Author Topic: Potty Popcorn Engine  (Read 166137 times)
Re: Potty Popcorn Engine
« Reply #150 on: November 10, 2011, 11:12:23 AM »
Dragged myself into the shop today and finished off the bits and bobs for the governor:-
Turned up the jocky wheels and crank shaft pully. No pics
Then made the fly ball arms, I used mild steel
Squared up a block and first drilled the pivot hole 1mm and the corner holes.
http://i431.photobucket.com/albums/qq32/sbwhart/Potty%20Popcorn%20Engine/131_0983.jpgPotty Popcorn Engine
Then with a milling cutter milled one side deep enough to make the two arms, then swiveled the vice round, and milled the angled bit.
http://i431.photobucket.com/albums/qq32/sbwhart/Potty%20Popcorn%20Engine/131_0987.jpgPotty Popcorn Engine
Then split them off with a slitting saw.
http://i431.photobucket.com/albums/qq32/sbwhart/Potty%20Popcorn%20Engine/131_0997.jpgPotty Popcorn Engine
Spent a little time filing them to fit, and filed the end into a rough round then run a M2 die down it.
Drilled and tapped the balls
http://i431.photobucket.com/albums/qq32/sbwhart/Potty%20Popcorn%20Engine/131_0999.jpgPotty Popcorn Engine
I took delivery of some 3mm dia o ring cord this morning that I'm going to use for the drive belt, so time for another hows it going to look shot.
http://i431.photobucket.com/albums/qq32/sbwhart/Potty%20Popcorn%20Engine/131_1001.jpgPotty Popcorn Engine
« Reply #151 on: November 10, 2011, 12:09:15 PM »
Ohh, my.....
« Reply #152 on: November 10, 2011, 02:26:04 PM »
 :bow: :bow: :bow:
« Reply #153 on: November 10, 2011, 08:38:26 PM »
Oh my.   :bow:  :bow:  :bow:  :bow:
« Reply #154 on: November 11, 2011, 11:47:54 AM »
Thanks:- Dave/Saw/Bernd
Ok with my bigger watermark now in place.
Made the manifold.
Started with a bit of brass bar, turn it down to size and part off.
http://i431.photobucket.com/albums/qq32/sbwhart/Potty%20Popcorn%20Engine/131_1006.jpgPotty Popcorn Engine
Then drill and tap one end marked the tap up so i wouldn't go in too deep.
http://i431.photobucket.com/albums/qq32/sbwhart/Potty%20Popcorn%20Engine/131_1007.jpgPotty Popcorn Engine
Turned it round and did the same to the other end and also thread the OD 3/8*32 ME.
Then mark out where the holes are to go, then in the spin-indexer drill the holes 3mm for the couplings, also milled a small flat on the hole position so the coupling would have something to sit square against for soldering.
http://i431.photobucket.com/albums/qq32/sbwhart/Potty%20Popcorn%20Engine/131_1011.jpgPotty Popcorn Engine
Turned up the coupling with a little 3mm  nipple on the end 3mm for a tight fit in the manifold.
http://i431.photobucket.com/albums/qq32/sbwhart/Potty%20Popcorn%20Engine/131_1013.jpgPotty Popcorn Engine
Couplings pressed in.
http://i431.photobucket.com/albums/qq32/sbwhart/Potty%20Popcorn%20Engine/131_1014.jpgPotty Popcorn Engine
Onto the silver soldering just added a little bit of flux, and a few nuggets of solder and heated them up to everything melted in, then into the pickle for 1/2 hr.
Back onto the spinindexer, square up onto one of the coupling pick the hole centres up and drill.
http://i431.photobucket.com/albums/qq32/sbwhart/Potty%20Popcorn%20Engine/131_1015.jpgPotty Popcorn Engine
http://i431.photobucket.com/albums/qq32/sbwhart/Potty%20Popcorn%20Engine/131_1016.jpgPotty Popcorn Engine
Wilst it was in the pickle made the stop valve nut.
Her it all is
http://i431.photobucket.com/albums/qq32/sbwhart/Potty%20Popcorn%20Engine/131_1019.jpgPotty Popcorn Engine
« Reply #155 on: November 11, 2011, 12:18:43 PM »
Nice work.  :clap: :clap:
 :offtopic:
After silverloading what are you using to clean the material  :smart:
« Reply #156 on: November 11, 2011, 12:32:54 PM »
hi Benni
I'm using a Citric acid solution, its used in baking you can get it from suppermarkets, it comes as a powder and you just add it to water to make a strong solution.
« Reply #157 on: November 11, 2011, 01:46:28 PM »
Thank you (it's Citronsyrelösning in Swedish), I will try that next time.  :headbang:
« Reply #158 on: November 11, 2011, 02:39:38 PM »
Hi Stew . :clap: :clap:
The governor looks spot on ,,,,,a cracking bit of machining  :bow: :bow: :bow: :bow: :bow:
I see you managed to fined O ring cord  :dremel:
 :lol: :lol: :lol: are you sure they are your photos  :lol: :lol: :lol:
Rob  :D
« Reply #159 on: November 11, 2011, 04:09:44 PM »
Yes Rob thanks for putting me onto it:- less than £2 for a meter including postage on flea bay.
 :thumbup:
« Reply #160 on: November 13, 2011, 05:25:26 AM »
Finished off most of the fittings for the manifold.
To make the body for the whistle valve just square up a chunk of brass and put a small centre where the coupling will be turned.
http://i431.photobucket.com/albums/qq32/sbwhart/Potty%20Popcorn%20Engine/IMG_3527.jpgPotty Popcorn Engine
Then using the good old wobble bar get it on centre in the four jaw chuck
Turn and thread 1/4*40 and drill through 2mm and part off
Over onto the mill and mill a 3/16 slot across it.
http://i431.photobucket.com/albums/qq32/sbwhart/Potty%20Popcorn%20Engine/131_1028.jpgPotty Popcorn Engine
Drill a 1mm hole for the lever pin
http://i431.photobucket.com/albums/qq32/sbwhart/Potty%20Popcorn%20Engine/131_1030.jpgPotty Popcorn Engine
The lever is made from some 3/16 square mild steel bar, so in the self centering four jaw with the compound slewed over a couple of degrees turn up a nice shaped handle, and part off.
http://i431.photobucket.com/albums/qq32/sbwhart/Potty%20Popcorn%20Engine/131_1031.jpgPotty Popcorn Engine
Drill a 1mm hole for the pivot pin.
Next bit the valve spindle, from a bit of 8mm dia stainless, centre drill and with a running centre turn and thread.
http://i431.photobucket.com/albums/qq32/sbwhart/Potty%20Popcorn%20Engine/131_1034.jpgPotty Popcorn Engine
Flip it round and turn and thread the other end again using a running centre, to turn the cone I used a small fixed steady that I made some time ago it just clamps on the running centre.
http://i431.photobucket.com/albums/qq32/sbwhart/Potty%20Popcorn%20Engine/131_1035.jpgPotty Popcorn Engine
These are the bits
http://i431.photobucket.com/albums/qq32/sbwhart/Potty%20Popcorn%20Engine/131_1043.jpgPotty Popcorn Engine
and assembled
http://i431.photobucket.com/albums/qq32/sbwhart/Potty%20Popcorn%20Engine/131_1038.jpgPotty Popcorn Engine
« Reply #161 on: November 13, 2011, 05:53:49 AM »
Some nice detail work
I like that steady
« Reply #162 on: November 13, 2011, 08:42:50 AM »
I like that little steady rest too. Nice idea.  :thumbup: I'll have to copy it, if it's ok by you Stew?
And very nice work on those little detail items. I need to learn patients to do that.  :med:
« Reply #163 on: November 13, 2011, 08:53:15 AM »
Nice build, I just love your'e small fixed steady  :thumbup: :clap: :clap:
Offline arnoldb
  • Windhoek, Namibia
« Reply #164 on: November 13, 2011, 12:06:41 PM »
Great going Stew  :clap: :clap: - lovely work on the detail  :thumbup:.
 :D I love that steady too - so simple!
 :beer:, Arnold
« Reply #165 on: November 14, 2011, 09:53:09 AM »
Thanks for all your kind comments guys. that little steady I saw some ware and though that's a good idea, so when the need arose I made one, and glad I did.
Next bit up is the union coupling of the manifold to the steam chest, this had to be a naval type coupling otherwise the darn thing wouldn't screw together. The bits were just straight forward machining.
Her they are the little round mushroom bit screws into the square body through the nut its fixed in place with stud lock, tightening the nut onto the union on the manifold tightens onto it an make the seal, hope that made sense  :scratch:
http://i431.photobucket.com/albums/qq32/sbwhart/Potty%20Popcorn%20Engine/131_1049.jpgPotty Popcorn Engine
Also made the oiler as I won't be running on steam its not a proper displacement oiler just a look a like, to use just unscrew the cap put a few drops of oil in screw the cap on tight, turn the air on and it will flush the oil into the cylinders.
Her's a pic of it all assembled onto the engine.
http://i431.photobucket.com/albums/qq32/sbwhart/Potty%20Popcorn%20Engine/131_1053.jpgPotty Popcorn Engine
Starting to look a bit tasty.
Waiting for some 12mm dia thin wall brass tube to be delivered for the wistle, that will be the next bit.
« Reply #166 on: November 14, 2011, 10:16:22 AM »
You're photos is so fine now that I think you can use it as a Christmas card  :lol:
Offline Doc
    • My Youtube Channel
« Reply #167 on: November 14, 2011, 11:05:09 AM »
That is some amazing work Stew simply beautiful!
I really love the looks of that flywheel!
Very very nice Stew keep up the good work!
« Reply #168 on: November 14, 2011, 12:21:58 PM »
I can understand your union coupling.......  :thumbup:
I don't understand how you manage to do the rest of it. Gorgeous!  :drool:
(No, not you Stew...... The engine)!  :palm:
Offline Doc
« Reply #169 on: November 14, 2011, 01:55:35 PM »
Phaaaa ha ha ha
« Reply #170 on: November 14, 2011, 05:32:41 PM »
We need an emticon that shows "mind in the gutter".   :lol:  :lol:  :lol:  :lol:
I know mine was.  :(  :palm:
« Reply #171 on: November 15, 2011, 05:12:22 PM »
Well done Stew, love your steady from the tailstock, I've always wondered how people turn small bar without it flexing ... always get a taper on it, now I know!  :thumbup:
« Reply #172 on: November 16, 2011, 05:05:00 AM »
Thanks for your interest and support chaps.
Got a little done yesterday, I'm rapidly getting to the point with the build when its all about bling.
Made the stop valve handle out of a bit of broom handle, I just hope the boss doesn't notice.
Turned it up in the lathe and recessed it to take  dime, I'll glue it in at final assembly.
This us what it look like.
http://i431.photobucket.com/albums/qq32/sbwhart/Potty%20Popcorn%20Engine/131_1062.jpgPotty Popcorn Engine
« Reply #173 on: November 16, 2011, 09:03:32 AM »
Now I know were that dime went that I lost.   :lol:  :lol:  :lol:
Nice work Stew. That'll be one pretty engine once it's all "blinged up".
« Reply #174 on: November 16, 2011, 11:35:22 AM »
Thanks Bernd
Our daughter brought the dime back from her resent visit to the west coast, I asked her to bring back some us change just for this just job, taking a closer look at it I realized that each state has a different design on the tail side of the coin, some of them a very nice indeed.
Well I've more or less done all the machining work now, its just down to assembling the pulley for the governor and giving it a trial, then it down to some serious bling work.
Last job making the whistle, not much to show in terms of machine set ups most of it was basic stuff and file work, I followed LBSC instruction for making a loco whistle he was very insistent about getting the shape of the throat correct and the disc slot, it came out fine I get a nice sharp note, that set the dogs howling in the area, I was a bit concerned that it would come with a D flatulent note
  :D :D :D :D
http://i431.photobucket.com/albums/qq32/sbwhart/Potty%20Popcorn%20Engine/131_1071.jpgPotty Popcorn Engine
http://i431.photobucket.com/albums/qq32/sbwhart/Potty%20Popcorn%20Engine/131_1072.jpgPotty Popcorn Engine
Her's a few pics of the whistle fitted, I won't post any more pics of the engine now until its all blinged up.
