Author Topic: Improvising a tiny machinist’s jack.  (Read 6105 times)
« on: November 29, 2011, 09:27:30 AM »
I needed to hold a new component up to an existing one, to spot through for bolt holes in the new bit. I couldn't get a clamp on, but a tiny jack would do the job, if it was less than 0.75” high. The problem was easily solved with this:
It’s the threaded jaw from a small parallel clamp, with two M6 bolts in it. The only work involved was a facing cut to remove the raised lettering on the bolt heads. Very stable in use.
Not exactly an life-changing* idea, but I thought I’d pass it on in case anyone else needs it.
* I tried earth-****tering, but look what happened  :lol:
Re: Improvising a tiny machinist’s jack.
« Reply #1 on: November 29, 2011, 01:54:05 PM »
Nicely done Andy - sometimes it's the simple things that are the least obvious...
Ah, the old S***horpe problem... (http://g.co/maps/dhnse - it's a link to google maps)
