Author Topic: Temper steel dowel pins  (Read 13130 times)
« on: December 28, 2013, 04:17:37 PM »
Lads
I have some parallel steel dowel pins
They are that hard if you put one in a vice and hit it with a hammer it will snap
I put a few in the log burner last nite , (also great for drying welding electrodes)  this morning they can be filed and machined  :drool: :drool: :drool: :drool:
Would I just re temper it with water like silver steel (drill Rod)
Or do I need Sperm oil  :jaw: :jaw: (10 40)
I am wanting to make a centre punch for a video project
Regards
Re: Temper steel dowel pins
« Reply #1 on: December 28, 2013, 04:42:32 PM »
Lads
Or do I need Sperm oil  10 40
Regards
I think oil hardening would be safer. I use old vegetable oil with silver steel and similar steels and it gets plenty hard enough for making cutting tools. (I usually temper them in the deep fat fryer! but I think you would need to temper at a higher temp for a centre punch or else it would be too brittle.)
I have found some hardened dowel pins which are in 100CR6 steel. This needs heating to 840C before quenching in oil.
Hope this helps.
Cheers.
« Reply #2 on: December 28, 2013, 05:05:57 PM »
you have several, why not experiment, test in water and oil?
« Reply #3 on: December 28, 2013, 05:30:40 PM »
hi john if its the ones from me witch i think they are you need oil to put them in we just reharden them the same as silver steel
« Reply #4 on: December 28, 2013, 05:32:49 PM »
Thanks Bob
I have put a few more in the fire
Like Mathew suggests I will have a bit experiment
« Reply #5 on: December 29, 2013, 01:28:06 AM »
Here in the U.S., plain steel cylindrical dowel pins are most commonly LC steel that has been case hardened.  You may be able to reconstitute the case by heating & quenching, but that would be drawing to an inside straight.  Stainless steel cylindrical dowel pins are either (Austenitic) hard drawn, (Martensitic) hardened & tempered, or precipitation hardened -- making home retreating a crap's shoot at best.
The problem with a reconstituting a case hardened part is that the heating for hardening often (usually) dissipates the carbon (decarburizing) to surrounding areas reducing the ability to get a hard surface.
« Reply #6 on: December 29, 2013, 04:04:36 AM »
Hi John I bought some H S S drill blanks ages ago have soffend some bent and retempard them , coat them with likuid soap berore heating stops them going black , I quench in used engine oil that I use for oil blacking (the price is right) , looking forward to the video .
