Author Topic: New Toy  (Read 11559 times)
Offline RichardShute
New Toy
« on: May 09, 2010, 06:10:13 PM »
Here's my (well actually my Dad's) new toy. A Thiel 158 universal mill. At present it's topless, or decapitated depending on you predeliction, as it was more convenient to shift it like that. First is a poorer photo of what it looks like fully assembled complete withthe sexy swivel & tilt table. My Dad seems to have absorbed my preference for this style of mill as I already have a Stanko 676P Russian Deckel-like mill which I rate highly. The Thiel is a bit smaller and a slightly different design and inevitably uses a different tooling mount in the spindle, ho hummmm.
We'll give it a general service and shovel out the swarf, but so far it generally looks in decent nick - a little scoring to the Y-axis ways, but not enough to get sick over. I'll post some more pics as & when it is resurrected.
Richard
Re: New Toy
« Reply #1 on: July 31, 2010, 11:17:21 AM »
Here are some more Thiel photos.
Firstly a decco into the top of the main spindle feed gearbox. There's a lot of gears in there! A nice detail is that the Y-axis feedscrew in also in there so benefits from a constant oil spray. The Y-axis ways are just visible at the top and bottom of the photo as well as the feedscrew inside the gearbox.
We stripped all of the slides apart and cleaned the dovetails as they were full of swarf and general filth. One aspect of the machine is that all the ways are oil lubricated, but it must be administered to 18 individual push on oil nipples scattered around the machine with the inevitable consequence that it was rarely if ever done. A strange contrast to the excellent scheme for the feedscrew noted above. We have now converted all the oiling points to use modern clip on grease nipples and will use a converted grease gun to oil regularly.
Another problem was that the each of the two gearboxes were both empty of any oil. They are built into the main body of the machine, but are in separate isolated chambers. We obviously filled them to the correct level and it was instantly obvious why there was so much oil in the suds tank, the oil ran out almost as fast as we poured it in so we stripped the side panels off to investigate. This is not as simple as it appears because the gear selector slides overlap the lip of the hole preventing the cover from coming straight off. However, the cover cannot be moved sideways to let the selector slides to clear because of the rapid feed actuating shaft passing through the cover. That shaft cannot simply be removed either....
So it's actually a matter of starting from the other side of the machine, remove the plain cover,
remove the cotter pin that locks the power feed actuation shaft to the clutch yoke and withdraw the shaft, making sure not to pull it all the way out or the clutch falls apart into the sump - oh joy!
This the main drive gearbox, the vertical shaft is the output from the power feeds clutch to the Y-axis.
Once we had the covers off, the reason for the leak was obvious. As well as the twelve screws holding each cover on, the designers had thoughtfully added an additional screw in each corner tapped into the cover to jack it away from the face to aid removal. A job that would otherwise be very difficult especially when the face had been sealed with gasket sealant. The trouble was, of course, some clown of a grease monkey had tightened ALL the screws and thus broken the seal, the tighter he made the screws to 'fix' the problem, the worse it go. A quick clean up of the mating surfaces, a wipe round with some Hylomar and it's sorted.
The machine is now just about all back together, just need to sort the wiring which had suffered the less than tender butchery of some psychotic electrician with a machete and a roll of sticky tape.
Richard
Re: New Toy
« Reply #2 on: July 31, 2010, 11:46:12 AM »
That's a nice looking mill. Wish I had the room (and money) for something like that. Good score.
Re: New Toy
« Reply #3 on: July 31, 2010, 03:03:01 PM »
Thanks Eric,
space-wise I suppose I'm lucky, my parents live on a (small) farm so outbuildings for a workshop are not too hard to come by, but the machine has a smaller footprint than a Bridgeport. Price wise, because the name isn't well known it came pretty cheap, GBP450 that's under US$700 with the vice so it's hardly a bank breaker. A Bridgeport would have usually been more and a Deckel a LOT more.
I'll take a couple of photo's tomorrow, now it's all back together with the sexy tilt & swivel table.
Richard
Re: New Toy
« Reply #4 on: August 01, 2010, 05:48:01 PM »
Here's a couple of photos of the machine back together mechanically. Still need to sort the electrics, and at some point also repair/replace the bellows over the X-axis feedscrew. I'm thinking about getting some motor bike fork gaiters as the originals are not available as far as I am aware and I can't face makeing the concertina things myself.
Here is the business side of the machine. One of teh quirks of this style of machine over a turret type is that you generally stand mostly to one side, rather than in front. It just a different perspective and is fine once you are used to it.
This is the boring side, nothing much there. The swivel and tilt table uses taper dowels to quickly restor it to flat and square. Curiously a similar scheme is used on the Stanko to set the vertical head upright, but not on this machine, there is a vernier degree scale whcih is no doubt accurate, but slow compared to peg in a hole.
Re: New Toy
« Reply #5 on: August 01, 2010, 09:20:40 PM »
I like the style of that machine. It has an art deco look to it (which I am heavily into). I have a feeling it would look smart in a shop with a monarch 10EE next to it.
Small farm would be nice to have. My father in-law (RIP) had a nice hobby farm I would have loved to get my hands on. Again, nice find.
Re: New Toy
« Reply #6 on: August 03, 2010, 02:51:46 PM »
Well, Eric...... not a 10EE, but lurking in my shed next door to my Dad's is this:
My contribution to the shared resources. Essentially the same machine as Darren's well documented lathe. And yes, they do make an attractive couple.
Rgds
Richard
« Last Edit: August 03, 2010, 03:25:33 PM by RichardShute »
Re: New Toy
« Reply #7 on: August 03, 2010, 07:26:52 PM »
RichardShute
I have to agree on making an attractive couple. Thanks for showing them to us.
