Author Topic: Hobbymat low speed kit  (Read 8123 times)
Offline PJW
« on: August 17, 2015, 05:14:11 PM »
Hi does any one know if drawing for the low speed kit for the Hobbymat exist?
Old Guys Rule the Dark Side of the Shed!
Re: Hobbymat low speed kit
« Reply #1 on: August 17, 2015, 05:39:34 PM »
Acording to Tonys lathes site a kit does exsist http://www.lathes.co.uk/hobbymat/ .
Offline PJW
« Reply #2 on: August 17, 2015, 06:00:48 PM »
Thanks, I know he makes a kit, but it is very, very expensive. i was wanting to make my own,
Peter
Offline velocette
« Reply #3 on: August 18, 2015, 12:42:52 AM »
Hi Peter
Looking at the photos of the Low Speed Kit It appears that it is a single phase motor with a fixed speed of 1425 RPM.
Have you considered a Variable Speed drive using a 3 phase motor and single to three phase variable speed converter.
Or AC to DC variable speed converter and a DC motor.
"Poly Vee Belts" are far superior to vee belts for larger ratios of speed reduction and easier to fabricate as the angle of the vees is constant with any diameter so no calculations for the correct angles.
J Section poly vee belts are 60 deg by 2.34 mm pitch.
PDF file with more info attached
« Reply #4 on: August 18, 2015, 03:23:19 AM »
Eric,
I agree that Poly-V are far superior but the included angle is 40 degrees and not 60.
Offline velocette
« Reply #5 on: August 18, 2015, 04:54:59 PM »
Typo Error the manual tells it correctly
Note to self RTFMF
Offline PJW
« Reply #6 on: August 18, 2015, 05:19:06 PM »
thanks for the information, I will work on that,
Peter
