Author Topic: Digital oscilloscope project/kit  (Read 483894 times)
Re: Digital oscilloscope project/kit
« Reply #125 on: January 02, 2016, 10:14:11 AM »
Offline modeng200023
« Reply #126 on: January 02, 2016, 12:59:51 PM »
Thanks Rob, I think I'll have some fun.
Offline John Swift
« Reply #127 on: January 05, 2016, 03:36:49 PM »
Hi Rob
a simple LED oscilloscope from 20 years ago
the circuit shows the principle
the 'scope in the  photo has an adjustable sync  , time base and attenuator
as expected in a usable  tool
the oscilloscope is usable up to 30 KHz
Online John Rudd
« Reply #128 on: January 05, 2016, 03:43:57 PM »
There arent any valves in that design..... :lol:
Offline John Swift
« Reply #129 on: January 05, 2016, 03:52:33 PM »
Hi  John
    your correct ,
I did not go back to the old all valve Heath Kit oscilloscopes or Practical Wireless projects
they don't work with just a pp3 battery
« Reply #130 on: January 05, 2016, 04:12:49 PM »
Online John Rudd
« Reply #131 on: January 05, 2016, 04:17:02 PM »
If you care for a quick wallow in nostalgia:
https://archive.org/stream/PracticalWireless1971April#page/n25/mode/2up        :thumbup:
Yup, remember that well......iirc there was another scope in one of the other periodicals a couple of years earlier....Radio Constructor? Used a 1CP1 crt....iirc..
I love nostalgia and wallowing....
« Reply #132 on: January 05, 2016, 04:34:20 PM »
Made my first oscilloscope when I was at school based on an ex WW2 VCR97 radar tube 6" diameter. Drove the metal working instructor mad pestering him to help me make the chassis and front panel. Used many of the ubiquitous EF50 red metal canned valves that the surplus shops were awash with at the time
http://www.r-type.org/exhib/aaj0166.htm
http://www.dos4ever.com/EF50/EF50.html
It worked ok but the frequency response was pretty low at about 1Mhz
« Reply #133 on: January 05, 2016, 11:09:27 PM »
Hi, just a quick pic of my test board.
it's not too bad, at least the LED works. :zap:
Roy.
Seems a little Rube Goldberg if you ask me... ;)
« Reply #134 on: January 06, 2016, 02:21:18 AM »
I love wallowing....
You  be careful. I reckon it was too much wallowing in my younger days that did my back in.  :ddb:
« Reply #135 on: January 06, 2016, 02:34:29 PM »
Hi Rob
Hi John ,  Did you build one ?
Looks a fun project , I may have a bash at making one myself   :zap:
Its good to see this old time technologie , all way way before my time    :lol: :lol:                 cheers for sharing lads  :thumbup:
Offline wheeltapper
  • Spixworth Norfolk
« Reply #136 on: January 06, 2016, 03:27:03 PM »
Hi Rob.
I've just finished building the scope kit and it all seems to work OK apart from one thing, the top l/h switch for AC, DC and ground, I can only get the display to indicate DC or ground.
have you any ideas what to look for?
cheers
Roy.
Offline kayzed1
« Reply #137 on: January 06, 2016, 04:01:13 PM »
My kit arrived today, will take a look at it in the morning and report back.
Lyn.
Online John Rudd
« Reply #138 on: January 06, 2016, 05:21:52 PM »
How long does it take for a kit to arrive?
Might just buy one for fun... :coffee: I already have a digital lcd scope...... :scratch:
« Reply #139 on: January 06, 2016, 05:49:24 PM »
Hi Rob.
cheers
Roy.
Hi Roy
All I can think of is you may have a faulty switch  ,
From pin 2 on the back of the board to the outer of the BNC plug ,
With the switch  in the Ground position you should have continuity .
In AC or DC there will be a high resistance , if you still have continuity in these positions the switch is bust.
DSO  Manual attached for the pros to cast an eye over .
Hope that helps ,Rob
Offline wheeltapper
  • Spixworth Norfolk
« Reply #140 on: January 06, 2016, 05:55:14 PM »
Mine arrived within a week. ordered on 21-12, e-mail saying it was dispatched 22-12, arrived a few days later.
I got mine from here
http://www.ebay.co.uk/itm/131575205359
Roy.
« Reply #141 on: January 06, 2016, 05:58:48 PM »
You know you want to John  :poke:  ,,,,,,,,,,,,,,,,,,,,,,join the fun  :lol:
4 weeks from banggood  :palm:
Offline wheeltapper
  • Spixworth Norfolk
« Reply #142 on: January 06, 2016, 06:06:29 PM »
Rob,
I just checked the switch and I get what you say on pin 2, continuity to ground, high resistance on AC or DC.
why is there an arrow pointing to pin 4?
Roy.
« Reply #143 on: January 06, 2016, 06:23:15 PM »
Rob,
Roy.
Hi Roy
 Pin 4 is connected to BNC outer ,it was easier/clearer  to use a crock clip on the connector and take the photo .
So its not the switch then . mmmmmmmm
Offline John Swift
« Reply #144 on: January 06, 2016, 06:26:16 PM »
Hi Rob
just got back from the Everton v Manchester City match    (we won 2-1)
no I didn't build the LED scope
 I built a Vellerman LCD scope about 12 years ago
I've not used it for a while it needs the  6  AA nicads replacing
« Last Edit: January 06, 2016, 11:11:46 PM by John Swift »
Offline John Swift
« Reply #145 on: January 06, 2016, 07:16:03 PM »
Hi Roy
just double checking
when you say I can only get the display to indicate DC or ground.
do you mean it does not show "AC" at the bottom of the LCD
or the trace is a straight line
if its not indicating "AC" at the bottom of the LCD then check the voltage at test point TP6  ( switch 1B terminal 6 )
+5V for DC
 +1.2V  for AC
and 0V for GND
if its the trace not responding
check C1 is 0.1uF (marked 104)
if for instance a very small value capacitor that should be C2 , C3 , C5 or C7
virtually non of the AC voltage at the input connector will be passed onto  switch 1A terminal 3
Offline wheeltapper
  • Spixworth Norfolk
« Reply #146 on: January 07, 2016, 06:07:18 AM »
Hi John, thanks for the reply.
It is the indicator on the LCD, it doesn't change to AC.
I was going to do some voltage checks as soon as real life gets out of the way. :bang:
I'll get back with the results.
Roy.
Offline wheeltapper
  • Spixworth Norfolk
« Reply #147 on: January 07, 2016, 06:24:42 AM »
Thar's interesting, I'm getting 3.8v on AC.
I will look further.
Roy.
  • Country: ie
« Reply #148 on: January 07, 2016, 07:31:55 AM »
Cheers Rob for posting the manual.
 I must say that is one of the best manuals I've seen in a while for such a cheap kit!.
Online John Rudd
« Reply #149 on: January 07, 2016, 07:37:33 AM »
3.8v is too high....should be around 1.4v.....it looks like the software isnt switching as a result...
I suspect the resistors are the wrong way round....
You need to check the values of the resistors in the chain......
