Author Topic: How do i achieve this?  (Read 33479 times)
Offline Bangkok Mick
Re: How do i achieve this?
« Reply #25 on: November 17, 2013, 05:57:15 AM »
Do you intend to produce many of these to close tolerances? Since they're mostly decorative you could just rough out the majority of the material with plunge cuts and a parting tool, then smooth the steps with a file and emery tape. If you need to keep close enough to a plan for some reason you could figure out how far to plunge each step.
Here's a shoddy representation.
Although the way i'd do them would just be to cut the bulk material free hand with the carriage and crosslide handwheel and file it smooth.
I know there's a great temptation to try do everything in clever and overly technical ways, but it's just not worth it for these one-off jobs. Keep it simple.
Plunge cuts cleaned up with file and emery cloth is exactly what I used to make my mini shisha pipe and I was pleased with the result.
Cheers Mick
Offline Fergus OMore
« Reply #26 on: November 17, 2013, 06:10:07 AM »
As you have called yourself 'Piper' and show a strangled octopus :lol: you should know what a chanter and drones looks like.
So the question is how did they make them? Actually, it is simple enough if you forget these dreadful carbide inserts and think that there are other things which remove metal or wood. What carves nice shapes in pipes and a lot of other things is not fancy carbides or fancier exotics but plain and simple 'form tools' in carbon steel or better high speed stuff.
I made me a left hand and right handed pair of form tools to do my chanter and drones in ten minutes.
You don't need fancy stuff, you need form tools.
Sorry but first things first.
Norman
  • Country: za
« Reply #27 on: November 17, 2013, 06:14:01 AM »
is this a devise that can be purchased or do you have to build one to fit your own lathe? sorry for the dumb questions.
Kev
Hi Kev,
You can buy them, but most guys tend to make their own. There are a few different designs some easier to make than others.
One that seems to have become a favourite is the 'Steve bedair'  one.
His site shows how to make it  http://bedair.org/Ball/ball1.html
Offline piper1
« Reply #28 on: November 17, 2013, 06:20:05 AM »
Kev
Hi Kev,
Thank you Dave I will go and have a read.
Kev
  • Country: za
« Reply #29 on: November 17, 2013, 06:22:06 AM »
Kev,
There are some on here - here's one
http://madmodder.net/index.php/topic,548.0.html
Offline piper1
« Reply #30 on: November 17, 2013, 06:23:45 AM »
Norman
Thanks Norman, I would love to see a picture of the end product.
Offline piper1
« Reply #31 on: November 17, 2013, 06:26:29 AM »
  • Country: za
« Reply #32 on: November 17, 2013, 06:39:23 AM »
  • Country: za
« Reply #33 on: November 17, 2013, 08:18:38 AM »
And if you wish to buy one http://www.serepton.co.uk/
« Reply #34 on: November 17, 2013, 09:16:23 AM »
Norman
[/quote]
Heavens! I made the pipes scores of years ago. No one wanted the supply of African blackwood and Brazilian. rosewood( under the bed :bang:) so it went to a musical instrument repairer whose wife bought the bass saxophone.
Maybe, we'll meet up- we've a date a bit North of you in April. In my opinion you should be getting a little tool and cutter grinder if you are unhappy about hand grinding form tools.
Probably, I'd knock up a graver with a 1/8th bit( bit) of hss square and only sharpen one face. I recall that I was using a knocked about school lathe with a bit of steel rod as a rest in the tool post to steady things!
It's not Fancy stuff. Pipes were made and bored with the shepherd's wife's steel  knitting needles and ground on the sandstone wheel and honed on the kitchen window sill.
It may be basic but that is how things CAN be done.
I'll be in touch.
Norman
Offline unc1esteve
« Reply #35 on: November 17, 2013, 09:28:32 AM »
Sorry I can not remember the particular tubal cain video.
Here is a link to get started.
http://www.woodworkforums.com/f65/freehand-turning-103759/
Do a google search on turning freehand on a metal lathe.
Offline piper1
« Reply #36 on: November 17, 2013, 09:58:47 AM »
Thanks Steve
Offline piper1
« Reply #37 on: November 17, 2013, 10:03:10 AM »
Thanks again Dave.
I've just seen one that RDG TOOLS do which suit my budget at the moment or I might and wait and see if Santa brings me lol.
« Reply #38 on: November 17, 2013, 01:29:46 PM »
No need for a ball turner since doing one offs and no need to set up.
Far easier and twenty times quicker making or using a ground up form tool or even a carbide radius works extremely well I do it daily but limited to 9.5mm depth. 2 mins for above shaping tops polished, really simple.
Offline piper1
« Reply #39 on: November 17, 2013, 01:38:08 PM »
Thank you, would you have any more information/pictures about a ground up form tool setup please.
« Reply #40 on: November 24, 2013, 04:46:35 PM »
You have a couple of options, one may be to grind a hss tool up to required shape but that's probably ok if doing a few or more.
If its one or two off I would just use a selection of normal tools and literally rough it out to shape then an easy sand in maybe even file amazingly easy.
To do the shaping in 1st piccy dead simple, set your favourite tool at an angle plunge in and profile. The angles left should be finished item.
Radiuses have to keep an eye on what your doing by eg moving carriage 1/2 pace of cross slide so working the two together and constantly altering as curvature changes.
Other way is to set top slide to cut specific angles maybe in conjunction with opposite side of tool.
« Reply #41 on: November 24, 2013, 06:19:13 PM »
To do a ball handle form tool is by drilling a cone in a bit of softened file- then cut it in half and temper it again.
This is how Chaddock did the Ball handles on the Quorn.
N
