Author Topic: How do I scribe a taper?  (Read 13095 times)
Offline DarrenUK
« on: March 01, 2014, 01:19:29 PM »
Can anyone suggest a tool or a quick easy way that I can use to scribe a straight line down the centre length of a tapered bar?
I know I could measure and mark each end at the centre then just use a straight edge to scribe but would like to find a quicker alternative method.
Red line on image below is where I want to scribe.
Re: How do I scribe a taper?
« Reply #1 on: March 01, 2014, 01:42:10 PM »
Mount it between centres on a lathe and use a height gauge scriber along the top of a piece of bar held in a toolpost at centre height.
« Reply #2 on: March 01, 2014, 05:37:23 PM »
I like that idea Pete!  :thumbup:
Offline DarrenUK
« Reply #3 on: March 02, 2014, 03:01:52 AM »
Forgot to mention, I have no lathe, just a small SX2 milling machine and a few basic tools.
Offline angus
« Reply #4 on: March 02, 2014, 03:24:43 AM »
how accurate does it need to be ???
use some marking out blue
dirty way put in a vice holding the ends, the holding a spirit level, and looking at the bubble drag it along the top edge
will be fairly close, but maybe not close enough for what you want ?
Offline ieezitin
« Reply #5 on: March 02, 2014, 08:06:51 AM »
Darren
put on a surface plate build up smallest end with gage blocks (mill one since you have a mill)...you could use adjustable parallels,  You could use a sine bar get the angle and lay it top to tail on it.
Without some tooling its not easy to do.
Anthony.
Offline ausdier
« Reply #6 on: March 03, 2014, 09:51:49 AM »
Reply #9 over here I think is a good simple answer.
http://www.modelenginemaker.com/index.php/topic,3285.0.html
