Author Topic: Extending the cross slide travel on a 7 x 12 mini lathe  (Read 30031 times)
Offline Twinsquirrel
« on: March 29, 2009, 05:01:49 PM »
Well this is something Ive been meaning to do for a while, the cross slide travel is not what it could be on the mini lathe and I often feel I could do with an extra inch or so (no sniggering). The idea came from this site http://warhammer.mcc.virginia.edu/ty/7x10/xslidemod.html
http://i294.photobucket.com/albums/mm108/twinsquirrel/25032009064.jpgExtending the cross slide travel on a 7 x 12 mini lathe
As the first job for my new mill I decided to live dangerously and mill out the excess material on the saddle :dremel:, believe it or not this is how it looked from the factory  :scratch:
http://i294.photobucket.com/albums/mm108/twinsquirrel/25032009065.jpgExtending the cross slide travel on a 7 x 12 mini lathe
And after a bit of judicious metal murdering just enough material was removed to allow the full length of the screw to be used..
http://i294.photobucket.com/albums/mm108/twinsquirrel/29032009079.jpgExtending the cross slide travel on a 7 x 12 mini lathe
Heres a few boring pics of turning the spacer..
Finishing cut, 34mm
http://i294.photobucket.com/albums/mm108/twinsquirrel/25032009068.jpgExtending the cross slide travel on a 7 x 12 mini lathe
Parting off, total length of spacer 25mm, I know I shouldn't really use the live center to support the workpeice when parting but I find it easier that way. BTW the new taper bearings in the lathe have greatly increased my confidence when parting...look I even managed to take a pic while parting!!
http://i294.photobucket.com/albums/mm108/twinsquirrel/25032009070.jpgExtending the cross slide travel on a 7 x 12 mini lathe
I got a bit over-excited and forgot to take any pictures of the milling but here is the finished part..
http://i294.photobucket.com/albums/mm108/twinsquirrel/29032009072.jpgExtending the cross slide travel on a 7 x 12 mini lathe
And here it is mocked up on the lathe..
http://i294.photobucket.com/albums/mm108/twinsquirrel/29032009076.jpgExtending the cross slide travel on a 7 x 12 mini lathe
The only thing left to do is extend the shaft on the cross-slide screw then I should be good to go..
David
« Last Edit: March 30, 2009, 04:41:17 PM by Twinsquirrel »
Re: Extending the cross slide travel on a 7 x 12 mini lathe
« Reply #1 on: March 29, 2009, 06:30:59 PM »
I hope they've got those rats trained better these days  :ddb:
That's some very nice work so far David. What do you mean by "extend the shaft on the cross-slide screw"
I suppose you will show us soon enough?  :thumbup:
Offline cedge
« Reply #2 on: March 29, 2009, 10:24:01 PM »
TS...
That was one of the best mods I ever made to my little 7x14. Adding onto the lead screw and stepping up to a 5 inch chuck made it all work together. The lead screw mod was no big deal. I ordered a spare from Little Machine Shop, cut off what I needed and then drilled and reamed the end of the original to accept a turned down end on the new one (light interference fit).  I secured the joint with red loctite and used the bronze lead screw nut to align the thread ends.  I bit of hand dressing with a small jeweler's file quickly had things moving quite smoothly.
I seriously doubt you'll ever regret this one. You'll certainly be nicelyy surprised by how much added capability you've gained.
« Reply #3 on: March 29, 2009, 10:43:33 PM »
Nice work David.
The confidence to do things like this gives you greater scope in getting your little basic lathe into a much more versatile machine. A tweak here and a fiddle there will make it into a totally different machine from basic.
Don't let how tut-tut's do things stop you from doing what YOU want to do, ie tailstock centre. If it works for you, use it, you are the one doing the job, no-one else.
As long as you are not creating a safety issue by doing it, then it is OK.
« Last Edit: March 30, 2009, 04:01:32 AM by bogstandard »
« Reply #4 on: March 30, 2009, 03:55:51 AM »
Well done that man  :clap: :clap: :clap:
Using the centre when parting is OK I do it myselve from time to time when sercumstances demand it, you just have to be carfull at the last little bit I back the centre off to let the job drop away.  :headbang:  :headbang:
Have fun
« Reply #5 on: March 30, 2009, 02:31:52 PM »
I'm glad you guys didn't shout at me for the live center/parting thing. I know it's silly but I'm a little wary of showing my setups sometimes in case I'm doing something stupid. I always think safety first though.
Darren,
This is the shaft that needs extending to accomodate the spacer.
http://i294.photobucket.com/albums/mm108/twinsquirrel/29032009077.jpgExtending the cross slide travel on a 7 x 12 mini lathe
Steve,
Am I right in thinking that you extended the threaded part of the shaft? I was thinking of just extending the non threaded part as I will not be fitting a bearing?
« Last Edit: March 30, 2009, 03:15:10 PM by Twinsquirrel »
Offline shoey51
« Reply #6 on: March 30, 2009, 04:28:16 PM »
great job there Steve
I wouldnt be game to do that to mine
« Reply #7 on: March 30, 2009, 04:39:10 PM »
Shoey,
Nothing ventured nothing gained eh? He who dares, wins Rodney.
David
Offline cedge
« Reply #8 on: March 30, 2009, 05:23:51 PM »
TS...
The shoulder flange of the lead screw goes between the old and new parts. You'll want to add on to the threaded end.
« Reply #9 on: March 30, 2009, 05:28:03 PM »
ah I see, I've counterbored the new spacer to keep the shoulder in its original position, I thought this might work?
David
Offline cedge
« Reply #10 on: March 30, 2009, 08:05:19 PM »
David
Seems like a lot of work to reach around one's thumb to touch one's elbow...(grin). The mod has been successful untold numbers of times. Reinventing the wheel seems a little like a lot of work only to get unproven results.
« Reply #11 on: March 31, 2009, 03:18:36 AM »
Noted Steve, I have ordered a new screw but in the meantime I may have a go with my original idea as I can easily change tack if it all goes south.
I guess Im just a rebel without a clue  :hammer:
David
« Last Edit: March 31, 2009, 03:45:09 AM by Twinsquirrel »
Offline winklmj
« Reply #12 on: May 18, 2010, 02:14:11 PM »
So how'd it go with this mod. I've started a similar mod this weekend. I'll be adding a ball-bearing as well similar to the mod on GadgetBuilder's site.
Mike
Offline Sorekiwi
« Reply #13 on: May 18, 2010, 09:15:32 PM »
Its been 4 or 5 years since I did this same mod on mine, so the details are a little "fuzzy".  But I think I left the leadscrew in its origional location, and turned up an extension for the unthreaded end of the screw.  I also added a ball bearing in the extension spacer.
I could go out to the shed and look at the lathe, but its cold and raining tonight, and I think there are monsters out there...
« Last Edit: May 18, 2010, 09:17:25 PM by Sorekiwi »
Mike, expat Kiwi in NE Ohio, USA
« Reply #14 on: May 19, 2010, 02:44:53 AM »
There's another, very similar, recipe for extending the cross-slide travel on here:
http://mikesworkshop.weebly.com/cross-slide-extended-travel.html
by Mike Cox, who had the idea for the swing-up toolholder for threading. At the end, he reckons it could have been done without milling out the slide. There's a mod for extending the top-slide travel on there, too.
Mike has only just started his site, but it will be worth keeping an eye on it if you are into improving your mini-lathe; I know there are things like a T-slotted cross-slide to come.
