Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Project Logs
Home
Help
Search
Login
Register
Gallery, Projects and General
Project Logs
oil gun refit
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: oil gun refit (Read 5986 times)
krv3000
Hero Member
Country:
oil gun refit
on:
April 16, 2016, 04:47:35 PM »
hi well did this today I have one of them oil guns I.E the plunger type you no the ones that leek oil all over the place and when you cum to use it its empty so I dismantled it as you will see in the pic the centre tube is held in place by the top edge of the mane body bin bent over with a screwdriver I lifted the lip over to remove the tube in-between two steel cup washers their is a o ring well past its sell by date and a spring so before I replast the o ring I gave the tube a good clean up in side the tube their is fitted a one way valve no way of getting this out with out damaging the tube . the bush on the bottom of the gun was well worn so the end of the mane body had to cum off I thort it my be soldered on to the mane body its not it is just a push fit so after sum bashing I got it off the bush is formed over in the cap so I removed the lip then mad a new one and soldered the new one back in to the cap then I replast the cap I used a two part epoxy to glue the cap back on once all back together I filled the gun up with light oil thinner than watt normally goes in and gave it sum stick I.E pumped the oil gun till it was empty then refiled it and left in the vice over night will see tomorrow if it has leaked right pics
Logged
Jonny
Hero Member
Re: oil gun refit
Reply #1 on:
April 16, 2016, 05:37:58 PM »
A lot of the leaks are due to the thin wall tubing and not being round to seal up against.
Can get away with thicker cross section o rings expanded up, good for 10000psi.
I use an air operated, probably pump in 100bar cleans the debris out of gaps.
Logged
krv3000
Hero Member
Country:
Re: oil gun refit
Reply #2 on:
April 18, 2016, 04:47:59 PM »
well left it over night and no leeks pic
Logged
DMIOM
Hero Member
Country:
Isle of Man
Re: oil gun refit
Reply #3 on:
April 19, 2016, 02:45:37 PM »
Logged
Print
Pages: [
1
Go Up
« previous
next »
Project Logs
oil gun refit
