Author Topic: Lathe Tools  (Read 23013 times)
Re: Lathe Tools
« Reply #25 on: June 27, 2013, 08:10:56 AM »
DavidA:
The cross slide on my Sieg C3 which is metric is marked 0.025 mm per division. It is also marked 0.001" which are obviously not equal. I suspect DaveIOM is correct, it is a 2.5 mm pitch leadscrew thread. Treat it as 2.5 mm per turn.
Gary
Mine is the same. The difference in a full turn is not even 2 thou, so rough it close and then measure for your final cut. To make things even more weird, the cross-slide thread on my lathe is specified on the drawing as an imperial OD but metric pitch :)
Re: Lathe Tools
« Reply #26 on: June 27, 2013, 09:41:38 AM »
Pete,
That is more or less what I do.  Here is a picture of my set up.  It's probably more accurate that using a dial.
Offline Trebor
Re: Lathe Tools
« Reply #27 on: June 28, 2013, 07:44:07 AM »
Just found out that I have a mixture of metric and imperial dials and feed screws on my carriage so at the moment I haven't a chance in hell of sorting it out without spending more money.  :palm:
Re: Lathe Tools
« Reply #28 on: June 28, 2013, 11:26:56 AM »
Shouldn't be too hard to fix. Do you know what pitch the screw is, exactly? I put a dial gauge on my cross-slide and measured mine over 1, 2 and 5 turns.
Offline Trebor
Re: Lathe Tools
« Reply #29 on: June 28, 2013, 11:54:01 AM »
I did find out that my feed screws and dial for 1 rotation move tool 2mm metric / 1/8 imp. Tested mine and its already been converted apart from the top dial is imperial. So it's turned out a cheap fix.
Why is my coolant rusting my bed ? That's the next topic !!! lol
Re: Lathe Tools
« Reply #30 on: June 28, 2013, 12:48:30 PM »
Doesn't make sense. 2mm pitch and 8tpi are nowhere near the same.
Re: Lathe Tools
« Reply #31 on: June 28, 2013, 01:19:33 PM »
Trebor,
Got to agree with Pete. Something wrong there.
RE the rust.  Your coolant mix is probably too weak.
Offline Trebor
Re: Lathe Tools
« Reply #32 on: June 28, 2013, 01:35:39 PM »
Well the metric dials are 0 to 40 and imp 0 to 100. I have feed screws that move tool post 2mm on full turn. I did check this before speaking to Myford. I have metric cross feed dial and feed screw, metric top feed screw and imperial dial.
Offline Trebor
Re: Lathe Tools
« Reply #33 on: June 28, 2013, 01:38:53 PM »
sorry about the pictures this is the only site I have trouble loading pictures on !! just got to get used to it.
Re: Lathe Tools
« Reply #34 on: June 28, 2013, 01:47:04 PM »
How far does the topslide actually move for 1 full turn of the dial.  Measures with a dial gauge ?
Offline Trebor
Re: Lathe Tools
« Reply #35 on: June 28, 2013, 02:17:41 PM »
I only have a vernier gauge but on 1 full turn it moves 2mm.
Re: Lathe Tools
« Reply #36 on: June 28, 2013, 03:15:34 PM »
Then if that 40 on the dial was read as 4.0 it would seem to indicate the amount of reduction on the diameter per revolution.  I.e 2 x 2
Anyone agree ?
Re: Lathe Tools
« Reply #37 on: June 28, 2013, 03:25:00 PM »
Yep, direct-reading dial, 2mm travel is 4mm off the OD.
Re: Lathe Tools
« Reply #38 on: June 28, 2013, 03:27:26 PM »
Trebor is the compound slide also 2mm pitch? If it is, for now all you have to do is put some masking tape around the dial and double all the numbers with a felt pen.
Offline Trebor
Re: Lathe Tools
« Reply #39 on: June 28, 2013, 03:38:37 PM »
You have lost me now I'm a novice chap. Both the cross and top slides have the same feed.
Offline garym
  • Manchester, England
Re: Lathe Tools
« Reply #40 on: June 28, 2013, 04:52:40 PM »
Hi Trebor,
Compound slide = top slide on most lathes. Does this help?
Gary
Offline Trebor
Re: Lathe Tools
« Reply #41 on: June 28, 2013, 05:19:56 PM »
Cheers I've learnt something else today  :thumbup:
