Author Topic: Digital oscilloscope project/kit  (Read 690478 times)
Offline PK
Re: Digital oscilloscope project/kit
« Reply #225 on: January 23, 2016, 09:17:34 PM »
We have one of these at work http://www.peakelec.co.uk/acatalog/jz_lcr40.html
As I recall, it wasn't 'chinese cheap' but it works very well and we use it more than we thought we would.
« Reply #226 on: January 24, 2016, 03:06:25 AM »
Yes I have one of those tucked away in a drawer. Extremely useful. Only irritation is that it's calibration period is obviously written into the firmware so it nags me to send it off whenever I use it!
Offline John Swift
« Reply #227 on: January 24, 2016, 10:03:53 AM »
tried  the DSO138 power supply mod
with firmware 113-13801 -050 you don't get an improvement
unlike that as described at -
http://forum.banggood.com/forum-topic-61279.html
for the early version that's cloned using FW  113-13801-040
managed to buy 6 AA nicads for the Velleman K7105 'scope I built back in 2002
with no back light , the picture showing the trace of the test signal from the DSO138 is not great but shows the trace for comparison
PS
RS Components do a slide switch that could be OK to mount onto a new front panel
 thought the 2 slide switches (sen1 & sen2)could be replaced by 1 rotary switch
but the rotary 4  pole 9 way switches I've found so far are several times more than the cost of the kit !
« Last Edit: January 24, 2016, 10:30:55 AM by John Swift »
« Reply #228 on: January 24, 2016, 10:35:37 AM »
Hmmm...I guess what you pay for....
No point in buying a Mini if you want Ferrari performance... :Doh:
« Last Edit: January 24, 2016, 12:53:43 PM by John Rudd »
« Reply #229 on: January 24, 2016, 12:48:04 PM »
I wonder how well this kind of rotary switches would work?
http://www.partco.biz/verkkokauppa/product_info.php?cPath=2065_1046_1276&products_id=15706&language=en
Are there any reasonable quality rotary switches like used on scope voltage input stage? Probably someone has considered building simple specialized input amplifiers, bit like differential amplifiers or such. Really hard to build an amplifier that is good in everything, but not too hard to build amplifier that does one or two things good eneough.
Offline John Swift
« Reply #230 on: January 24, 2016, 01:58:54 PM »
Hi Pekka
the switches look OK - I assume they are break before make
twice I have resorted to making a custom switch using parts from RS Components
http://uk.rs-online.com/web/p/rotary-switch-shaft-assemblies/0327894/
plus
http://uk.rs-online.com/web/p/rotary-switches/0352193/?origin=PSF_428206|acc
or
http://uk.rs-online.com/web/p/rotary-switches/0352222/?origin=PSF_428206|acc
  an expensive solution , but it worked
« Reply #231 on: January 24, 2016, 03:24:46 PM »
Those "Wafers" are not silly money, but shaft and rest of it will add up. But they are higher voltage and probably lower capasitance etc.
« Reply #232 on: January 28, 2016, 12:05:15 PM »
Hi, just a quick pic of my test board.
http://i293.photobucket.com/albums/mm72/wheeltapper_2008/test20board_zpshybj1zrh.jpgDigital oscilloscope project/kit
it's not too bad, at least the LED works. :zap:
Roy.
My SMD kit arrived today ,,,,,,,,,,,,,,,,,,,,,,,,,,,,F*&k me  those are bloody small components Roy  :palm:
They are going to take some welding  , 3.2 mm  7018 rods should do the trick  :lol:
« Reply #233 on: January 28, 2016, 12:44:13 PM »
Roy.
What about post weld heat treatment? Have you got a heat blanket to wrap the board in for stress relieving.....?? :lol: :lol:
Sounds like you are all having fun.... :dremel: :zap:  :beer:
« Reply #234 on: January 28, 2016, 12:52:08 PM »
 :lol: I was planning on peening the welds to relieve the stress John .
My Buck converter power supply arrived a few days back , opened it up and it has surface mount components  :palm:  , so a quick shop on Ebay fro some new gear ,
one has to buy new toys  :dremel:
http://i1066.photobucket.com/albums/u410/RobWilson100/Electronics%20Projects/P1100831_zpsiquewa4e.jpgDigital oscilloscope project/kit
And some tackle to practice with .
http://i1066.photobucket.com/albums/u410/RobWilson100/Electronics%20Projects/P1100832_zps4xyeegvs.jpgDigital oscilloscope project/kit
WTF !
http://i1066.photobucket.com/albums/u410/RobWilson100/Electronics%20Projects/P1100829_zpscjm718mh.jpgDigital oscilloscope project/kit
Offline wheeltapper
  • Spixworth Norfolk
« Reply #235 on: January 28, 2016, 01:12:20 PM »
Hi Rob.
yea, they are a bit titchy,  on that board the 0603 resistor is the smallest and that is what is on the scope kit, the frightening thing is,they come even smaller than that, at least three sizes.
funny coincidence, I just ordered an 858D hot air gun, different make to yours tho. got it off Fleabay.
If you are interested in a review see here.
 A different make again but the same thing.
make sure the chipping hammer is sharp before you start. :ddb: :ddb: :ddb: :ddb:
have fun.
Roy.
« Reply #236 on: January 28, 2016, 01:26:45 PM »
Hi Roy
Cheers for the youtube link  very interesting  :thumbup:  they all look very generic , my one  feels and look  canny , not bad for the money , mains lead is a tad short .
http://www.ebay.co.uk/itm/331330745304?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
You say the resistors  come even smaller  :jaw:
I have put a fresh flap wheel on the grinder   :dremel:
Offline wheeltapper
  • Spixworth Norfolk
« Reply #237 on: January 28, 2016, 01:45:37 PM »
I thought you'd like that, he has an SMD solder tutorial here.
this is the hot air gun I ordered. http://www.ebay.co.uk/itm/371415508867?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
as far as I can see they all look the same.
Roy.
« Reply #238 on: January 28, 2016, 02:14:53 PM »
Nice one  Roy  :thumbup:
Question , How long  were you on soldering all those resistors ?
and how do I know which way round the LED goes lol  :scratch:
Offline wheeltapper
  • Spixworth Norfolk
« Reply #239 on: January 28, 2016, 02:41:03 PM »
Rob, I think it took me about 15 mins per column.
put 3 volts across the led an see which way it lights.......................only 3volts tho or........ :zap: :zap: :zap: :zap: :zap: once its all done you can put 9 volts from pad to pad.
if you hold the board up to the light you can see the trace.
looking at mine there is a little green mark next to the negative side. YMMV :D
that guy has some very interesting videos.
Roy.
« Reply #240 on: January 28, 2016, 04:01:54 PM »
Hi Roy
Cheers for the LED tip /info  :thumbup:
Aye just been watching a few of Dave's videos , very interesting and he is quite a character  :clap: :clap:
Cheers Rob
Offline kayzed1
« Reply #241 on: January 28, 2016, 07:36:06 PM »
I have given up on mine now, i had the No trace on screen. I bought another screen kit and it is just the same...no trace but all other stuff is ok..just those two voltages that are not correct so binned it :doh: i went to the forum and one other person has asked the Q' with the same symptoms, and no answer from the mod or users, so bin it was.
Lyn.
Offline wheeltapper
  • Spixworth Norfolk
« Reply #242 on: January 29, 2016, 03:51:09 PM »
Rob. I received my hot air station this morning.
you said your mains lead was short, how short is short?
mine is a separate one that plugs in the back and it's 5 foot long.
It works well tho, I tried desoldering a tiny 16 pin IC and it came straight off the board.
Roy.
Offline wheeltapper
  • Spixworth Norfolk
« Reply #243 on: January 29, 2016, 04:36:37 PM »
Hi John, this is the one I got.
I ordered it on Tuesday and it arrived this morning.
Roy.
« Reply #244 on: January 29, 2016, 07:23:25 PM »
Boy, I'm kicking myself that I hadn't bought shares in this company when it was first brought to light.  I've lost count how many kits have reportedly been bought as a result!
« Reply #245 on: January 30, 2016, 02:20:29 AM »
I got one scope kit yesterday.
I was just eyeballing the PCB. Should have a cunning plan for the external rigger signal, but I want to assemble it as "standard" now. Display comes over it, not too much space for connectors or standoffs.
There seems to be some "optional" connectors: Like Mini USB and some for programming. Anyone used them?
Offline wheeltapper
  • Spixworth Norfolk
« Reply #246 on: February 13, 2016, 08:25:09 AM »
SNIP
[/quote]
SNIP
Hi Rob.
We never heard how you got on with those SMD components.
You must have finished by now. :) :) :)
Roy.
« Reply #247 on: February 13, 2016, 08:45:01 AM »
 :Doh:  Hi Roy ,
 I have had a wee practice using the hot air gun and solder paste with  mixed results  :(  , looking for a way to apply just the  correct amount of paste .
too much , wire feed a tad high  :lol:
http://i1066.photobucket.com/albums/u410/RobWilson100/Electronics%20Projects/16012819463511273474_zpscqezvyqz.jpgDigital oscilloscope project/kit
looking a bit better , placement is a bit wonky  :palm:
http://i1066.photobucket.com/albums/u410/RobWilson100/Electronics%20Projects/16012819494011458491_zpschkxzpua.jpgDigital oscilloscope project/kit
I am using a stereo microscope to do the work , I think I need glasses  :palm:
http://i1066.photobucket.com/albums/u410/RobWilson100/P1100836_zps57nyhnhp.jpgDigital oscilloscope project/kit
I may practice a bit more this evening , things are a bit slow at  the moment as I am pulling my workshops to bits to make room for new machines  , like this wee beastie   :)
http://i1066.photobucket.com/albums/u410/RobWilson100/Arboga%20Geared-head%20Drill/P1100838_zpsvzxoq4mb.jpgDigital oscilloscope project/kit
Offline wheeltapper
  • Spixworth Norfolk
« Reply #248 on: February 13, 2016, 09:16:01 AM »
You've got one upside down! all the pixies will fall out. :lol: :lol:
Nice looking drill press, is it a recon job or just chuck it in a space and use it?
posh microscope you have there,  :drool: all I've got is a MK1 eyeball and a magnifying glass. :bang: :bang:
Roy.
« Reply #249 on: February 13, 2016, 10:09:20 AM »
So opinions please on the hot air rework unit ?
Are they good, rubbish or something else?
Nice effort Rob, half the trouble is placing the little blighters and getting them to stay put..... :Doh:
Then soldering them without dislodging.....
