Author Topic: MDF board  (Read 14481 times)
Offline John Lindo
MDF board
« on: August 06, 2013, 12:46:12 AM »
I had to reduce a piece of MDF board thickness the other day.
Using my mill and a standard endmill it worked ok,until I picked up my shop vac with a plastic hose to
clean up the DUST and at the same time touched the machine.
I got quite an electrostatic shock.
It's never happened before,with metal cutting so I did a bit more cutting and again same thing happened.
Is the MDF storing static?
Spain
Re: MDF board
« Reply #1 on: August 06, 2013, 05:09:47 AM »
Does happen, I get it with machining plastic. Bits jump up and stick to the side of the nozzle rather than going up the tube. Never got a shock yet but it certainly could happen.
You've just made a rather crude but nonetheless effective 'Tribo-electric' generator with the dry dust and the insulated hose.
http://en.wikipedia.org/wiki/Electrostatic_generator
Re: MDF board
« Reply #2 on: August 06, 2013, 05:35:08 AM »
hi John,
just a couple of thoughts :
1/ Try and avoid inhaling the MDF dust -  the dust, and (if present) the formaldehyde binder aren't good for you (MDF health FAQ)
2/ Re dust / electrostatics - wood dust (= fine particles) is explosive, and commercial extraction systems have to be conductive so any static is dissipated to earth (useful info)
