Author Topic: Rotary Broacher  (Read 14120 times)
Offline Trebor
Rotary Broacher
« on: August 02, 2013, 01:19:25 PM »
Can anyone tell me if its possible to buy a rotary broacher in the UK ?
Offline NeoTech
    • Roughedge Hobbyworks
Re: Rotary Broacher
« Reply #1 on: August 02, 2013, 01:28:14 PM »
Make one? Its a good little project. :)
Offline Trebor
Re: Rotary Broacher
« Reply #2 on: August 02, 2013, 01:45:14 PM »
If only I knew how !! Just found this but It looks expensive
« Last Edit: August 02, 2013, 02:07:57 PM by dsquire »
Offline tekfab
Re: Rotary Broacher
« Reply #3 on: August 02, 2013, 02:06:07 PM »
Did our very own Rob Wilson not make one ? i think it would be somewhere in the Project logs if you look.
Mike
Offline NeoTech
Re: Rotary Broacher
« Reply #4 on: August 02, 2013, 02:09:25 PM »
http://www.homemodelenginemachinist.com/f12/rotary-broach-tool-design-14076/
Theres a cad file i n the HME topic regarding wobble / rotary broaches..
Basicly a two part tool back end is 90 degree flat with the chuck, the front part is set 1 degree off, the tool rotates on a throwout bearing and radial bearing.
Offline NeoTech
Re: Rotary Broacher
« Reply #5 on: August 02, 2013, 02:11:09 PM »
http://www.homemadetools.net/rotary-broaching-tool
Here you have another design on the same issue. =)
Offline John Swift
Re: Rotary Broacher
« Reply #6 on: August 02, 2013, 02:22:50 PM »
Hi Trebor
yes , you can buy them in the UK
first web search result ---  http://www.repco-tech.co.uk/broaching-attachments/
how many thousands of parts are you making ?
Offline Trebor
Re: Rotary Broacher
« Reply #7 on: August 02, 2013, 02:43:29 PM »
Theres no indication on prices !! I would love having a go at making one but at the moment ai only have a lathe and a few tools  :bang:
Offline NeoTech
Re: Rotary Broacher
« Reply #8 on: August 02, 2013, 02:45:10 PM »
All you need is actually the lathe.. Before i got my mill i did all kinds of exploratory operations on my lathe, with setting up the work on faceplate holding endmills in the ordinary tool holder, drill chucks and whatever..   To be honest.. The lathe is a mill lying down basicly..
Offline John Swift
Re: Rotary Broacher
« Reply #9 on: August 02, 2013, 03:39:10 PM »
Hi Trebor
I suspect a second hand one will be a few hundred pounds and a new one if you have to ask whats the price you can't afford it for hobby use
years ago I watched an EMI-MEC sprint ,  broach 3/8" square holes in the parts it was making
the job run for days
 ( automated capstan lathe  with a 3 HP spindle motor if I remember correctly)
for a diy broach look here -
http://madmodder.net/index.php/topic,6165.msg70542.html#msg70542
