Author Topic: Spanner-less QCTP for small lathe  (Read 11735 times)
« on: August 16, 2013, 02:56:05 PM »
I can hear the cries now "not another QCTP!"
This one is a spanner-less version of the Norman Patent design (with a nod to mikesworkshop)
It should be self explanatory. The thing works by expanding a ring into the hole in the tool holder (as per the mikesworkshop design), the variation is the slot in the back to allow it to go over the tool post lever.
« Last Edit: August 17, 2013, 12:58:38 PM by BillTodd »
Offline NeoTech
    • Roughedge Hobbyworks
Re: Spanner-less QCTP for small lathe
« Reply #1 on: August 16, 2013, 03:09:44 PM »
This was kinda genious..
Im bloody tired of my multifix - damn hopeless to clone the holder..
« Reply #2 on: August 16, 2013, 04:28:40 PM »
I can here the cries now "not another QCTP!"
I don't think there _can_ be enough QCTP threads, can there? They are marvellous devices.... I really must finish mine off one day...
« Reply #3 on: August 16, 2013, 05:55:19 PM »
Not from me! Nice one.  :thumbup: :clap:
« Reply #4 on: November 13, 2013, 02:43:29 PM »
Jaker, your inbox is full.
Perhaps you'd like to continue the qctp discussion here
« Reply #5 on: November 13, 2013, 03:04:29 PM »
Always interesting to see new ideas - and if it's QCTPs then it's QCTPs  :ddb:
I'm sure that that design is fine for a small lathe, but I don't think that it would scale up to a larger one with much larger cutting forces as the cunning slot will tend to open up as the expanding collar grips it.
It must be possible to make the vertical part of the locking shaft longer so that an unslotted holder will lift up clear of the central spigot, then tilt to allow the handle to pass through it.
Andrew
