Author Topic: Replacing Bearings in a Bench Grinder  (Read 10308 times)
« on: August 31, 2013, 08:06:06 AM »
Hi Guys
              I am attempting to remove the bearings in a bench grinder, and have struck problem. There is a  1/8  inch dia. roll pin driven into a blind hole in the shaft with only 85 thou protruding. I have tried the obvious pliers with nil success. Has anyone any bright ideas?
Re: Replacing Bearings in a Bench Grinder
« Reply #1 on: August 31, 2013, 08:49:51 AM »
Mole grips
Drill behind it and punch it out
Weld a nut on to it
« Reply #2 on: August 31, 2013, 09:04:29 AM »
Buy a new grinder around £23 from toolstation...... :coffee:
Offline DavesWimshurst
« Reply #3 on: August 31, 2013, 09:31:00 AM »
Grind or file level with surface of shaft. Remove shaft. Drill from back side of blind hole and punch out pin.
« Reply #4 on: August 31, 2013, 01:09:40 PM »
Hi Guys
                 Thanks for the suggestions. I tried the mole to no avail, and decided to drill from the rear and punch the roll pin out. I set the shaft up in the dividing head on the mill, and found the center using a small drill, started the machine and just entered the hole to check running clear.  I stopped the mill withdrew the center drill and noticed a small bright witness on the roll pin, it was soft, what luck! so I drilled it out from the front. Then I set up again for the other roll pin, no such luck it was hard, progress was slow but the HSS drill was harder than the pin, and I just managed to drill it out before completely blunting the drill. Think I will replace the pins with silver steel pins.  Another job done.
                                                            Cheers  David
« Reply #5 on: August 31, 2013, 03:07:06 PM »
Thank goodness....... :drool:
Was thinking you might have to spend a few quid........ :lol:
