Author Topic: Holding square stock in a three jaw chuck  (Read 25599 times)
Offline macbrat
« on: February 03, 2014, 12:21:39 PM »
I know this topic has had various solutions posted in the past. My method for turning between centres, which I haven't seen covered to date, is:- Use an appropriate socket from a standard socket spanner set. They need to be the type that has 12 splines (designed to accommodate hex and square nuts/bolts). These usually cover sizes up to about an inch or so square. This will of course require a centre bit hole drilling in the tail stock end. Hope this tip helps.
Re: Holding square stock in a three jaw chuck
« Reply #1 on: February 03, 2014, 12:29:33 PM »
Ooohh...... I like that tip!   :clap: :clap:
Thanks, McB.   :thumbup:
Would you like to put a few lines about yourself, in the Introductions Section?
Offline macbrat
« Reply #2 on: February 03, 2014, 12:40:14 PM »
Thanks for your rapid response David. That was my first post on MadModder. Where do I find the 'Introduction Section'?
Offline macbrat
« Reply #3 on: February 03, 2014, 12:46:34 PM »
Just found it David - will write a few words. Thanks for the suggestion.
« Reply #4 on: February 03, 2014, 02:07:06 PM »
For rough-holding of square stock in a 3-jaw chuck I use a split collar. I turn a collar from scap ally of which the ID is the same as the square's diagonal distance, wall thickness 3-4mm, then I cut a 2-3mm slit in it and slide it over the square stock. All you have to do is make sure you don't grip the split bit right on the jaw.
« Reply #5 on: February 03, 2014, 02:20:17 PM »
I use Er32 collets over 6mm they have 8 slots and are pretty mutch spot on , they just click into the slots and don't move .
Offline mechman48
« Reply #6 on: February 07, 2014, 06:02:40 AM »
Hi & welcome  :wave:
Have always used the split collar method myself but I like your idea  :clap: next time I need to use square bar I'll give it a try  :thumbup:
George
George.
Offline Arbalist
« Reply #7 on: February 07, 2014, 06:21:15 PM »
Nice idea macbrat!
Offline MetalMuncher
« Reply #8 on: February 18, 2014, 11:22:21 AM »
These are clever ideas!  :thumbup:
Offline clevinski
« Reply #9 on: February 19, 2014, 07:35:46 AM »
Very creative solution!
Thanks,
Charlie
Offline rotorhead
« Reply #10 on: February 28, 2014, 04:17:47 AM »
Hi McB
That is a very welcome and intuitive introduction, well done that MadModder.
Sunny Scunny,
North Lincolnshire.
Offline unioncreek
« Reply #11 on: April 24, 2014, 03:51:01 PM »
I'm with everyone else on the split collar.  I make them up as I go and then put them in a drawer for next time I need one close to that size.
Bob
