Author Topic: Knurling tool  (Read 33363 times)
Offline Gerhard Olivier
Knurling tool
« on: November 29, 2009, 02:20:42 PM »
Time to attak the knurling tool
Design is to be 2 arms to appy presure and save the lathe bearings but to minimize the amount that the cros slide has to be pulled out the mounting is no be to the side of the toolpost.
My knurling tool that I dont like is very good (funtionally) but a bit of a pain to get in between the toolpost and the work.
http://i608.photobucket.com/albums/tt161/geroli/DSC_0001-1.jpgKnurling tool
So To work.
Some steel cut on the band saw
http://i608.photobucket.com/albums/tt161/geroli/DSC_0002-5.jpgKnurling tool
The body marked
http://i608.photobucket.com/albums/tt161/geroli/DSC_0004-4.jpgKnurling tool
And co-ordinate drilled
http://i608.photobucket.com/albums/tt161/geroli/DSC_0005-6.jpgKnurling tool
Then I drilled the holes in the arms and bolted groups of four together.  I cut the relief on the mill by alligning the scribed line with the top of the vice jaw..
http://i608.photobucket.com/albums/tt161/geroli/DSC_0007-5.jpgKnurling tool
http://i608.photobucket.com/albums/tt161/geroli/DSC_0009-4.jpgKnurling tool
The round ends was cut using the washer as a guide to set progressive angles on the mill vice and the cutter staying at one hight
http://i608.photobucket.com/albums/tt161/geroli/DSC_0010-3.jpgKnurling tool
http://i608.photobucket.com/albums/tt161/geroli/DSC_0011-1.jpgKnurling tool
Then a Trial fit to see what it will look like
http://i608.photobucket.com/albums/tt161/geroli/DSC_0012-1.jpgKnurling tool
Gerhard
Guernsey
Channel Islands
Re: Knurling tool
« Reply #1 on: November 29, 2009, 03:01:59 PM »
Nice couple of tools you've made there Gerhard + boring tool holder, they will come in real handy.
 :thumbup: :thumbup: :thumbup:
Have fun
Russel
Re: Knurling tool
« Reply #2 on: November 29, 2009, 03:10:09 PM »
Very nice work!
I especially like the way you rounded the parts with a washer and progressive cuts. I hadn't thought of that.
Russ
Re: Knurling tool
« Reply #3 on: November 29, 2009, 08:53:12 PM »
Gerhard
Very smart work their my man. Using washers like filing buttons to machine the round ends is very clever of you. Thanks for sharing with us.  :ddb: :ddb:
Re: Knurling tool
« Reply #4 on: December 01, 2009, 08:18:14 AM »
Didn't know what people were on about for a minute then, but do now! Great idea Gerhard. Nice looking tools too.
Re: Knurling tool
« Reply #5 on: December 03, 2009, 03:31:34 PM »
Thank chaps
Rounding the material was an idea I read in a book some time?  I tried to find the referance again to put in here but cant remember what book it was.  The writer put a round bar through the hole and then used the vice to round around the bore leaving a piece flat to use as a ossilating cylinder. (instead of using casting?)
Hope to do a bit of turning for this poject this weekend.
Gerhard
Guernsey
Channel Islands
Re: Knurling tool
« Reply #6 on: December 05, 2009, 03:33:18 PM »
Took some of the bar used as the spacers as it had the exact right thickness. This is to make the spacers.
http://i608.photobucket.com/albums/tt161/geroli/Knurl1.jpgKnurling tool
http://i608.photobucket.com/albums/tt161/geroli/Knurl3.jpgKnurling tool
http://i608.photobucket.com/albums/tt161/geroli/Knurl4.jpgKnurling tool
That is the six spacers done.
Then 16 mm bar for the threaded bits.
http://i608.photobucket.com/albums/tt161/geroli/Knurl1-1.jpgKnurling tool
Then Is set up to check.
http://i608.photobucket.com/albums/tt161/geroli/Knurl11.jpgKnurling tool
After cutting the 8mm part of the edges I drilled 3 to 8mm (clearance for m8 thread)  and drilled 3 to 6.8mm for threading M8 and cut the non-threaded one for a flat surface
http://i608.photobucket.com/albums/tt161/geroli/Knurl12.jpgKnurling tool
Gerhard
Guernsey
Channel Islands
Re: Knurling tool
« Reply #7 on: December 06, 2009, 02:09:12 AM »
Going well  :thumbup:
Nice work
Re: Knurling tool
« Reply #8 on: December 06, 2009, 03:37:32 AM »
Nice 1 Gerhard,
Do you find it tedius doing lots of the same bit? I do, I hate it!
Re: Knurling tool
« Reply #9 on: December 07, 2009, 08:05:23 AM »
Thanks Stew Nick
Nick yes it is tedius but must be done- best to make it as close to a production run.
Made the threeaded bit next.  12mm bar used
http://i608.photobucket.com/albums/tt161/geroli/Knurl35.jpgKnurling tool
Using the Die holder   :D :D :D
http://i608.photobucket.com/albums/tt161/geroli/Knurl36.jpgKnurling tool
The threaded rods done
http://i608.photobucket.com/albums/tt161/geroli/Knurl37.jpgKnurling tool
The Knobs made from Ali 41mm diameter radius cut with the ball cutter.
http://i608.photobucket.com/albums/tt161/geroli/Knurl38.jpgKnurling tool
And a small amount of radius knurling to give it a bit more grip.
http://i608.photobucket.com/albums/tt161/geroli/Knurl39.jpgKnurling tool
And the End product
http://i608.photobucket.com/albums/tt161/geroli/Knurl310.jpgKnurling tool
Gerhard
Guernsey
Channel Islands
Re: Knurling tool
« Reply #10 on: December 07, 2009, 09:02:04 AM »
Gerhard,
I think you just came up with another use for the ball turning fixture. Putting a knurl on a ball. Neat idea.
Nice project by the way. I need to make one of these some day.
Re: Knurling tool
« Reply #11 on: December 07, 2009, 11:56:56 AM »
Gerhard
Very nice handles for your knurling tool. I like the way you have knurled the round surface. Will make the knurling tool look very sharp. :ddb: :ddb:
Re: Knurling tool
« Reply #12 on: January 02, 2010, 06:50:23 AM »
Thanks chaps
Finally finished them- used some 20mmx10mm bar to cut t-piece to mount on the tool post.
Then cut a test piece of all 3 the knurl patterns.
http://i608.photobucket.com/albums/tt161/geroli/k51.jpgKnurling tool
http://i608.photobucket.com/albums/tt161/geroli/k1.jpgKnurling tool
I used 350 RPM (25mm bar) and a lot of wd40 sprayed onto the piece to flush away the bits - I cut small amounts and tighten a bit between each pass.  When I stop the piece to check the pattern I leave the knurling tool engaged and If need then just restart the lathe.  Others will have different ways but this works on my lathe.
The only problem is the large straight knurl takes a lot of presure and I think it will be for Ali only it took a lot of passes before the pattern looked right.
Gerhard
Guernsey
Channel Islands
Re: Knurling tool
« Reply #13 on: January 02, 2010, 07:22:39 AM »
Hi Gerhard
I have just red through this post ,what a great read and you have made three very fine knuling tools,that will give you good service for years   :clap: :clap: :clap: :clap: and you get a very nice crisp knurl too ,,,great job , i see you make good use of your ball turning attachment ,that another tool i will have to build.
Regards Rob
Re: Knurling tool
« Reply #14 on: January 02, 2010, 09:11:56 AM »
Gerhard,
Very nice job. That knurling looks excellent.
Offline Shepherduke
Re: Knurling tool
« Reply #15 on: January 02, 2010, 10:02:30 AM »
  Lovely piece of work geroli.  Do you have a drawing for this (or any other)
  Die Holder?  It looks too good to use!  Shepherduke
Re: Knurling tool
« Reply #16 on: January 02, 2010, 12:25:41 PM »
Thanks for comments chaps
I suppose it is lazy to not want to change the cutters over but now I know I will use the most appropriae knurl rather than the one that is in the knurling tool. :med:
Sheperduke The die holder build is on here somewhere
http://madmodder.net/index.php?topic=2066.0
And Russel made one as well  http://madmodder.net/index.php?topic=2187.0
If you need a COC will do but it is really easy to make.  Mine fits over the tailstock ram - but most uses a steel bar held in the tailstock.
Gerhard
Guernsey
Channel Islands
Offline Shepherduke
Re: Knurling tool
« Reply #17 on: January 02, 2010, 03:45:40 PM »
  Thanks for that geroli.  Due to the Knurling tool and Tailstock t&d holders
  projects of yours, I am inspired to start making a few bits and pieces on     my   new mini lathe ( after my hip operation next Friday, and six weeks  recouperation! ).
  I have been searching for a book which deals with  similar  projects, but my local library reports that all such books have been "mislaid".  If you or anyone else reading this post can recommend such a book, I would be very grateful.  Shepherduke.
Re: Knurling tool
« Reply #18 on: January 02, 2010, 06:06:46 PM »
This guy is Canadian based. Published the 3 Bedside Readers. Might be of interest. Guy Lautard's Beside Readers
Re: Knurling tool
« Reply #19 on: January 03, 2010, 06:52:57 AM »
Gerhard....
Very nice tool build  :thumbup:
Really like the use of the ball cutter..... And the knurl on the radius... inspiring! never thought of that one, top marks  :bow:
You know I'm going to have to try and copy that now  :dremel:
I don't do too much knurling, find it difficult at times, think I may need to buy some new/sharper knurls..... I think stainless steel and inexperience killed mine a while ago! ::)
Again, very good topic  :thumbup:
This tuit list is getting massive!
