Author Topic: Nut insert for repair  (Read 13785 times)
Offline Chuck in E. TN
  • USAF Retired
« on: April 12, 2015, 07:05:38 PM »
 John(Doubleboost),
Very neat repair you demonstrated in Sunday Nite Nightcap # 66 (
0iPSQ&index=1). Is there a formula or rule of thumb that lead you to choose 7mm to bore for a M4 nut? Any correlation that can be used for such repairs using SAE nuts?
All the best to you and Debs.
Chuck
Chuck in E. TN
Offline studders
Re: Nut insert for repair
« Reply #1 on: April 13, 2015, 12:16:39 AM »
I've used that method a few times in wood, never occurred to me to use it in aluminumium. One to remember.
Offline studders
« Reply #2 on: April 13, 2015, 11:26:21 AM »
To do this we need to calculate the diameter of a nut ACROSS THE POINTS .........
d = 2*r
w = 2*a
From the diagram, we have,
a = r * cos(x)
so:
2*a = w = 2*r*cos(x) = d * cos(x)
Solving for d,
d = w/cos(x)
For a hexagonal nut, x will be 30 degrees so,
cos(x) = sqrt(3)/2 = 0.866
Finally,
d = w/0.866 = 1.1547 * w
Doubtless that was the very method John used to arrive at 7mm.
I favour the 'guess it and whack it' approach.
« Reply #3 on: April 13, 2015, 11:42:57 AM »
I claim prior invention on this as per my posting in my Fanuc Wire EDM rebuild thread in October 2014  :lol:
(Actually the idea was suggested to me by a poster on the MIG welding forum)
Offline mklotz
  • LA, CA, USA
« Reply #4 on: April 13, 2015, 12:06:02 PM »
I'm sure you do.
Regards, Marv
Home Shop Freeware
Offline bertie_bassett
« Reply #5 on: April 13, 2015, 04:41:41 PM »
To do this we need to calculate the diameter of a nut ACROSS THE POINTS given the conventional width of the nut measured ACROSS THE FLATS.  That diameter, suitably adjusted for an interference fit, will be the size of the recess into which the nut is driven.
Take a look at the canonical circular arc diagram shown below.  In this diagram the desired diameter,  d, will be twice the radius, r.  Similarly, the width of the nut, w, will be twice the apothem, a, shown in the diagram.
d = 2*r
w = 2*a
a = r * cos(x)
so:
Solving for d,
d = w/cos(x)
Finally,
Remember to drill slightly smaller than d so the points of the nut have something to bite into.
Could you not just measure the nut??
« Reply #6 on: April 13, 2015, 04:57:36 PM »
:poke: I'm sure I heard John go through that formula on the video.  I just couldn't understand him. :poke:
« Reply #7 on: April 13, 2015, 05:04:33 PM »
I think he added ten to it to get the factor of 7
« Reply #8 on: April 13, 2015, 05:26:25 PM »
Sorry Lads
No magic formula I measured across the flats and just went with that
The flat bottomed hole it the important bit
I will have a play with different size nuts & post a bit video
Any further DRO installs will be made from steel
« Reply #9 on: April 13, 2015, 10:50:12 PM »
d = 2*r
w = 2*a
a = r * cos(x)
so:
Solving for d,
d = w/cos(x)
Finally,
 :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol:
And then of course apply the technical term "slightly smaller than" to arrive at an exact value.
« Reply #10 on: April 14, 2015, 12:19:26 PM »
 :smart:
 :lol:  PRICELESS !   :lol:
Rob  :coffee:
« Reply #11 on: April 15, 2015, 01:09:28 PM »
d = 2*r
w = 2*a
a = r * cos(x)
so:
Solving for d,
d = w/cos(x)
Finally,
Just checked above with  my book " Math to build on a book for those who build "  close enough  ,but  the book did not cover the "slight smaller factor"  :coffee:
« Last Edit: April 15, 2015, 02:07:16 PM by RobWilson »
