Author Topic: Tapping Stand  (Read 36712 times)
Offline Dan The Man
  • How did they build the first Lathe????
Tapping Stand
« on: December 22, 2013, 08:03:05 AM »
This post will be my first attempt at a Project Log :doh:
We will try to Turn a 22.5" Ferm pillar drill into a tapping stand.
We have already take the electric's off and now struggling with taking off the front pulley, any ideas??
« Last Edit: December 24, 2013, 01:39:55 AM by dsquire »
Offline wheeltapper
  • Spixworth Norfolk
Re: Tapping Stand
« Reply #1 on: December 22, 2013, 08:06:21 AM »
Look for a setscrew hidden at the bottom of one of the belt grooves.
Roy.
Offline Dan The Man
Re: Tapping Stand
« Reply #2 on: December 22, 2013, 08:07:56 AM »
Yes - Already removed with Allen Key - Still tight to remove :lol:
Re: Tapping Stand
« Reply #3 on: December 22, 2013, 08:09:23 AM »
Warm it up with a hot air gun and use a puller....generally works....
Offline Dan The Man
Re: Tapping Stand
« Reply #4 on: December 22, 2013, 08:16:42 AM »
Good idea, will borrow a puller on Monday   :D
Re: Tapping Stand
« Reply #5 on: December 22, 2013, 10:07:54 AM »
You might check there aren't 2 screws in there. Not uncommon to have one on top of the other in a 'locking' arrangement.
BTW Any reason why this is in ' Announcements & Issues' Shows etc??
Offline Dan The Man
Re: Tapping Stand
« Reply #6 on: December 22, 2013, 10:15:33 AM »
Sorry didn't realise anyway of fixing?   :Doh:
Re: Tapping Stand
« Reply #7 on: December 22, 2013, 10:18:46 AM »
Doesn't really matter much I think ... MODs'll shift it if they want to.  :thumbup:
Offline Dan The Man
Re: Tapping Stand
« Reply #8 on: December 22, 2013, 10:24:37 AM »
anyone know how to get pics were you want not just at bottom? sorry im new
Offline Dan The Man
Re: Tapping Stand
« Reply #9 on: December 22, 2013, 10:29:23 AM »
Johns Idea worked but instead of using a puller we levered it away with screwdrivers
« Last Edit: December 24, 2013, 01:40:59 AM by dsquire »
Offline Dan The Man
Re: Tapping Stand
« Reply #10 on: December 22, 2013, 10:34:10 AM »
We then took away the safety shield
« Last Edit: December 24, 2013, 01:41:49 AM by dsquire »
Offline Dan The Man
Re: Tapping Stand
« Reply #11 on: December 22, 2013, 10:38:20 AM »
On this drill the coil is too strong to push from above so we need to take it out and weaken it
« Last Edit: December 24, 2013, 01:43:06 AM by dsquire »
Offline Dan The Man
Re: Tapping Stand
« Reply #12 on: December 22, 2013, 10:41:22 AM »
We then took off 2 of the 3 handles. I saw that we could use them on our lathe, as the tool change block needs a thin but strong item to tighten it and offen they bend and we need to make new ones.
« Last Edit: December 24, 2013, 01:44:07 AM by dsquire »
Re: Tapping Stand
« Reply #13 on: December 22, 2013, 11:50:28 AM »
Hi Dan,
See http://madmodder.net/index.php/topic,607.msg2864.html#msg2864
The method requires that your photos are hosted somewhere on the web (e.g. Photobucket).
Cheers.
Offline Dan The Man
Re: Tapping Stand
« Reply #14 on: December 22, 2013, 12:56:06 PM »
Thank You will try it
Offline Dan The Man
Re: Tapping Stand
« Reply #15 on: December 22, 2013, 02:24:27 PM »
Right so we had a redesign instead of weakening the spring we just took it off
« Last Edit: December 24, 2013, 01:44:59 AM by dsquire »
Offline Dan The Man
Re: Tapping Stand
« Reply #16 on: December 22, 2013, 02:27:02 PM »
Then we put the case back on as a washer
« Last Edit: December 24, 2013, 01:45:59 AM by dsquire »
Offline Dan The Man
Re: Tapping Stand
« Reply #17 on: December 22, 2013, 02:28:49 PM »
We then realised that on the upstroke it would tighten so we had 2 put on 2 washers and lock them
« Last Edit: December 24, 2013, 01:47:01 AM by dsquire »
Offline Dan The Man
Re: Tapping Stand
« Reply #18 on: December 22, 2013, 02:30:08 PM »
also the chuck is rusted and no pics sorry :worthless:
Offline Dan The Man
Re: Tapping Stand
« Reply #19 on: December 22, 2013, 02:30:52 PM »
Day 1 over :(
Re: Tapping Stand
« Reply #20 on: December 22, 2013, 02:52:05 PM »
Hi Dan
                  Looks just the right size for a tapping stand, good luck with the project.
Offline kayz1
Re: Tapping Stand
« Reply #21 on: December 22, 2013, 03:58:35 PM »
Good idea that man, i have just bought myself a bigger drill so the little Machinemart job ( same as yours different colour ) will do the job..
I will be following with interest.
 Lyn.
Offline nel2lar
Re: Tapping Stand
« Reply #22 on: December 22, 2013, 04:06:26 PM »
Dan
Nice work, keep us up on all your mods. A tapping stand can be used for more than tapping.
Nelson Collar
Offline Dan The Man
Re: Tapping Stand
« Reply #23 on: December 23, 2013, 04:38:19 AM »
Start of day 2 :)
Offline Dan The Man
Re: Tapping Stand
« Reply #24 on: December 23, 2013, 04:43:17 AM »
Warning: :offtopic: This is just a sub project. My full project is making Sbwharts or Stew's Lathe only engine. Just finished theturning on the eccentric yesterday just some holes left , here are some pics  :offtopic: :Warning
« Last Edit: December 24, 2013, 01:48:17 AM by dsquire »
