Author Topic: Rust removal on linear bearings and ballscrews?  (Read 17435 times)
« on: November 15, 2013, 09:06:57 AM »
Some electronics industry have been shipped to china and our scrapyards are filled with component placement machines. I got some parts that I could use on one experiment.
Balltracks seem to be unaffected, but other surfaces has some rust. I'm drying them out on the garage.
What is a good way to stabilize them and then remove offending rust and grime. I'm 100% sure I have to make some plastic dummies to keep the balls inside the nuts/runners and then remove those out of rails.
Plan (needs review and updates):
1) stabilize
2) make dummies, fill bearings with grease, move ballnuts/runners on dummies.
3) Clean the ballrails ballscrews
4) Purge  ballnuts/runners with some sort of grease
What do you think?
Re: Rust removal on linear bearings and ballscrews?
« Reply #1 on: November 15, 2013, 11:58:22 AM »
Hi there, Pekka,
First of all, it's important to remember that 1 inch of steel makes 13 inches of rust so don't panic!  It looks worse than it is!
There have been a couple of threads on here describing removal by chemical methods and by electrolysis, I haven't tried those myself but no doubt the folks who have will contribute here.
If you're forced to remove rust by hand, assuming that the rust attack is spotty or patchy, I think it's important to confine your work to the actual area of the rust and leave the rust-free parts alone.  My own preference is to use a scraper followed by a glass fibre brush.  Several suppliers in the UK here stock a glass fibre brush whose bristles can be retracted into the handle, rather like the lead extension/retraction mechanism of a propelling pencil.  It can be quite labour intensive and time consuming but good results can be achieved.
« Reply #2 on: November 15, 2013, 12:12:24 PM »
As many will know from my previous postings, I greatly favour Citric Acid.Very effective and safe to the hands as well as safe to dispose of - after all it's only lemon juice. I used about a cup full of crystals to a two gallon bucket but the actual dilution is not very critical.
Andrew
« Reply #3 on: November 16, 2013, 03:34:22 AM »
I normally would attack rust with citric acid or phtosphorous acid, but these are precision parts and I don't want to mess with ball tracks.
Glass fibre brush sounds interesting. Never seen one. Would like to have one.
« Reply #4 on: November 16, 2013, 03:45:58 AM »
Citric acid will only remove the rust and leave sound steel untouched. Fibreglass brush will erode both.
Andrew
« Reply #5 on: November 16, 2013, 04:59:01 AM »
Common enough in certain circles, Pekka. Try an electronics supplier.
This is what I have:
http://cpc.farnell.com/jsp/search/results.jsp?N=411&Ntk=gensearch&Ntt=fibreglass+brush&Ntx=mode+matchallpartial&suggestions=false&ref=globalsearch&_requestid=50892
Except mine is yellow, not red. [ The top one, not the Shesto item  .... ]
As Andrew said, they can be a bit aggressive ... but they do have their uses, the little brass brushes are quite good ...
« Reply #6 on: November 16, 2013, 11:24:30 AM »
I use a fibreglass brush for cleaning clock parts , but I always get a load of the glass splinters in my fingers and you can't see the b*****s to get them out .
« Reply #7 on: November 16, 2013, 05:41:54 PM »
Yes, sorry, I did mean to mention that!    :doh:   :(   :doh:   :(   :doh:   :(
