Author Topic: Wheels, okay then... Castors  (Read 23143 times)
Offline Ooompa
« on: November 05, 2013, 05:25:11 PM »
I have decided it would help me greatly if I could fit some castors to my Anvil. Not the anvil itself of course but the stand it sits on.
The stand is a very substantial block of Engineered Mahogany approx 10" by 15" (long x wide)
If I could wheel my Anvil out of the way it would really help with the space issue in my workshop.
Obviously, a set of castors from a discarded "Hostess Trolley" would quite simply collapse under the weight.
Anyone have any suggestions?
Thanks,
graham.
graham.
Re: Wheels, okay then... Castors
« Reply #1 on: November 05, 2013, 06:55:34 PM »
I suspect that you will have to put the anvil back down on a solid base before you begin beating on it.
Otherwise you will soon wreck the wheels. Otherwise, use whatever wheels/castors will the the weight.
« Reply #2 on: November 06, 2013, 05:06:13 AM »
Determine roughly how much weight you need to carry, divide by 3, then go find some castors which will take that weight. eBay is a surprisingly good place to find low-cost quality castors.
For the lifting up/putting down, thing, I'd recommend building a frame for the castors which is normally off the floor, which is lowered and locked in place by a lever which puts the castors down for moving it... hard to explain, I'll see if I can find a picture later.
Offline shipto
  • Redditch, UK
« Reply #3 on: November 06, 2013, 05:25:31 AM »
If its a big block of wood what about hollowing out some spaces to house little wheels and have some kind of lever to lower them when needed?
best of both worlds manouverability and no extra bits sticking out to trip over.
« Reply #4 on: November 06, 2013, 06:46:19 AM »
Some sort of lift/lower arrangement as others have said, but I think the difficulty is going to be not obstructing the base where you want to put your feet. Can you make something that slips over the anvil and block, lifts and shifts, and is then removed for when you start working? Perhaps bore a pair of holes through your wooden block, through which you can insert lifting bars that rest on your lift and shift arrangement. I have the same issue but I'm afraid I just drag it out of the way at great effort.
Offline 75Plus
« Reply #5 on: November 06, 2013, 08:49:15 AM »
Take a look at this. It may give you some ideas.
http://www.grizzly.com/products/D2260A
Joe
Offline Dawai
« Reply #6 on: November 06, 2013, 08:09:51 PM »
Stick two wheels out one end? put a handle on the other, lift it like a wheel barrow and roll it around. It will sit on the floor till you tilt it onto the wheels to dolly it. Warning, one chunk on the floor can cause a endo-high side.. top heavy..
Offline S. Heslop
« Reply #7 on: November 07, 2013, 10:53:34 AM »
Something like this could work.
http://woodgears.ca/mobile_base/table_saw.html
Maybe you could make it from steel to survive the weight.
« Reply #8 on: November 25, 2013, 01:57:08 PM »
          Simon, that is a neat way of moving a table saw.
Offline Arbalist
« Reply #9 on: November 25, 2013, 02:43:32 PM »
I can't help Graham but I have the same problem so if you sort it out please post some pictures. :thumbup:
My Anvil is only 1 cwt but I reckon the Oak stump it's mounted on weighs about the same!
Offline AussieJimG
« Reply #10 on: October 06, 2014, 01:51:11 AM »
What about lifting it with air (like a hovercraft). And it will blow all the crap into the corners of the workshop at the same time.
Jim
