Author Topic: Potty Popcorn Engine  (Read 123182 times)
Re: Potty Popcorn Engine
« Reply #100 on: October 16, 2011, 05:26:05 PM »
You made that look easy :bugeye: :bugeye: :bugeye:
Cracking build log
Thanks :clap: :clap:
« Reply #101 on: October 17, 2011, 10:43:36 AM »
Thanks Guys,
Andy I got an headace counting your mates fingers, took me a while spotting what was odd it didn't look like but I was damed if I could spot what.
An extra diget would come in darn handy you could have one finger for scratching your arse and one for picking your nose  :lol:
Its bin awfull getting on the site over the last couple of days, I was begining to fret about it, like losing an arm.
Moving on completed the base.
Measured the centre height to the crank shaft and the piston rods take one from the other and thats what the base needs to be made with mine it came spot on 14mm.
Fly cut a chunk of ally square and to size.
Then marked out uts centre and mark a square to match the base of the cylinder.
Drilled the clamping holes
Then with a 10mm dia ball nosed cutter and the mill head slewed over 20 deg, mill a nice flared foot, working to the lines marked.
This is what it looks like.
« Reply #102 on: October 17, 2011, 10:56:25 AM »
Another bit done the slide valve coupling.
Not many more to do now.
Offline saw
  • lucky amateur
    • Svenssons AckordsWerkstad
« Reply #103 on: October 17, 2011, 11:24:15 AM »
 :bow: :bow: :bow:
I have no words..
_________________________
Greetings / Benni
« Reply #104 on: October 17, 2011, 01:06:16 PM »
Looking lovely Stew ,,,,,,,,,,, sculpture in metal  :med:  :clap: :clap: :clap:
« Reply #105 on: October 18, 2011, 02:34:24 AM »
Thanks Saw/Rob
I should be ready to test it by the end of the week, keep you're fingers crossed.
Brian Rupnow over on HMEN has built an imperialised engine to this this design and got it running.
I won't get much done today though we're looking after our 18 month old grandson, by this evening we'll be completly knackered running round after him.
Ho happy days
 :D :D :D :D :D :D :D
« Reply #106 on: October 18, 2011, 03:09:01 PM »
Managed to get a little done this afternoon whilst the little chap had a sleep.
The valve rod support, I drew it up fancy and didn't think to much on how to make it, but when it came to it, I realized it was quite an awkward shape, I could have redesigned it, but I kind of liked it as is was.  The important part is for the hole to be on the same centre height at the valve rod, so decided it would be easier to make it in two bits and bring it to the correct height by adjusting the base thickness.
With a bit of 10mm brass bar first turned a little 4mm dia chucking piece on the end, then over on the mill drill the hole for the valve stem and mill the flats.
Cut it off to length and centre drill and tap the other end M3, then gripping on the chucking piece, turn the tapered bit.
Sorry pic not very good.
Cut the chucking bit off, and make the base adjusting its thickness to get the correct centre height for the hole.
These are the bits.
I'll whittle that square end sticking up into a round later.
And how its looks.
Just got the base to machine up, but before I'll do that I want to get all the bit loosely fitting together so I can get the positioning correct.
« Reply #107 on: October 18, 2011, 03:28:02 PM »
I love the way you think things through Stew!  :clap: :clap:
And, what you produce after thinking.......  :thumbup:
« Reply #108 on: October 23, 2011, 08:11:40 AM »
Thanks Dave
But I don't think I thought enough about this one:- I've got it running eventualy but it took nearly three days of trying, but persistance tamed the beast in the end.
And the video
http://youtu.be/1QaTBWvG5bs
« Reply #109 on: October 23, 2011, 08:24:08 AM »
YEEeeeee...... HAAaaarrrrrrrr!!!  :D :) :ddb: :ddb:
That's a fine sight to see Stew!  :thumbup:
Congratulations..... Blummin well done!  :clap: :clap: :thumbup:
« Reply #110 on: October 23, 2011, 08:27:25 AM »
Nice one Stew
Runs well & looks great :thumbup: :thumbup: :thumbup:
I am looking forward to the govener build
Offline saw
  • lucky amateur
« Reply #111 on: October 23, 2011, 08:31:36 AM »
Lov it congrat  :clap: :clap:
Greetings / Benni
Offline DaveH
  • Kempton Park, South Africa
« Reply #112 on: October 23, 2011, 09:06:35 AM »
Really good :clap: :clap: :clap:
Very nice :thumbup: :thumbup: :thumbup:
« Reply #113 on: October 23, 2011, 09:32:31 AM »
That's one lovley looking engine with those acents on the cylinder head. Runs pretty darn nice too.  :thumbup:
Nice job Stew. :clap:
Offline AndyB
« Reply #114 on: October 23, 2011, 10:16:22 AM »
Cogratulations and well done Stew :bow: :bow: :bow: :bow: :bow:
Lovely engine doing its lovely thing! :clap: :clap: :clap: :clap:
Saw your Overcrank on YouTube too...what a fabulous sound running slowly!!!! My wife was entranced!!!!
Offline arnoldb
  • Windhoek, Namibia
« Reply #115 on: October 23, 2011, 01:56:52 PM »
Very well done indeed Stew  :bow: :bow:  :clap: :clap: :clap: :clap:
It's a great little runner  :D :D
 :wack: I'm starting to dislike your builds; each time another one gets added to my growing list  :doh:  :lol: :lol:
(:D :D Just teasing mate; keep them coming; you're doing a GREAT job for model engineering :bow: :bow: Thank you very much!)
Kind regards, Arnold
« Reply #116 on: October 23, 2011, 02:03:19 PM »
 :bow: :bow: :bow: :bow: :bow:  well done Stew  :clap: :clap: :clap: :clap:
Sure is a great looking engine  :drool:
very enjoyable thread too  :med:
« Reply #117 on: October 23, 2011, 03:15:50 PM »
Thanks Guys
It was a right son of a bitch to get running it took three days of trying, some of the problems were down to my hamfistedness, I distorted the bore in the cylinder because I was clamping it to the base with over long screws, took me a while to work out why it was getting tighter and tighter, had to run the reamer done the bore to get rid of the tight spots.
And as was pointed out the cylinders were on the short side, I had sussed this out and increase the length by 2 mm, but that was hardly enough, so any of you guys who had the drawings off me make a note to increase the cylinder length by at least 3mm. I had to set the stroke using a depth mic to measure the top of the piston at forward dead centre, I only had about 0.2 mm clearance.
Then I went and seized the main bearings up twice running it in with a Black and Decker, the bearing stands were pulling off line when I tightened then down and causing the bearings to bind, I sorted that by running the reamers through the bearing whilst they were bolted down on the base.
The the connecting rod was just kissing on the cross head guide, just enough to stop it, that had a file taken too it, it was just a case of chasing down the problems one at a time, and being patient.
You never truly understand an engine until you come to put it together and this was no exception, it doesn't like any tight spots at all, it seems to be bedding in OK now getting better and better as it runs, only problem is my compressor is as noisy as hell and it starts the local dogs off barking, so to avoid complaints I only run it for short spells.
Offline NickG
« Reply #118 on: October 26, 2011, 11:55:05 AM »
Nice work Stew, it looks / runs great now! Am tempted to have a go at that one myself but already have a list as long as my arm and no time to do them!
« Reply #119 on: October 26, 2011, 12:10:06 PM »
Well done Stew!!  :thumbup: :thumbup:
« Reply #120 on: October 27, 2011, 04:26:29 AM »
Thanks Nick/Eric
In order to make the body for the governor I need a ball turning attachment, being a bit of a tight wad I didn't want to go out and buy one and I wanted something that would be quick and cheep to build, and I tough of my RT, I hunted around my stash and came up with this lot.
A couple of mornings work and I had got myself a ball turner.
Here's a picture of my balls
 :lol: :lol: :lol: :lol: :lol: :lol: :lol:
Their fly balls for the governor I could have bought some 1/2" brass balls but I wanted to give it a try.
« Reply #121 on: October 27, 2011, 04:31:44 AM »
Now, THAT was well thought through, Stew!  :clap: :clap:
Nice balls, too......  :thumbup:
« Reply #122 on: October 27, 2011, 04:43:49 AM »
Thanks Nick/Eric
Are those off of the Brass Monkey?   :lol: :lol: :lol:
Nice job Stew but I feel sorry for the Monkey.  :lol: :lol:
Offline saw
  • lucky amateur
« Reply #123 on: October 27, 2011, 04:52:16 AM »
Nice work, I like it.  :bugeye:
Greetings / Benni
« Reply #124 on: October 27, 2011, 05:23:50 AM »
Super looking engine, Stew. Look forward to pics complete with balls.
I see from the latest MEW that you are showing it at the Sandown MW Exhibition, along with your elbow engine. It's a good thing I'm not going, or you'd have to chain them down.
Andy.
