Author Topic: Low buck, multi use rotary fixture homeshop/hobbyist use  (Read 13778 times)
Offline PTsideshow
« on: August 07, 2014, 07:14:47 AM »
Years a ago I was rebuilding Chevy 4 bolt 350's for the trucks me and the kids had seems that had one in the process just in case when you buy and drive older trucks.
I had two of these from HF.
http://www.harborfreight.com/automotive-motorcycle/lifts-stands/1000-lb-engine-stand-69886.html
When the daughter got something else, and the son moved on to Jeeps. I took em apart and put them in the shed. I don't like selling tools as I always seem to need the items 10 minutes after they are driven away!
The son wants to free up the trailer that he hauls is smoker on, for his urban farm and garden biz. so I am welding after assembling one of the HF http://www.harborfreight.com/automotive-motorcycle/trailer-accessories/1720-lb-capacity-super-duty-48-inch-x-96-inch-utility-trailer-with-12-inch-five-lug-wheels-and-tires-94564.html
With the 25% off coupon it was a savings of $180.00 and it is good enough to haul it locally and the cambro boxes along with a supply of the wood, tables and some other small items. The frame steel is about 1/8" thick, and can be modified for his needs with out removing anything parts.
Knowing that most people tend to over load the trailers, just a little ;)  I took the springs up to the local spring joint and had them put an extra leaf in each side. so much easier that after they have been on a while.
I had always thought that the engine stands could make a good light weight home owner/hobbyist Rotary welding/work fixture!
http://i35.photobucket.com/albums/d200/ptsideshow/Tools/WElding%20equipment/IMG_1775.jpgLow buck, multi use rotary fixture homeshop/hobbyist use
http://i35.photobucket.com/albums/d200/ptsideshow/Tools/WElding%20equipment/IMG_1776.jpgLow buck, multi use rotary fixture homeshop/hobbyist use
Both sides
I still have to find some bar stock with holes in them to mount the frame to the engine mounts to replace the C-clamps so it can rotate 360°.
They also have now have a 2,000 pound foldable one http://www.harborfreight.com/automotive-motorcycle/lifts-stands/2000-lb-foldable-engine-stand-69521-8970.html
With the current 25% off coupon from the HF wiki site it brings the price down for the two of them. About $45.00 each a lot better that the import rotaries sold by the car places.
If you have a problem with HF buy them where you want!
Will let you know how it works.:D
Raise the Dead!
        Walk on water!
                 Fix a broken heart!
glen
Offline PTsideshow
Re: Low buck, multi use rotary fixture homeshop/hobbyist use
« Reply #1 on: August 07, 2014, 10:18:49 AM »
I'm sure it would, plus some weight on each since one person turning the item over tends to move one more than the other . Must be the rust have to shoot it with some breakaway to free things up.
http://i35.photobucket.com/albums/d200/ptsideshow/Tools/WElding%20equipment/IMG_1779.jpgLow buck, multi use rotary fixture homeshop/hobbyist use
I marked the center line on each stand and then the end rails to get the balance good.
http://i35.photobucket.com/albums/d200/ptsideshow/Tools/WElding%20equipment/IMG_1777.jpgLow buck, multi use rotary fixture homeshop/hobbyist use
Here are a couple of the brackets I used and on the other side two pieces of expand/holey angle
http://i35.photobucket.com/albums/d200/ptsideshow/Tools/WElding%20equipment/IMG_1780.jpgLow buck, multi use rotary fixture homeshop/hobbyist use
Here is the frame flipped right side up.
This is a good solution for me mostly working by my self. Along with the cherry picker, lift table, motorcycle lift, and the garden tractor hoist/lift I find I can do about any thing I need to do.;)
Raise the Dead!
        Walk on water!
                 Fix a broken heart!
glen
