Author Topic: How big aught the vent in a metal melting furnace be?  (Read 13358 times)
Offline S. Heslop
« on: August 20, 2013, 04:31:49 PM »
Here's where i'm at right now.
I read a thing online that said to give it 7x the cross sectional area of the burner tube, which worked out to about 60mm diameter with an inch wide burner. I've made a stack of MDF discs as the inner form, but I'm sort of feeling it looks a little bit small.
I suppose itd make more sense to over-shoot the ideal size since you can cover it partially with a fire brick, but i'd rather not make it too big.
Re: How big aught the vent in a metal melting furnace be?
« Reply #1 on: August 20, 2013, 05:17:01 PM »
Mine vents through a 80 mm pipe (side vent) as the furnace is inside
The hole in the top is 100 mm closed with a fire brick
« Reply #2 on: August 20, 2013, 07:40:33 PM »
Mine has a 4" vent hole too.
Offline S. Heslop
« Reply #3 on: August 21, 2013, 07:06:58 AM »
I guess 100mm is the way to go then. Thanks for the replies.
