Author Topic: Potty Vertical Cross Single  (Read 46235 times)
« on: December 21, 2013, 07:26:13 AM »
Just started on building a Vertical Cross Single, its very loosely based on the Kenion Engine that can be seen at the Northern Mill Engine Society at Bolton http://www.nmes.org/ I've designed it along the lines of the simple horizontal engine that can be made with limited equipment and has a lot of parts common to or similar to this engine.
This is my progress to Date
http://i431.photobucket.com/albums/qq32/sbwhart/Vertical%20Cross%20Single/DSC00765_zps3108e83f.jpgPotty Vertical Cross Single
If any one would like a copy of my V1 drawings just send me a PM with you're email address and I'll fix them up, but at the moment this is very much a work in progress so the drawings will change.
Offline Dan The Man
  • How did they build the first Lathe????
Re: Potty Vertical Cross Single
« Reply #1 on: December 21, 2013, 05:05:23 PM »
 :mmr:
Go for it Stew - We will be watching this one closely. Christmas Dinner in the Shed?
Dan
Offline billmac
« Reply #2 on: December 22, 2013, 12:07:25 PM »
Stew-
I will be watching this with a lot of interest. You may be aware that we (NMES) have recently done a lot of work on the valve gear on the Kenyon engine, which was getting a bit sloppy in places. It has a double slide valve on the high pressure cylinder, one of which provides a variable cut-off for steam economy. The linkage to achieve parallel motion is quite interesting and I see that you have this feature in your design.
I'm not sure about the 'cross' bit in your engine description; are you thinking of adding a second cylinder?
We have steam days on Saturday 28 and Sunday 29th December for anyone who would like to see this engine running (and all the others). Free admission, children with adults are very welcome. A visit might make a welcome alternative to endless turkey, TV and computer games?
« Reply #3 on: December 23, 2013, 01:47:14 AM »
Hi Bill
I've been quite a regular visitor to the museum I'm hoping to go next week end but may not make it due to an illness in the family.
The Lumb cut off is one of the things that I like about the Kenyon but I'm afraid I've simplified that out of this model, I did try drawing up a more detailed engine some time ago but to get the detail, it would have ended up to large an engine for me.
I have thought long and hard about adding a second cylinder it shouldn't be to difficult to do but I'm building it as part of a series of simple engines for the beginner based around common  parts that I've been writing up for Model Engineer, so I'm keeping it as a single. I think I have a bit of a cheek even calling it a model of the Kenyon engine because I have simplified it so much but it should show Phineas Crowther  parallel motion off well.
Thanks for your interest
« Reply #4 on: December 24, 2013, 04:20:39 AM »
Fished off some more parts, I was a bit unsure how to make the valve stem support I wonted a design that could be made without a mill I hit on the idea of using some cold drawn angle I had.
These are the parts
http://i431.photobucket.com/albums/qq32/sbwhart/Vertical%20Cross%20Single/DSC00788_zps3b8363d3.jpgPotty Vertical Cross Single
I like the look of it.
http://i431.photobucket.com/albums/qq32/sbwhart/Vertical%20Cross%20Single/DSC00794_zps982c7b3a.jpgPotty Vertical Cross Single
I'll slap a bit of JB weld on it so it looks more like a casting. It won't be easy to adjust the valve events but I'll deal with that when I get.
to it.
Just given my shed its pre Christmas clean out and oiled my machines so that me closed down for the holiday.
All have a good Christmas
« Reply #5 on: January 01, 2014, 01:32:45 PM »
Herr's wishing you a happy a prosperous new year.
Got a few more parts made, the swing arms took a little creative thinking I want this engine to be within the capabilities of a Newbie with a modestly equipped shop, the holes in the swing arms need to be symmetrical with them selves and with each other, I started off by first centre drilling a pip on the end of each arm I then marked them out to give a guide as to where to cut away the meat,
 I then drilled the centre 4mm hole, then pinned the two arms together with a 4mm dowel I then drilled one 3mm hole all the way through both arms, I then swivelled the top arm 180 deg and used it as a guide to drill the second hole in the bottom arm, flip them over and do the same to the other arm this way they must have the same centre distance and be symmetrical to each other.
http://i431.photobucket.com/albums/qq32/sbwhart/Vertical%20Cross%20Single/DSC00804_zps5c447194.jpgPotty Vertical Cross Single
http://i431.photobucket.com/albums/qq32/sbwhart/Vertical%20Cross%20Single/DSC00808_zps522e5add.jpgPotty Vertical Cross Single
Then into the four jaw and supported on the centre chew away the unwanted bits, then cut off the pip and finish off to shape with filing buttons.
http://i431.photobucket.com/albums/qq32/sbwhart/Vertical%20Cross%20Single/DSC00815_zps0ce0bd7e.jpgPotty Vertical Cross Single
This is how its looking
http://i431.photobucket.com/albums/qq32/sbwhart/Vertical%20Cross%20Single/DSC00821_zps190be0d1.jpgPotty Vertical Cross Single
« Reply #6 on: January 23, 2014, 04:22:35 AM »
Time for a bit of an update
I fabricated the fly wheel from a bit of 41/2" welded tube a length of 1" bar drilled and formed into a circle with slip rolls a hub and some spokes
http://i431.photobucket.com/albums/qq32/sbwhart/Vertical%20Cross%20Single/DSC00899_zps64e4c60e.jpgPotty Vertical Cross Single
http://i431.photobucket.com/albums/qq32/sbwhart/Vertical%20Cross%20Single/DSC00916_zpsbebb3496.jpgPotty Vertical Cross Single
Also more or less got all the work done on the cylinder
http://i431.photobucket.com/albums/qq32/sbwhart/Vertical%20Cross%20Single/DSC00912_zps2568f8ab.jpgPotty Vertical Cross Single
And the crank and eccentric
http://i431.photobucket.com/albums/qq32/sbwhart/Vertical%20Cross%20Single/DSC00913_zpsc0bdfd48.jpgPotty Vertical Cross Single
Just got the base and the top to do.
Offline Chuck in E. TN
  • USAF Retired
« Reply #7 on: January 23, 2014, 08:35:53 AM »
Looking good, Stew. Nice work. I like the flywheel.
Chuck
Chuck in E. TN
Offline Doc
    • My Youtube Channel
« Reply #8 on: January 23, 2014, 11:04:28 AM »
Nice that is a beautiful flywheel very nice!
And that valve stem support I LIKE it is looking like a cast piece, nice work.
Offline billmac
« Reply #9 on: January 23, 2014, 11:12:32 AM »
Congratulations on your progress. The flywheel looks very good; the proportions are very reminiscent of the original. (http://www.nmes.org/) That flywheel is about 14 feet diameter and its 'presence' makes itself felt if you stand under it with the engine running.
You may have noticed the two black marks running around the outside of the flywheel. They are nothing to do with the original design, but a side-effect of the motor drive we use to turn the engine when not using steam. They are the rubber from a pair of car tyres that drive the flywheel.
The original engine looks to me like a collection of clever ideas all put together in one machine. There is the parallel linkage (an interesting job to erect in the original engine!), the Mercury cups liked to the governer linkage, the Lumb trip etc. etc.
« Reply #10 on: January 24, 2014, 01:39:16 AM »
Hi Bill
When I first saw the engine "running" at Bolton with that motor drive on the fly wheel I thought they couldn't get it going on steam:- how wrong I was. As an engine it has got a look of evolving over time, I would love to model that Lumb trip gear but I just couldn't get it down to a size that I could make and having it look, it would be just to big. I can't really claim this is a model of the Kenion engine as I've taken huge liberties in order to keep it simple for a newbie to make, and I've only given it one cylinder, but adding a second cylinder shouldn't be too difficult.
Offline billmac
« Reply #11 on: January 24, 2014, 12:19:33 PM »
I think it will make a really nice engine just the way you have planned it.
I agree about the 'evolving over time' description. It looks to me like a series of possibly good ideas that got tacked on as time passed. Quite a few of our engines have been modified in their past working lives. McNaughting beam engines was quite popular at one time and we have an example of that type of modification, as I am sure you know. The McNaughting leaves the engine looking fine in my opinion, but the Kenyon engine does have the look of 'bits everywhere' to me.
The Kenyon engine runs on steam very well, especially after our latest overhaul, but it does use quite a bit of steam so we can't run it for very long with our single boiler. The motor drive does work very well - we have recently added an inverter for the motor drive, which is noticeably smoother starting and doesn't remove quite as much tread from the tyres.
« Reply #12 on: February 01, 2014, 12:37:41 PM »
Thanks for your interest in my project Bill I visit the Museum from time to time hopefully we will meet up for a natter.
Any way I've got it running
Its a bit noisy but that will tune out bits are catching or have an headache but nothing that a bitter of fitting can't sort.
Its on a test base at the moment I want to fit it to a tile effect base,
http://i431.photobucket.com/albums/qq32/sbwhart/Vertical%20Cross%20Single/DSC00928_zps1828589d.jpgPotty Vertical Cross Single
I'm also going to make valve for it.
« Last Edit: February 01, 2014, 01:39:59 PM by dsquire »
« Reply #13 on: February 01, 2014, 01:42:21 PM »
Very nice runner that you have there.  :D :D
Offline BaronJ
  • Grumpy Old Git !
« Reply #14 on: February 01, 2014, 03:26:59 PM »
Mmm...  Nice video.  That's one engine I'd like to have a thrutch at.  Any plans kicking about ?
Best Regards:
                     Baron
« Reply #15 on: February 02, 2014, 01:53:48 AM »
Thanks for your input Chaps
Baron:- Its my own design I have drawn it up but they need revising, I change things as I go along, I'll make the finished drawings available to those who want them:- so just keep watching and ask me the ? again when I have it all finished.
Thanks again
Offline BaronJ
  • Grumpy Old Git !
« Reply #16 on: February 02, 2014, 12:53:14 PM »
Thanks again
Hi Stew,
Will do.  Watching with interest.  Thanks:
Best Regards:
                     Baron
« Reply #17 on: February 10, 2014, 12:30:56 PM »
Well I've got it finished, struggled a bit with the wooden base, when it comes to woodwork I'm no Chippendale
 (I don't do exotic dancing either  :D)
http://i431.photobucket.com/albums/qq32/sbwhart/Vertical%20Cross%20Single/DSC00968_zpse956546f.jpgPotty Vertical Cross Single
http://i431.photobucket.com/albums/qq32/sbwhart/Vertical%20Cross%20Single/DSC00971_zpsf45bad49.jpgPotty Vertical Cross Single
And her's the video
« Last Edit: February 10, 2014, 03:03:02 PM by Stilldrillin »
Offline millwright
  • Leeds West Yorshire
« Reply #18 on: February 10, 2014, 02:54:04 PM »
Looks great Stew, and runs nice and.
 slowly. what did you use for the tile effect on the base.
« Reply #19 on: February 10, 2014, 03:01:47 PM »
Another beauty Stew!  :clap: :clap:
Love how the parallel linkage works.  :thumbup:
« Reply #20 on: February 11, 2014, 01:46:09 AM »
Hi John
I cribbed the tiling method from Jason he used it to make the base for his Benson engine.
Basically what you do is paint a lump of high density chip board with the base colour in my case this was white, then you cover the whole lot with frog masking tape then you simply mark it out and remove the bit of tape where you want it to be black, you then spray the whole lot black let it dry and then pick off the bits of tape to give the black and white tile effect.
http://i431.photobucket.com/albums/qq32/sbwhart/Vertical%20Cross%20Single/DSC00909_zpsbd984384.jpgPotty Vertical Cross Single
Cheers Dave:-
My show self is starting to get a little crowded  :thumbup:
« Last Edit: February 11, 2014, 03:41:27 AM by Stilldrillin »
« Reply #21 on: February 11, 2014, 03:43:16 AM »
Cheers Dave:-
My show shelf is starting to get a little crowded  :thumbup:
Yes, but. What a crackin' display at, Showtime.  :clap: :clap:
Especially with a little exotic dancing.......  :thumbup:   :lol: :lol:
Offline millwright
« Reply #22 on: February 11, 2014, 03:45:20 PM »
Thaks Stew,
 i must of missed that or not taken on board, a brain fart no doubt.
Offline BaronJ
  • Grumpy Old Git !
« Reply #23 on: February 13, 2014, 08:51:21 AM »
That looks very nice !  I would love to have it on my display shelf.
Best Regards:
                     Baron
« Reply #24 on: February 16, 2014, 04:53:32 AM »
I've got the drawings up to date, if any one would like a copy just send me a PM with your email address and I'll forward a set.
