Author Topic: Gear Cutter  (Read 14370 times)
Gear Cutter
« on: September 14, 2013, 02:06:48 AM »
Some time ago I read an article about making gear cutters on a lathe , using two pins a set distance apart I found a program on Marv Klutz's  web site that works out the size and distances for the pins and the in feed , I made a couple and they worked , looking at them I thought that they could be made on a mill with a indexing head a lot easier using an end mill , the re-leaf angles are 15 degrees as I used a 24 hole dividing ring and they work just as well .
« Last Edit: September 14, 2013, 08:42:05 PM by vtsteam »
Re: Gear Cutter
« Reply #1 on: September 14, 2013, 02:33:58 PM »
Pic's are to big for my tablet but anyone can see them if they use the view picture on their puter or tablet.
Offline mklotz
  • LA, CA, USA
Re: Gear Cutter
« Reply #2 on: September 14, 2013, 02:52:38 PM »
Klotz, not "Klutz".  I'm German, not Yiddish.
Regards, Marv
Home Shop Freeware
Re: Gear Cutter
« Reply #3 on: September 14, 2013, 07:16:13 PM »
So if it was "Kloutz" would that be German / Yiddish ?
Offline mklotz
  • LA, CA, USA
Re: Gear Cutter
« Reply #4 on: September 14, 2013, 07:28:22 PM »
No, that would be "clumsy bastard" typing.
Regards, Marv
Home Shop Freeware
Re: Gear Cutter
« Reply #5 on: September 14, 2013, 08:44:12 PM »
Photo sizes reduced.
Re: Gear Cutter
« Reply #6 on: September 15, 2013, 01:50:34 AM »
Sorry Marv I am dyslexic no sleight intended , the cutter sort of worked the re leaf angle needs to be greater , cut a mild steel gear and the cutter rubbed 15 degrees wasn't enough ,
