Author Topic: 626 Z Axis Feed Nut  (Read 4565 times)
626 Z Axis Feed Nut
« on: September 16, 2012, 04:09:52 PM »
Lads
The Z axis nut on my 626 is badly worn . I have heard tales of the nut failing and the table dropping (narrowly missing the bollocks of the operator)  :jaw: :jaw: :jaw:
I stripped the screw and nut out and was pleased to see a brass sleve in the cast iron nut housing
Simple repair machine a new nut from some propper bronze  :ddb: :ddb: :ddb:
My mill is fitted with a 6 inch riser block (it is possible to wind the table up untill the feed nut disengages
Rob Wilson took one look at it and said "Do a propper job and make a longer screw as well"
The pictures tell the story so far
Next job the new nut
« Last Edit: September 16, 2012, 04:35:31 PM by dsquire »
Offline saw
  • lucky amateur
    • Svenssons AckordsWerkstad
Re: 626 Z Axis Feed Nut
« Reply #1 on: September 16, 2012, 05:15:32 PM »
Nice work  :clap: :clap: :thumbup:
_________________________
Greetings / Benni
« Reply #2 on: September 16, 2012, 05:20:06 PM »
craking job john well dun and posted
« Reply #3 on: September 18, 2012, 12:49:13 PM »
 :thumbup:  Now that looks much better John  :clap: :clap: :clap:
