Author Topic: I made a thing...  (Read 54647 times)
Re: I made a thing...
« Reply #25 on: November 11, 2023, 01:53:31 PM »
What size pilot did you use?
I haven't got round to making a HSS broach for mine yet after my silver steel failures.
« Last Edit: November 12, 2023, 03:29:56 AM by philf »
« Reply #26 on: November 11, 2023, 03:22:07 PM »
Looking good.
What's the pressure like now you have sharpened the tool?
Offline shipto
  • Redditch, UK
« Reply #27 on: November 11, 2023, 05:42:05 PM »
I haven't got round to making a HSS broach for mine yet after my silver steel failures. Lol lol
6mm for a 6mm hex.
Looking good.
The pressure needed at the beginning is very good but adds up as it cuts but I think if I remove that with the drill then take another bite I can get the hex a bit deeper. I will try that tomorrow.
Offline shipto
  • Redditch, UK
« Reply #28 on: November 15, 2023, 01:15:48 PM »
I set it all up and I am quite pleased with the results. however I discovered that the selection of 6mm allen keys I have vary from 5.97mm (the one I measured to get the size of the broach) to 6.05mm which will fit but gets a bit stuck as I made the broach 6.05mm so I might need to make another nearer to 6.1mm.
I have included pics of the setup and end result but my phone is struggling to get a decent close up of the hex itself.
One thing to note is to do with setting the tool, I found it much easier to set when I drilled a slightly oversize hole (6.5mm) in a plate and put it in the mill then turned it by hand and set it until the plate did not move when turning the broach tool rather than trying to clock it up on the lathe.
Offline RotarySMP
  • Country: at
« Reply #29 on: November 26, 2023, 09:29:37 AM »
I found the system extremely sensitive to clearance diameter. Learned the hard way with too small holes :)
Mark
