Author Topic: Scott Vacuum Engine......  (Read 140063 times)
Re: Scott Vacuum Engine......
« Reply #50 on: December 30, 2014, 07:58:38 AM »
Hi Stuart.
These days, H&S would have a field day.......  :palm:
The gas engines. Were there three of them? Each with a lady's name?  :scratch:
Old Gordon, the blacksmith. Who used to live over the fence from me. Told me of the times, as an apprentice. He had to crawl inside the exhaust pipes, to weld patches over the leaks........  :bugeye:
Thanks! Wishing a happy New Year, to You and Yours.......  :thumbup:
lordedmond
« Reply #51 on: December 30, 2014, 08:27:59 AM »
Yes David no h&s then only came over for a works visit whilst I was doing my time ,
The generators were huge all open frames two cylinder gas engines ,very unnerving standing at the ends with the piston rod cross head coming towards you,
I bet the generators were serviced while running as we did with our converters and alternators ie carbon brushes changed on load / live no need to shut down it was only 220 volts and the Gas engine ones were 2 volts
I cannot remember the names of them
Stuart
« Reply #52 on: December 30, 2014, 09:09:34 AM »
Fascinating stuff........
« Reply #53 on: December 30, 2014, 10:01:39 AM »
Stuart
JOAN, ENID, VERA........
Horizontal, Twin Tandem Compound. ** BLAST FURNACE GAS ENGINES** Date 1924-28.
Cylinder- Dia x Stroke 51.25" x 59".
Horse Power 7150.
Speed 91.5 rpm.
3-phase flywheel aternator - 185 tons inc crankshaft.
3 engines, JOAN, ENID and VERA, using 544,500 cu ft/hour of blast furnace gas, to generate 5000 kw at 6,600 volts.
http://ellisdesign.jalbum.net/Stationary%20Engines%20-%204/Iron%20&%20Steelworks/Staveley%20Ironworks/slides/01-66-34.html?show_param=3
Would have loved to have seen them running........
lordedmond
« Reply #54 on: December 30, 2014, 12:34:16 PM »
Yes David they where quite a sight and very nearly silent
Well you have jogged my brain cell it was the rotary converters that did the two volts for the salt cells the gas engines were at high voltage thaks for the nudge
At Stanton we used steam turbines for power generation
Stuart
« Last Edit: December 30, 2014, 01:23:51 PM by Stuart »
« Reply #55 on: January 07, 2015, 04:23:17 PM »
I've had very little workshop time, these past weeks. But, have made some good, solid progress.
I took the top off the original burner......
http://i110.photobucket.com/albums/n95/Dayjo/2015%20Onward/IMG_20150107_115202515_zps19e197f9.jpgScott Vacuum Engine......
And, made a twin wick cap........
http://i110.photobucket.com/albums/n95/Dayjo/2015%20Onward/IMG_20150107_115342708_zps2bd78d45.jpgScott Vacuum Engine......
The engine then proved to be a willing, steady runner!
The shim valve. When releasing it's pressure, blew onto the flames. Bending them outward.
So, I filed the top edge of the "window", to direct the pressure more upwards.
That's a bit better.......
http://i110.photobucket.com/albums/n95/Dayjo/2015%20Onward/IMG_20150107_111704765_zpscbc75328.jpgScott Vacuum Engine......
It's really satisfying, when you begin to understand these engines.
The obligatory video.........
Next job. We need an "eyebrow", to replace the hacksaw blade.
Also, I've noticed the mild steel shutter, is now scuffing the s/s port area. Will swap material, to brass shim........
Thanks for looking in!   :beer:
« Last Edit: January 07, 2015, 06:02:35 PM by Stilldrillin »
« Reply #56 on: January 27, 2015, 04:48:44 AM »
A cap. To finish off the burner assembly.  :thumbup:
3/8BSP fittings.........
http://i110.photobucket.com/albums/n95/Dayjo/2015%20Onward/IMG_20150115_145554372_zpsaeed92c2.jpgScott Vacuum Engine......
Final assembly........
http://i110.photobucket.com/albums/n95/Dayjo/2015%20Onward/IMG_20150115_150003994_zps85ca32d8.jpgScott Vacuum Engine......
« Reply #57 on: January 27, 2015, 06:05:36 AM »
I've had very little shop time, recently. Old bones/ cold workshop........  :(
Managed to bend up a s/steel shroud, for the burner flame area.
Then grooved, to give a positive location.......
http://i110.photobucket.com/albums/n95/Dayjo/2015%20Onward/IMG_20150116_134255567_HDR_zpsnl6xzmzn.jpgScott Vacuum Engine......
Set it in place........
http://i110.photobucket.com/albums/n95/Dayjo/2015%20Onward/IMG_20150116_134442850_HDR_zpsaxnfps6f.jpgScott Vacuum Engine......
And, silver soldered........
http://i110.photobucket.com/albums/n95/Dayjo/2015%20Onward/IMG_20150120_142849712_zpshihcllaq.jpgScott Vacuum Engine......
Seems to work well.......
http://i110.photobucket.com/albums/n95/Dayjo/2015%20Onward/IMG_20150122_133012875_zps8i292jgv.jpgScott Vacuum Engine......
Nice, steady running..........
http://i110.photobucket.com/albums/n95/Dayjo/2015%20Onward/IMG_20150122_133238344_zpsukelngfj.jpgScott Vacuum Engine......
Maybe, a little choked? By the recessed shroud.......
http://i110.photobucket.com/albums/n95/Dayjo/2015%20Onward/IMG_20150122_134021019_zpss29nmowz.jpgScott Vacuum Engine......
Opened it up, a little.........
http://i110.photobucket.com/albums/n95/Dayjo/2015%20Onward/IMG_20150122_135516761_zpsypwysqem.jpgScott Vacuum Engine......
That's better!
http://i110.photobucket.com/albums/n95/Dayjo/2015%20Onward/IMG_20150122_140326244_zpsuwdcevho.jpgScott Vacuum Engine......
Realised the valve assembly had settled a little. The shutter was only just covering the ports. Maybe, allowing pressure to exit horizontally, onto the flames.
Tweaked, to give 2mm overlap........
http://i110.photobucket.com/albums/n95/Dayjo/2015%20Onward/IMG_20150126_133922127_zpssufts3uw.jpgScott Vacuum Engine......
All that was left to do, was to experiment with the wick height, and positioning.
Sorry for the amateur dramatics. But, I was, just a little pleased with the result.........
Still only, loosely assembled, for test purposes. Using undersize c/i piston.
Lots to do yet. But VERY encouraging.
Thanks for looking in!  :thumbup:
« Reply #58 on: January 27, 2015, 05:37:08 PM »
Well done young Fella ...  :thumbup:
That really is a nice runner ..  :med: much improved .
You may reward yourself with an extra Jaffa Cake ..
« Reply #59 on: January 27, 2015, 05:43:26 PM »
Thank you, Young Man.......  :thumbup:
Offline fcheslop
« Reply #60 on: January 27, 2015, 05:46:28 PM »
Nice, you must be chuffed with that marra
cheers
« Reply #61 on: January 27, 2015, 05:51:22 PM »
cheers
Certainly am, Pal.  :thumbup:
Each tweak, improved the revs.......  :D
Now, finished developing the head. Going to start on the other end, next.  :palm:
Offline fcheslop
« Reply #62 on: January 27, 2015, 05:56:57 PM »
Gluten for punishment :loco:
  :D
« Reply #63 on: January 27, 2015, 05:58:11 PM »
  :D
Listen who's talking......  :lol:
Offline fcheslop
« Reply #64 on: January 27, 2015, 06:03:03 PM »
Nah marra Iv seen the light going all steamy :D
Sooo the big Q are you fitting her with balls
cheers
« Reply #65 on: January 27, 2015, 06:39:48 PM »
Great improvement David, more than double where you started. Beautiful engine, too.  :clap: :clap: :beer:
« Reply #66 on: January 28, 2015, 07:59:07 AM »
cheers
Wot sorta balls?  :scratch:
A governor?  Nah!
Thanks Steve!  :beer:
Happy with the head etc. I'm turning my attention to the other end, of this engine.
There's something wrong........  :scratch:
It's not the 'orribly designed crank throw. With the big end bearing hanging out in space.   :loco:
It's not the way the crankshaft ball races wobble, in their oversize housing.  :palm:
Shouldn't the flywheel, and cam, bosses, be level with the top of the pedestal casting?
http://i110.photobucket.com/albums/n95/Dayjo/2015%20Onward/IMG_20150120_135603402_HDR_zpsymyprbwi.jpgScott Vacuum Engine......
The top of the conrod, is a bit close to the cylinder.........
http://i110.photobucket.com/albums/n95/Dayjo/2015%20Onward/IMG_20150120_135653434_HDR_zpsewdznfvl.jpgScott Vacuum Engine......
But, there's rather more clearance, down here.........
http://i110.photobucket.com/albums/n95/Dayjo/2015%20Onward/IMG_20150120_135721257_HDR_zpso57ykyc4.jpgScott Vacuum Engine......
It's desaxe! :palm: Don't think that was a design feature!  :scratch:
The eccentrically cast flywheel, reminds me of a loco wheel.......
http://i110.photobucket.com/albums/n95/Dayjo/2015%20Onward/IMG_20150120_135749674_zpsbyza5vva.jpgScott Vacuum Engine......
Would this improve the looks, at all?
http://i110.photobucket.com/albums/n95/Dayjo/2015%20Onward/IMG_20150115_103841274_zpsbf02gn2u.jpgScott Vacuum Engine......
Oh. Yes! ........ And, I've got a pair of 'em!
http://i110.photobucket.com/albums/n95/Dayjo/2015%20Onward/IMG_20150127_135746340_zpsdkfxdwwl.jpgScott Vacuum Engine......
Still have lots of work to do. And, all winter to do it......
Offline fcheslop
« Reply #67 on: January 28, 2015, 10:00:01 AM »
Sorry meant ball bearings but now see she already has them :Doh:
Yep you like a challenge or two
cheers
« Reply #68 on: February 08, 2015, 04:53:20 AM »
I recognise those fly wheels David  :D
As ever a cracking engine rebuild ,good to see your still bringing them back to life .  :thumbup:
I will see about doing a few flywheels in cast iron for you ,as I will need something to practice on wile getting to grips with the  cupola  :dremel:
« Reply #69 on: February 08, 2015, 05:27:56 AM »
Ahh.... Bless yer, Rob!  :thumbup:
Didn't I always say, yer a gem......
Offline Bangkok Mick
« Reply #70 on: February 08, 2015, 11:13:55 PM »
Great thread, keep up the good work.
Cheers Mick
Offline fcheslop
« Reply #71 on: February 13, 2015, 09:54:55 AM »
Ah so that answers a question.
Very nice casting :thumbup:
http://i981.photobucket.com/albums/ae299/frazerheslop/lever%20engine%20finished/huibsleverenginefinished004_zps6756e83c.jpgScott Vacuum Engine......
Nice going marra.Have you sussed out tuther leg??
cheers
frazer
« Reply #72 on: February 13, 2015, 02:57:51 PM »
Cheers Mick
Thanks Mick!  :beer:
Ah...... Yes! The ancestry shows.......
That's supplied a little hint.......
[Nice going marra.Have you sussed out tuther leg??
cheers
frazer
Well......
I think, I'm going to have to have it off.......   :bugeye:
Plucking up the courage, at the moment.
« Reply #73 on: February 17, 2015, 08:30:39 AM »
Procrastination....... I think, that's the word...... Putting off, the big decision.
I can't keep on, blaming the cold weather. So, I did a couple of gonna do's. For a couple of weeks.
Then I realised, there's probably some more to come. After some more tweaking.
So, I raised the shutter opening higher, (the shadow, shows the original position), and filed the lip to a knife edge.......
http://i110.photobucket.com/albums/n95/Dayjo/2015%20Onward/P1040594_zpsuc2sorq5.jpgScott Vacuum Engine......
Lowered the rear of the wick tubes........
http://i110.photobucket.com/albums/n95/Dayjo/2015%20Onward/IMG_20150216_115639067_HDR_zpstrjuhewq.jpgScott Vacuum Engine......
And...... With the appropriate flame. It worked!
http://i110.photobucket.com/albums/n95/Dayjo/2015%20Onward/IMG_20150216_114931206_HDR_zpsjououpcb.jpgScott Vacuum Engine......
Then, a pal called. With a canyer just?. About a week's work........  :palm:
The extra revs had convinced me. Whatever I do to the crank/ flywheel end, there will be enough power to drive it.
It's time to start, on the big decision!
I need to know the height of the cylinder, from the underside of the base casting.
Don't have a height gauge...... But, this worked!
Two squares. Held square by an engineer's clamp.......
http://i110.photobucket.com/albums/n95/Dayjo/2015%20Onward/IMG_20150217_112133640_HDR_zpsvtp8biyz.jpgScott Vacuum Engine......
Measure the height, with vernier........
http://i110.photobucket.com/albums/n95/Dayjo/2015%20Onward/IMG_20150217_111036348_zpsgyxyt4zp.jpgScott Vacuum Engine......
Subtracting, half cylinder o/d, gives centre height. (Some 3mm lower than present crank height).......
Work is progressing again.......  :thumbup:
« Reply #74 on: February 17, 2015, 08:38:56 AM »
It's great to follow along with each of your improvements, David!
I also like your first picture -- naturally, I think it would make a fine avatar..... :)
