Author Topic: Good Advice  (Read 14750 times)
Offline BK
Good Advice
« on: June 17, 2010, 06:33:30 AM »
David (Stilldrilling) recommended a 2" diamond wheel for sharpening tools, spot on!!  :)
Mine arrived this week, but I didn't like the Dremal type arbour, it looked too flimsey, so I made a small face plate for it.
http://i160.photobucket.com/albums/t184/oldcranker/100_3128.jpgGood Advice
http://i160.photobucket.com/albums/t184/oldcranker/100_3130.jpgGood Advice
Cleaned up, and tapped a thread, works a treat, thanks mate. :clap:
http://i160.photobucket.com/albums/t184/oldcranker/100_3131.jpgGood Advice
If it aint broke, don't fix it!
Re: Good Advice
« Reply #1 on: June 17, 2010, 08:05:45 AM »
Yer welcome Bernie!
I usually run mine at 1100 rpm. Never tried it at higher revs........  ::)
Incidentally.........This has great potential.  :thumbup:
http://i110.photobucket.com/albums/n95/Dayjo/P3160027.jpgGood Advice
Not got around to sorting it, yet.   ::)
http://i110.photobucket.com/albums/n95/Dayjo/P3160025.jpgGood Advice
The red trail, is paint from a new carbide knifetool I roughed out, just to try it.....   :thumbup:
http://i110.photobucket.com/albums/n95/Dayjo/P3160016.jpgGood Advice
I had only jammed it onto a 22mm spigot. Will mount it sensibly, and try out properly....... Sometime!
Offline BK
Re: Good Advice
« Reply #2 on: June 17, 2010, 08:20:09 AM »
1060 rpm, that's my max without swapping the belt
Re: Good Advice
« Reply #3 on: June 17, 2010, 03:47:53 PM »
Looks a good idea! - how is the work clamped up and held/offered upto to the grinding wheel?
Re: Good Advice
« Reply #4 on: June 17, 2010, 04:10:02 PM »
By hand..... Like any other offhand grinder!  :thumbup:
Re: Good Advice
« Reply #5 on: June 17, 2010, 05:06:08 PM »
Oh I see, I was thinking you were somehow going to offer it up by locking it up in an arrangement around the cross slide.
Offline BK
Re: Good Advice
« Reply #6 on: June 17, 2010, 06:10:38 PM »
Ideal for sharpening tools.
Offline BK
Re: Good Advice
« Reply #7 on: June 18, 2010, 05:16:52 AM »
Yer welcome Bernie!
http://i160.photobucket.com/albums/t184/oldcranker/DCP_3307.jpgGood Advice
Umm, that might be handy in my homemade wire brush/grind anything!! It's got a chuck on one end to take all sorts of things.
Re: Good Advice
« Reply #8 on: June 18, 2010, 07:59:52 AM »
Bernie,
Don`t know if they`re available around your side...... Here`s where I got mine. (Don`t think I paid that much though!)  :scratch:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=280389682139
lordedmond
Re: Good Advice
« Reply #9 on: June 18, 2010, 12:16:43 PM »
I would have thought that using a diamond disk like that in the lathe would leave diamond dust on the bed , cross slide, bearings and every other place you can think of
diamond dust makes a VERY good lapping compound
just my 0.02 cents worth
Stuart
Re: Good Advice
« Reply #10 on: June 18, 2010, 12:27:39 PM »
Stuart,
The diamond grit stays stuck to the disc...... Certainly, much less messy than the grit from emery cloth.
I usually cover the bed ways, for either operation......  :thumbup:
