Author Topic: thread identification  (Read 19186 times)
Offline angus
« on: October 13, 2013, 11:56:43 AM »
hi
i have a bit of a puzzler
i am missing a screw from a williams rifle sight... its 0.138 diameter, so either 9/64 or 3.5mm
and either 0.5mm pitch or 48tpi
the books i have dont really give me a standard thread.....
any idea's as to what thread  it is ?
Re: thread identification
« Reply #1 on: October 13, 2013, 12:39:26 PM »
A 3.5mm screw would have an OD of 3.48mm so the OD of 3.505 suggests an imperial size. Also M3.5 typically comes in 0.6 and 0.35mm pitches, which would work out at 42.3 and 72.5tpi, so there's no metric equivalent close to your 48tpi.
Offline angus
« Reply #2 on: October 13, 2013, 12:48:01 PM »
sort of worked that bit out for myself..... the sight came from America, so guess it will be nothing standard!
« Reply #3 on: October 13, 2013, 01:19:58 PM »
It doesn't necessarily have to be a standard thread.....
I've known threads to be made as "specials" .........There' no reason why you can't make any thread the size you want....
« Reply #4 on: October 13, 2013, 01:23:48 PM »
hi
Angus,
It looks very much like a 6-48 UNS to me. (Which is 6 gauge in neither UNF(ine) or UNC(oarse) but UNS(pecial).)
I don't know where you would get a die to make a screw in the UK. They come in kits of taps & dies for gunsmiths in the US:
http://www.brownells.com/gunsmith-tools-supplies/general-gunsmith-tools/taps-dies/tap-die-kits/tap-die-kit-no-1-prod713.aspx
Cheers.
« Reply #5 on: October 13, 2013, 02:58:20 PM »
« Reply #6 on: October 13, 2013, 04:04:41 PM »
hi
Angus,
Cheers.
I think you're right, since the TPI matches and only 3 thou out on the OD from his measured size:
http://www.muzzlecouplings.com/measuring_thread_size.htm
http://www.ebay.com/bhp/6-48-screws
« Reply #7 on: October 14, 2013, 05:27:04 PM »
Still the most common thread used in US, theyre still on UNC, UNF but slowly changing over to metric.
Taps and dies quite common here too and cheap because no one wants them about £4 delivered for an 8-32 HSS tap last month for US, dies about the same.
Sure the 48TPI is about right?
Williams I would have thought 6-32  or 8-32 if measured the threaded hole.
Offline 75Plus
« Reply #8 on: October 14, 2013, 05:43:25 PM »
6-40, 6-48 and 8-40 are common sizes found in US made firearms and have been for at least a century. Here is the inventory of a Master Gunsmiths 142 pc. screw assortment from Brownell's, one of the top gunsmithing parts sources in the US.
 Master Gunsmith Screw Kit-142 Kit
Contains 10 each of 14 premium 3/32” hex style scope and base screws. These difficult to find screws are favored non-slip replacements for slotted screws. Set includes tweezers and thread size gauge/shortening jig.
Kit Contains:
#6-40 Fillister Head (3/8, ½)
#6-40 Oval Head (1/4, 3/8)
#6-48 Fillister Head (1/4, 3/8, 9/16)
#6-48 Oval Head (1/4, 3/8)
#8-40 Fillister Head (1/4, 3/8, ½)
#8-40 Oval Head (1/4, ½)
Offline angus
« Reply #9 on: October 15, 2013, 12:06:58 PM »
the measurements are of the other locking screw.... definitely seems to be 4-48.... a mate of a mate thinks he has some... time will tell
« Reply #10 on: October 15, 2013, 02:14:22 PM »
Angus,
4-48 is much smaller OD than you originally quoted and is a standard UNF thread and is only 0.118" c.f. 0.138" you originally quoted.
6-48 UNS is 0.138".
Offline angus
« Reply #11 on: October 15, 2013, 04:29:35 PM »
sorry philf my keyboard isnt typing what i meant!!! :doh:
i have 6-48 UNS written on my desk!
