Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Welcome to MadModder!
Home
Help
Search
Login
Register
Gallery, Projects and General
How do I??
Hobbymat low speed kit
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Hobbymat low speed kit (Read 8120 times)
PJW
Jr. Member
on:
August 17, 2015, 05:14:11 PM »
Hi does any one know if drawing for the low speed kit for the Hobbymat exist?
Logged
Old Guys Rule the Dark Side of the Shed!
chipenter
Hero Member
Re: Hobbymat low speed kit
Reply #1 on:
August 17, 2015, 05:39:34 PM »
Acording to Tonys lathes site a kit does exsist
http://www.lathes.co.uk/hobbymat/
Logged
PJW
Jr. Member
Reply #2 on:
August 17, 2015, 06:00:48 PM »
Thanks, I know he makes a kit, but it is very, very expensive. i was wanting to make my own,
Peter
Logged
velocette
Full Member
Reply #3 on:
August 18, 2015, 12:42:52 AM »
Hi Peter
Looking at the photos of the Low Speed Kit It appears that it is a single phase motor with a fixed speed of 1425 RPM.
Have you considered a Variable Speed drive using a 3 phase motor and single to three phase variable speed converter.
Or AC to DC variable speed converter and a DC motor.
"Poly Vee Belts" are far superior to vee belts for larger ratios of speed reduction and easier to fabricate as the angle of the vees is constant with any diameter so no calculations for the correct angles.
J Section poly vee belts are 60 deg by 2.34 mm pitch.
PDF file with more info attached
Logged
philf
Hero Member
Reply #4 on:
August 18, 2015, 03:23:19 AM »
Quote from: velocette on August 18, 2015, 12:42:52 AM
Eric,
I agree that Poly-V are far superior but the included angle is 40 degrees and not 60.
Logged
velocette
Full Member
Reply #5 on:
August 18, 2015, 04:54:59 PM »
Typo Error the manual tells it correctly
Note to self RTFMF
Logged
PJW
Jr. Member
Reply #6 on:
August 18, 2015, 05:19:06 PM »
thanks for the information, I will work on that,
Peter
Logged
Print
Pages: [
1
Go Up
« previous
next »
How do I??
