Author Topic: Welding Kart  (Read 30518 times)
Welding Kart
« on: December 15, 2013, 03:27:25 PM »
Lads
Made a start on a welding kart
http://i261.photobucket.com/albums/ii63/john970s0/weld%20cam/PC150072_zps37e6ec88.jpgWelding Kart
http://i261.photobucket.com/albums/ii63/john970s0/weld%20cam/PC150065_zps5b679c86.jpgWelding Kart
http://i261.photobucket.com/albums/ii63/john970s0/weld%20cam/PC150069_zps9f2b775e.jpgWelding Kart
http://i261.photobucket.com/albums/ii63/john970s0/weld%20cam/PC150067_zpse9f2a0da.jpgWelding Kart
http://i261.photobucket.com/albums/ii63/john970s0/weld%20cam/PC150073_zpsb160c136.jpgWelding Kart
« Last Edit: December 15, 2013, 05:00:03 PM by dsquire »
Re: Welding Kart
« Reply #1 on: December 15, 2013, 03:33:05 PM »
Looks like you're keeping the Plasma Cutter then John  :lol:
Andrew
Re: Welding Kart
« Reply #2 on: December 15, 2013, 03:48:34 PM »
I could not let it go back
It would be like giving a child a new toy then taking it away  :bugeye: :bugeye: :jaw: :jaw: :jaw:
Re: Welding Kart
« Reply #3 on: December 15, 2013, 05:47:46 PM »
Hi John , looks nice and will keep everything in one place but also mobile.................... I am sure you could find something else to fit on the lower section if the Plasma goes back  :bugeye: :bugeye: :bugeye: :bugeye:
  Cheers Mick.
Re: Welding Kart
« Reply #4 on: December 19, 2013, 10:23:34 AM »
Hi John
                I do like to see a spark of enthusiasm, quick of the mark with the kart, the units look smart and tidy. I think you are going to really enjoy that pair.  I expect you have already got a new project in mind.
        Good  Luck           Cheers David
Re: Welding Kart
« Reply #5 on: December 19, 2013, 10:24:57 AM »
Just needs another bar across the front and the Plasma Cutter CAN'T go back  :lol:
Andrew
Re: Welding Kart
« Reply #6 on: December 19, 2013, 03:41:57 PM »
Talking of plasma cutters I needed to cut a piece of what i thought was 12mm steel for a motor mounting conversion.
I have a Cebora 440v 40 A unit that is supposed to be good for 19mm. Problem is it's a pain in the rectum to get out, connect up and you get more heat off the gimbal on the electric meter than the torch.
I also have one of these cheap Cut40 plasma cutters which is supposed to cut 6mm.
Soooooooooooo if it cuts 6mm it will cut 12mm if you cut from both sides.
Dead quick to setup, support the plate on the council dustbin because when they catch fire you just get a new one. Only got to cut a plate 200 x 230 mm.
Cut from one side, turn over and repeat but it didn't fall free so quick smack with the BFH and it was on the deck.
Cleaning up I measured it and it wasn't 12mm it was 15mm so dead impressed that this little inverter jobby produced the goods.
Re: Welding Kart
« Reply #7 on: December 21, 2013, 05:31:38 PM »
well dun john
Re: Welding Kart
« Reply #8 on: December 21, 2013, 05:58:32 PM »
Lads
Got a bit more done
http://i261.photobucket.com/albums/ii63/john970s0/weld%20cam/PC210079_zpsed7e330c.jpgWelding Kart
http://i261.photobucket.com/albums/ii63/john970s0/weld%20cam/PC210076_zps0fdfcb5b.jpgWelding Kart
http://i261.photobucket.com/albums/ii63/john970s0/weld%20cam/PC210078_zps6a9b20af.jpgWelding Kart
http://i261.photobucket.com/albums/ii63/john970s0/weld%20cam/PC210081_zps55772fb8.jpgWelding Kart
http://i261.photobucket.com/albums/ii63/john970s0/weld%20cam/PC210082_zpsc4bd24e4.jpgWelding Kart
Re: Welding Kart
« Reply #9 on: December 26, 2013, 09:35:53 AM »
Lads
Managed a bit time in the shop today
http://i261.photobucket.com/albums/ii63/john970s0/weld%20cam/PC260097_zps37e19455.jpgWelding Kart
http://i261.photobucket.com/albums/ii63/john970s0/weld%20cam/PC260101_zpsa701d64d.jpgWelding Kart
http://i261.photobucket.com/albums/ii63/john970s0/weld%20cam/PC260098_zps65a1108f.jpgWelding Kart
It would be a real shame to separate them
Need some cable hooks and a handle now
Re: Welding Kart
« Reply #10 on: December 26, 2013, 10:13:14 AM »
Nice John, but it still needs a strap welding on to stop that Plasma cutter drifting back to R-Tech  :lol:
Andrew
Re: Welding Kart
« Reply #11 on: December 26, 2013, 10:35:14 AM »
I was thinking about welding on to stop any movement at all  :jaw: :jaw:
Offline Fredbare
  • Fakenham, Norfolk
Re: Welding Kart
« Reply #12 on: December 26, 2013, 02:27:28 PM »
Another fine job John.
Re: Welding Kart
« Reply #13 on: December 26, 2013, 05:36:56 PM »
Got a bit more done
http://i261.photobucket.com/albums/ii63/john970s0/weld%20cam/PC260104_zpsec771bc0.jpgWelding Kart
http://i261.photobucket.com/albums/ii63/john970s0/weld%20cam/PC260109_zpscd3509a6.jpgWelding Kart
http://i261.photobucket.com/albums/ii63/john970s0/weld%20cam/PC260108_zps7b34e333.jpgWelding Kart
Offline svk
Re: Welding Kart
« Reply #14 on: December 28, 2013, 03:09:29 PM »
Well done. You have to paint it in R-tech blue :D
Offline tekfab
Re: Welding Kart
« Reply #15 on: December 28, 2013, 03:33:31 PM »
It's a good thing your wife's there to weld it for you  ! :headbang:  :headbang:
Re: Welding Kart
« Reply #16 on: December 28, 2013, 05:14:12 PM »
Hi there, John,
How did you bend up the flanges on your two platforms?
Re: Welding Kart
« Reply #17 on: December 28, 2013, 05:26:00 PM »
I* cheated and got a mate with a 40 ton press brake to bend them for me :lol: :lol: :lol:
It could be done with angle iron and a hammer
Re: Welding Kart
« Reply #18 on: December 28, 2013, 06:00:04 PM »
Hi there, John,
I wondered how you got such a clean bend in such a thick gauge of steel.
If I were to attempt a bend like that with angle iron and a hammer, the finished job would have a lot of half-crowns all over it!    :lol:   :lol:   :lol:
 :offtopic:  Back in 1970, my wife and I moved into a new house.  There was a lot to do, including building a garage and workshop and a friend gave me a builder's wheelbarrow.  It was a bit ancient and the body was disintegrating.  The firm I worked for then had a scheme where employees could buy material through the company stores at friendly prices so I asked for a quote for a suitably sized sheet of 18 SWG mild steel.  The price quoted was SO FRIENDLY that I got over-enthusiastic and said 'in that case, I'll have it in 16 SWG.'.   :thumbup:   :thumbup:   :thumbup:
I took it home and marked it out and cut it to shape with a Monodex hand-shear.  When my hand, between my thumb and index finger, had healed (that's the one problem with the Monodex!!) I tried to bend it to shape.
I found that 16 SWG takes a lot more bending than 18 SWG!   :bang:   :bang:   :bang:
In the end, we took it out to the road in front of the house and set it on the ground so the fold lines, one after another, were over the edge of the kerb.  My wife stood on the footpath side of the bend line while I jumped on the other side (over the gutter).  That started the folds where we wanted them after which we completed the folds and got the seams to close with a hammer and block.
We did eventually get it to a usable barrow shape but there was no other barrow quite like it!   :lol:   :lol:   :lol:
Re: Welding Kart
« Reply #19 on: December 30, 2013, 09:14:04 AM »
John, I was wondering - will you be using the plasma torch as igniter for the kart's turbine/afterburner?!?  :zap:
