certainly did look like it had been ran over by either a car or worn by a welder!
I only lightly sanded the rough sides and then ran the case under a refinishing wheel.
« Reply #7 on: February 08, 2011, 12:31:08 PM »
Nice job John.  :thumbup:
I bet it didn't take the old master long to do that, eh?
Offline Bogstandard
  • Bogs Group
« Reply #8 on: February 08, 2011, 01:42:55 PM »
Bernd,
Not long at all, purely because when I was doing it, I prepared the bar to do another couple just in case something went wrong.
Because there was double angle being used on the outside, and it was a very complicated shape to measure up on the inside without a comparator microscope (which I don't possess), I actually cut slightly too deep on the inside for the first couple of attempts, but the third was spot on, with plenty of meat left on the inside.
The pic shows what happened with the first two.
BTW, between each one was only about 20 mins.
Added.
In fact the stainless bar (I have forgotten the material number, that was supplied by Bry) is still under my lathe, and still mounted in the chuck. Now that I know everything was successful, I can now take it out of the chuck and put it away somewhere safe just in case another one like this comes up.
« Last Edit: February 08, 2011, 01:54:53 PM by bogstandard »
Skype - bandit175
Offline Blade
« Reply #9 on: February 08, 2011, 02:46:13 PM »
Nice job!  :thumbup:
Offline bry1975
« Reply #10 on: February 08, 2011, 03:46:44 PM »
I rebrush and clean up bezels with the trick below as it's often very difficult to hold certain parts in a 3 or 4 jaw chuck.
Facing plate with industrial strength double sided tape!
http://img819.imageshack.us/img819/7396/tagcaseback.jpgBIG Thanks To Bogs aka John Moore!
Bry
P.S. takes a good twist of the screwdriver to lever the caseback off the facing plate!
« Reply #11 on: February 08, 2011, 04:36:22 PM »
Nice job John!
Bry, the watch looks great now.
Offline bry1975
« Reply #12 on: February 08, 2011, 04:47:37 PM »
Thanks Eric!
Offline HS93
« Reply #13 on: February 09, 2011, 05:40:03 AM »
I use this methoud to hold bits down but use IPA Isopropyl Alcohol a quick squirt leave for a few min and it falls off anddoes not normally rust the surface (well not my mill anyway) and dries very quick and you are left with no resedue.cleans things well as well great for around the shop (and house).
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=390274566925&ssPageName=ADME:B:EOIBSA:GB:1123
Peter
Offline bry1975
« Reply #14 on: February 09, 2011, 12:51:25 PM »
Thanks for the recommendation Peter I'll have to try some oh and the facing plate
is ally.  FYI I run the 3 jaw and 4 jaw and facing plates on my father's Myford ML8 wood
lathe works a treat for brush finishing and polishing.
« Last Edit: February 09, 2011, 01:18:22 PM by bry1975 »
Offline Bogstandard
  • Bogs Group
« Reply #15 on: February 09, 2011, 03:17:11 PM »
Bry
I use double sided on the surface grinder for non ferrous parts that can't be held in a vice to use the mag chuck.
Really good for a fine grind, but I do occasionally put bits into orbit.
Skype - bandit175
Offline bry1975
« Reply #16 on: February 11, 2011, 10:03:16 AM »
Strong double sided tape is certainly a very versatile sticking media.
Bry
